clutch management system when does it need to be implemented
58ragman
58ragman is offline
PostPosted: Wed Apr 21, 2021 12:38 pm    Post subject: clutch management system when does it need to be implemented Reply with quote
got most of the running gear and need to think bout the longivity of the trans.Its gonna be a MENDI so i dont want it to break first round out.
Was told that I may want to invest in a clutch management system.
So iam here on the boards to see what i can come up with.
Who builds such a system
what is the typical cost complete installed with parts
typical time to build install.
turbo motor
1400 lbs total weight with driver
semi street tires no slicks basically whos your daddy tires.
can the system be used for drag then when on the street do not use it
lastly at what point do you need such a system
vwracerdave
vwracerdave is offline
PostPosted: Wed Apr 21, 2021 3:16 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
There isn't one answer or one solution or one system. Over the years I have seen all kinds of clutch management systems, or attempts of clutch management. I've seen everything from the Gene Berg Washington anti shocker to air actuated cylinoids connected into the brake & clutch peddles and wired into the delay boxes and ignition systems. I've seen other racers that didn't have any of that stuff on their car win races.
I also feel driving style has a big impact on parts breakage.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
madmike
madmike is offline
PostPosted: Thu Apr 22, 2021 3:57 am    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
The washington anti shocker makes the clutch slip on every gear change Rolling Eyes
check out 'Muffler Mikes' set up his only works on the launch then is disconnected Wink
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Ohio Tom
Ohio Tom is offline
PostPosted: Thu Apr 22, 2021 1:25 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
1. you really need a bunch of HP to break a Mendi... .They are super strong.
I think they can support 800hp easily.
2. First you convert to hydraulic clutch.
Then you make a parallel branch in the line running to the slave.
1 branch will have a line-lock solenoid.
the other branch will have a "directional flow control" valve (needle valve to control flow that only works in one direction). Pretty common from industrial supply houses.
The line-lock is slaved to a micro switch on the shifter so it's only activated when in 1st gear.
The switch closes; Energizes the line lock; forcing fluid thru the flow control valve making clutch release action slower than you foot. You can tweak the flow control to speed up, or slow down the release action.
Once you shift out of 1st, the line-lock opens and allows normal operation for the rest of the gears.
They allow you to control the "hit" when drag racing. And they are very consistent.
jim martin
jim martin is offline
PostPosted: Thu Apr 22, 2021 3:28 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
im all over this and have a system that works and controls hydraulic and air/co2
sorry at work now will get some info up later when at home.
here is a early test from 2017
and more current
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
58ragman
58ragman is offline
PostPosted: Thu Apr 22, 2021 3:58 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
thanks guys for chiming in to give me an ideal what im up against all sounds good thanks again
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Thu Apr 22, 2021 4:59 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
Tom’s style system is the slickest I know of. You could have a master switch to the controlling micro switch to turn the system completely off for normal street driving. If you are racing in any specific class, check into the rules first. There are rules in certain classes about having devices controlling the release of the clutch for timing purposes, and this may fall under that if the tech inspector doesn’t understand its function.
jim martin
PostPosted: Thu Apr 22, 2021 7:54 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
there is a lot more to it than Toms system , which is the basic point most systems came from .
and no reason ever to turn it off on the street ,this is where a controllable and adjustable system really shines .
I can pull away as smooth as a car with a auto trans . control all 5 gears and make adjustments while sitting in the drivers seat .
Sponsored by :
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Thu Apr 22, 2021 10:23 pm    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
Have you considered a RLR Rev 6 clutch? Its designed to accomplish what you're after with less complexity https://ronlummusracing.com/product/rev-6-clutch-system-single-disc/
https://instagram.com/mr.ogpaint
Patrick Hall
[email protected]
PostPosted: Fri Apr 23, 2021 5:32 am    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
I thought the entire purpose of the system was to allow a tiny amount of slippage to the clutch when “dumping” it by slowing down its release in a consistent/repeatable manner without having to think about it while you are paying attention the lights on the tree?
None of these conditions apply on the street, so I thought you just used your leg to control how hard the clutch is released?
I understand your first post was when you were at work, but care to elaborate on what “a lot more to it” is?
58ragman
58ragman is offline
PostPosted: Fri Apr 23, 2021 9:00 am    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
has anybody used the management system alongside with a rev 6 clutch set up. is this a redundit move Or you can run the rev 6 with a clutch management system.
Ive noticied in a few drag cars that if they are running a clutch management system they are running a Kennedy plate and dual disc
I've noticed that the rev 6 clutch set up in a lot of cars are mechanical clutch cable no cylinder.
Being set up like so can a rev 6 still be set up with CMS since the pedal is not assisted with hydraulic fluid
jim martin
PostPosted: Sat Apr 24, 2021 7:53 am    Post subject: Re: clutch management system when does it need to be implemented Reply with quote
sorry guys away this weekend and this topic has a huge amount of information .
quickly thoe: the rev 6 is not the end all .I know I presently have it and run it and have tested it with and without clutch management .
running the rev6 with my ECMS system in my opinion is now the ultimate system/setup .
I have run multiple single disc set-up and 3 double disc setups ,there has been winners and losers .will get back later
Sponsored by :
