waller Samba Member
Posted: Mon Apr 19, 2021 10:58 am Post subject: Intermittent power loss |
Hi all
I have a 78 Beetle that is normally pretty reliable. This morning (it's been parked since last night), I got in and started and noticed it was having a little trouble, but started up fine as usual. Drove it just fine 5 miles, parked and went into a store. When I came out, it was like someone left the headlights on all night and it wouldn't start up.
My wife came and boosted me, it started right up. I've turned it off and on again a few times since then and no issues at all. I don't want to get stuck on my own somewhere, what gives or what should I check?
Also my GEN light sometimes come on right away before starting, sometimes it doesn't but if I wait a minute it eventually shows up (not sure if this is related but thought I'd mention it)
Ryan |
Nicholas D Samba Member
Joined: November 06, 2012 Posts: 225 Location: Charleston, SC
Posted: Tue Apr 20, 2021 5:07 am Post subject: Re: Intermittent power loss |
How old is the battery? That would be the first thing I'd check. Any auto parts store can check it for you. The generator light sometimes comes on in my bus when I first start it before the idle picks up a bit. If I tap the gas it'll go out and stay gone once the rpms increase. I believe both the generator and oil lights come on when I first start my bug and go right out but I'm not 100% on that. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Tue Apr 20, 2021 7:00 am Post subject: Re: Intermittent power loss |
Nicholas D wrote: |
How old is the battery? That would be the first thing I'd check. Any auto parts store can check it for you. The generator light sometimes comes on in my bus when I first start |
Clean up ALL the connections, terminals, etc.
But could simply be a bad battery, because it started right up when jump-started, that gave it more "battery power". _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
waller Samba Member
Posted: Tue Apr 20, 2021 7:46 am Post subject: Re: Intermittent power loss |
Thanks for the replies- I was thinking battery as well. Totally caught me off guard yesterday but is operating as normal again today.
Battery is from previous owner- I have no idea on age. Maybe I should just replace it to be safe. |
1968BUGMAN Samba Member
Joined: April 12, 2019 Posts: 246 Location: Southern California
Posted: Tue Apr 20, 2021 10:17 am Post subject: Re: Intermittent power loss |
It could also be the generator going out, but most likely the battery. I had a friend or had a similar problem with their bus, but it got to the point where they couldn't even jump it. I replaced their alternator for them and it runs great now, fixed the problems. I would recommend checking voltage/amperage of the generator when it is off. I also had a similar problem and it was my alternator. _________________ 1968 Beetle Project | https://www.thesamba.com/vw/forum/viewtopic.php?t=...ae8942450a
Installing a Stereo Into a Classic VW | https://www.thesamba.com/vw/forum/viewtopic.php?p=9502179#9502179 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9970 Location: Huntington Beach, CA
Posted: Tue Apr 20, 2021 5:15 pm Post subject: Re: Intermittent power loss |
It could be dirty terminals at the battery. Take a look at them. Clean them up and see if that improves the situation. A little bit of corrosion will limit the charging of the battery and have the exact symptoms you have detailed. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
waller Samba Member
Posted: Thu Apr 22, 2021 3:49 pm Post subject: Re: Intermittent power loss |
Hi all,
Car died again, so I pulled out the multi meter and have the following readings:
- no key in ignition: 11.3 and declining slowly
- key in ACC position: 9.4 and declining to 8.9
Is this likely a battery issue?
Current battery is an Interstate 525 CCA. What do you recommend I replace it with? (78 FI Beetle) |
Posted: Thu Apr 22, 2021 5:23 pm Post subject: Re: Intermittent power loss |
Battery or a big draw.
Remove the battery cables and recheck voltage. Does it climb back up? _________________ Jimbo
TDCTDI wrote: |
waller Samba Member
Posted: Thu Apr 22, 2021 5:33 pm Post subject: Re: Intermittent power loss |
VW_Jimbo wrote: |
Remove the battery cables and recheck voltage. Does it climb back up? |
With no cables, it's consistent at 11.8. What does that mean? |
waller Samba Member
Posted: Fri Apr 23, 2021 9:05 am Post subject: Re: Intermittent power loss HELP! |
OK so I have some updates but problem not solved.
-I replaced the battery and that's not the issue.
-Gen light not coming on
-With a boost, it starts right up but after two minutes of idling it dies.
Ideas? |
waller Samba Member
Posted: Fri Apr 23, 2021 10:30 am Post subject: Re: Intermittent power loss |
It’s not the battery. It’s over 14.
Here’s a pic of some of the wires at the battery and in the engine compartment. What would you do?
EDIT: the first pic at the battery had electrical tape around this grouping of wires, one was not connected.
ALSO EDIT: Gen light seems to be coming on faintly if I leave the car for a while, like it's charging up.
waller Samba Member
Posted: Fri Apr 23, 2021 11:35 am Post subject: Re: Intermittent power loss |
I’m at a loss. Now, the battery is reading 6.3 with key on, 7.5 with the key off and 10.5 when I take it out of the car completely and test it.
Brand new battery.
What the heck? |
Posted: Fri Apr 23, 2021 12:39 pm Post subject: Re: Intermittent power loss |
Hey man! Looks like you are chasing your tail a little bit. First stop and breathe.
Now, fix the connection at the battery cable(s). You have to start at the START. No going around it. Also, DO NOT use your meter as an amp draw test, there are better ways, that are just as accurate. The possibility of burning up a meter is fairly high, unless it has a fuse for protection.
Fix the connection.
Charge the battery.
Document voltage of battery after charging. Then install battery. Do not connect the cables yet. Go to Harbor Freight and pick up a cheap ($15) “clamp” style amp meter.
Reconnect you battery cables and set the clamp meter up on the positive cable.
Go to your fuse panel and start removing and reinstalling the fuses, one by one, checking the meter at each one. You are looking to see a drop in amps from one of those fuses. Hopefully finding the one which will allow less than .25amps to be drawn.
Good luck! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri Apr 23, 2021 12:49 pm Post subject: Re: Intermittent power loss |
Good advice about using an amp meter instead. I use a harbor freight multimeter that I got for free so I dont care if it blows up, my nice Klein once has a fuse, which I actually did blow at one point. A proper amp meter is better though. Also you can try redoing wiring like Jimbo said. I found that my car had really shotty wiring from the alt to the battery so I replaced it. While it didn't fix my problem it did help a bit, and it gives me some piece of mind that the wire wont fry. _________________ 1968 Beetle Project | https://www.thesamba.com/vw/forum/viewtopic.php?t=...ae8942450a
waller Samba Member
Posted: Fri Apr 23, 2021 2:39 pm Post subject: Re: Intermittent power loss |
VW_Jimbo wrote: |
Good luck! |
Thanks Jimbo- are you referring to parasitic test? If so, I did this and none of the fuses under the dash caused the amps to drop. Are there more locations that I should be checking? |
Posted: Fri Apr 23, 2021 3:03 pm Post subject: Re: Intermittent power loss |
You are going to have to start by removing the wires one at a time from that battery connection. Then follow it to the next part. One of those wires has amps moving through it when the car should be off!
Couple of items come to mind right off the bat....A/C clutch trying to engage or is continually engaged, even though there is no belt. Might want to unplug the wiring if you have not already.
The ignition coil is an unprotected hot wire. Sometimes they burn out and cross into other wires. Maybe a previous owner had it burn our. They "fixed" it and it worked, but now it does not. I have tracked down this exact issue more times than I have fingers and toes in my house holds, including the pets!
Any of the relay driven devices have the possibility of the relay getting stuck in the closed position.
Just a few thoughts there. Do you have anything not working or working oddly?
If not, really what works is watching a meter, reading amps at the battery while disconnecting wires. The battery feeder to the light switch is an unfused battery hot wire.
Alternator field may be stuck.
CPU for fuel injection may be stuck. It works the fuel pump, too!
Maybe the ignition switch is leaking voltage to something.
My money is on the Alternator! Or even better, if there had been an alarm installed into the car at one time!!!!
The diagnostic port also has a battery hot in it that could become compromised. Seen that one, 1 time! That was a head scratcher of a day! _________________ Jimbo
TDCTDI wrote: |
