Rgl1100 Samba Member
Posted: Fri Apr 23, 2021 2:47 am Post subject: Split window 2 speed wiper motor terminals |
I’m having a frustrating time with a wiper motor. I’m in the middle of a complete rewiring of my 67 bus. I’ve got the correct 2 speed switch. I know the motor works ok because it worked prior to removing it however the wiring from the PO was just a mess. Wrong colors, tape, exposed wire, etc. Problem is, the motor has no indication whatsoever of which terminals correspond to what they are. They don’t have markings for 53a or b, 31, etc. I’m posting a picture of what I have with the hope that someone can tell me which terminal corresponds to what.......BTW, disregard the wires you see. Although they do correspond to the correct terminals that need to be used, the colors were only a guess on my part as to what they were. Please help. I’m stumped......
swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
Posted: Fri Apr 23, 2021 5:19 am Post subject: Re: Split window 2 speed wiper motor terminals |
Well, that is even not the original plate of the wiper motor, so it is hard to say what belongs where. I think you have to open it and see where the contacts go to. Here is a picture of the original cover plate, which would have the terminal numbers pressed into the metal.
_________________ Recent pics from my SO-42 rebuild: https://www.instagram.com/anni_vintage_bus/ |
Posted: Fri Apr 23, 2021 5:32 am Post subject: Re: Split window 2 speed wiper motor terminals |
Wow, I had no idea. This is very helpful. Is there anyway for yourself or anyone else to open this plate and show the connections between the plate and the inner connections? Thank you! |
