69 wiring diagram - 67+ isn't correct
iamnotatwork
iamnotatwork is offline
PostPosted: Fri Apr 23, 2021 9:49 am    Post subject: 69 wiring diagram - 67+ isn't correct Reply with quote
I bought a new wiring harness from ispwest but the included diagram is not correct for 69... Has anyone drawn a new diagram? I checked the tech area but didn't see...
Thanks!
1967 Bug "Giblet"
1969 Squareback (undergoing restoration) "The Pickleback"
DQDan
DQDan is offline
PostPosted: Fri Apr 23, 2021 10:34 am    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
https://www.thesamba.com/vw/archives/info/wiringt3.php
iamnotatwork
PostPosted: Fri Apr 23, 2021 10:57 am    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
The diagram "type3_6870" in that link seems to be incorrect for 68 and 69. I will check the Mitchell pages also included in that link; maybe those will be helpful.
Thanks!
1967 Bug "Giblet"
iamnotatwork
PostPosted: Fri Apr 23, 2021 12:41 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
Lots of conflicting info there.
The wiring diagram that came with the loom from ISPWest is not correct for the wires received.
The color diagram in that link doesn't follow either...
The block diagram is good but lacks the pin assignments for the relays and such...
Anyone out there use one of the ISPWest looms for a 68-69 square?
1967 Bug "Giblet"
Erik G
Erik G is offline
PostPosted: Fri Apr 23, 2021 12:53 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
you keep saying not correct but not sharing any examples of why you consider it incorrect. please, by all means enlighten us...
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Apr 23, 2021 2:07 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
I can't speak to the wiring itself, but based on the style of the front and rear running lamp lenses, that diagram is for 1970, not '68-70.
Strange that a VWOA diagram would be in error, but it is.
DQDan
DQDan is offline
PostPosted: Fri Apr 23, 2021 4:36 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
Phil, are you saying you think VW should redo a wiring diagram because the shape of a blinker housing changed? If the wiring did not change I can't see why they would bother. To me it looks like the shape of the 66 blinkers, not the 70 ones. But of course it is FI so it's not a 66.
KTPhil is offline
PostPosted: Fri Apr 23, 2021 4:59 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
Those older-style wiring diagrams (pre-'73) not only show connections, but they also give a clue to the wire's physical location. This can be confusing if it doesn't match the car, as in this case.
The location of reverse lights, for example, is different. I expect there are other differences that are not quite so apparent... until that difference affects your car!
I know the dashboard grounds changed during that period, so tracing some unknown brown wire, or resolving a poor-ground issue, can be harder with the wrong diagram.
Those lenses have the small separate bulb that started in '70 (USA models). Some earlier models had "wraparound" lenses but they didn't use the separate small bulb, as shown here:
ataraxia
ataraxia is offline
PostPosted: Fri Apr 23, 2021 5:09 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
The wiring diagram is not correct for a 68 or a 69. The front turn indicators in a 68 and 69 (in the US) has one bulb in it - not two as shown on the diagram. It's not 'just the shape' - they're showing the 70+ front indicator housing and the 70+ rear tail lamp housing which has the reverse lights integrated into the housing vs. two separate lights mounted to the rear bumper.
If you can't tell the difference - look at an earlier wiring diagram - the early front indicator housings have one bulb, not two.
That's only three examples of why this diagram is incorrect - there are many more if you know what to look for...
Bobnotch
Bobnotch is offline
PostPosted: Sat Apr 24, 2021 10:36 am    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
According to Tram, the ISP main wiring harness is close enough to being correct. I'll trust Tram on that one, as I haven't used an ISP harness yet.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Sat Apr 24, 2021 10:53 am    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
yep, as soon as you posed that I looked and son of a bitch it's not quite correct. but fairly close...
OP what exactly do you have questions on, we can help you out
iamnotatwork
PostPosted: Sat Apr 24, 2021 3:43 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
I am putting together a list of discrepancies in the diagrams. Will be back soon.
Thanks all
1967 Bug "Giblet"
iamnotatwork
PostPosted: Thu Apr 29, 2021 12:23 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
A few examples...
Here are the different wiring diagrams:
In this ISP West diagram, how do I get power to the door switch when both are brown grounds? Also, the dome light red power seems to disappear within the loom (according to this diagram).
Here, what are the pinouts?
Who here has used an ISP loom with a 68 or 69 restoration? What schematic did you use? There are many more discrepancies...
1967 Bug "Giblet"
KTPhil is offline
PostPosted: Thu Apr 29, 2021 1:46 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
iamnotatwork wrote:
A few examples...
The door switches do not carry "power" (positive voltage). They make the lamp work by providing ground. The switch is grounded, and when the door opens, that brown wire is connected to ground. They are brown because of this, by convention.
iamnotatwork
PostPosted: Thu Apr 29, 2021 2:46 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
I understand that they are just an interrupt but I don't get where power is coming from...
1967 Bug "Giblet"
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 29, 2021 2:58 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
Power for the dome light comes from the red wire (from the fuse box) that runs up the "A" post to the light. Yes, the switch is just interrupting ground.
Tram wrote:
Tram wrote:
iamnotatwork
PostPosted: Thu Apr 29, 2021 3:09 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
We can figure out the stupid light... we are really struggling with the entire schematic under the dash.
Of the schematics out there, which do you guys use to wire up a 69? Of the schematics posted, the physical wiring does not match parts of the schematics because it shows 1970 - not a 68-69 proper.
How about that emergency flasher relay? Does anyone know the pins? The schematic that shows the actual pins numbers is for a 70 so the wires differ... That problem exists with all the relays and switches.
As far as I can tell, there is no 68-69 schematic... I have 68, 69, 70, 71, and 72 cars here. The 68-69's are different from the 70-72.
I appreciate the help!
1967 Bug "Giblet"
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 29, 2021 3:16 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
The big problem with the 4 way flasher, is that there's 2 types to work from. Simple switch, complex relay. And complex switch, simple relay. Do a search of the forum, as it's been broken down for ease of use.
Just to throw a monkey wrench into things, my 65 Notch has a 71 wiring harness in it, and is wired up like a 70/71.
Tram wrote:
Tram wrote:
iamnotatwork
PostPosted: Thu Apr 29, 2021 3:19 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
I did not know this - thank you very much Bob!
1967 Bug "Giblet"
KTPhil is offline
PostPosted: Thu Apr 29, 2021 3:34 pm    Post subject: Re: 69 wiring diagram - 67+ isn't correct Reply with quote
This is from Autobook's Type 3 Owners Workshop Manual. Not color, and it's for European models (might be more confusing due to USA differences), but it is listed as applicable to the '69 model year.
