mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
AJack500 Samba Member
Joined: October 17, 2011 Posts: 78 Location: Oklahoma
Posted: Fri Feb 05, 2021 6:10 am Post subject: Re: Early 1964 Turkis Standard Bus Build |
mdege wrote: |
That is the wrong rocker for that MY. You need the later rocker which has recess where the doors meet. |
It was funny, I noticed that shortly after updating this post. I have a funky green rocker as well and it fits much better. |
Two Glove Boxes Samba Member
Posted: Fri Feb 05, 2021 8:02 am Post subject: Re: Early 1964 Turkis Standard Bus Build |
AJack500 wrote: |
mdege wrote: |
Gerson's metal has gotten better and better over the years and it is mostly what helped get my truck finished the right way. _________________ 1951 Split Standard Hoffman Build
Two Glove Boxes
DLK |
Posted: Wed Feb 24, 2021 5:51 pm Post subject: Re: Early 1964 Turkis Standard Bus Build |
B pillar done. Dreading the long rocker job.
Posted: Thu Apr 22, 2021 6:42 pm Post subject: Re: Early 1964 Turkis Standard Bus Build |
Still chugging along on the long rocker. It is about 90% welded in. Cargo floors next! So far thinking about pausing the metal work after the rear corners and floors are fitted and getting it running and driving.
Some progress photos:
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Fri Apr 23, 2021 11:43 am Post subject: Re: Early 1964 Turkis Standard Bus Build |
Awesome! Any plans for paint blending?
O'Reilly's here can make spray cans using either the paint code or a scan of something you bring in. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Sat Apr 24, 2021 1:22 pm Post subject: Re: Early 1964 Turkis Standard Bus Build |
Yeah, It will be blended to an extent using the filler cap as a match for the color. I plan on just cleaning up the current nose for now and paint blending the bad spots. I considered fitting a new nose to it but that can wait for another day. |
Posted: Tue Apr 02, 2024 3:07 pm Post subject: Re: Early 1964 Turkis Standard Bus Build |
It's been awhile since the last update. I recently got reassigned to another state so it was time to move the bus. I made a cart out of 2x2 square stock and some industrial casters for easier loading onto the flatbed trailer.
Some photos of the cargo floor install. The heater channels all welded in after these were taken.
The corners were one of the toughest parts of this build for me. It took me about a year of on-off work to figure out why the right side door gap would not line up. Ended up making a few relief cuts and used some other folks buses as measurements in addition to the Bentley frame specs. It seems like mine was in a rear-end as the D-pillars were totally mangled and nothing was lining up.
Once I fit the apron, I tacked in the supports and every thing else fell into place. Still working on the right side. Currently fitting the battery tray, then onto the left side. I did manage to cut out the front floor in prep for that install once the corners are done.
