Getting a Type 4 engine to start after 10 years
Page: Previous  1, 2
Abscate Premium Member
Abscate is offline
PostPosted: Sat Apr 24, 2021 3:23 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
Mice less important. More important to get fresh gas in, old gas out, and. Getting the oil water slurry out of the crankcase before starting.
It’s not going to run well, that carb will be completely gunked up.
The price on turning the key to “ see if it will start” could be 4-8k , otherwise
.ssS!
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Sat Apr 24, 2021 5:06 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
You will smell the mouse nesting if and when your engine starts, it’s a foul burnt mulch/hot urine smell. It kind of smells like money burning.
I Corinthians 4
I actually drive my bus and single cab. They run and drive great, and I maintain them myself. I don't merely own type IIs, I travel all over in them. Really, check my instagram link or gallery.
‘71 Westy rag top, ‘69 single cab Both driven daily
60vwnewengland
Twin #2
60vwnewengland is offline
PostPosted: Sat Apr 24, 2021 7:28 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
The above is true. Drain the gas tank, new fuel lines, and new fuel filter.
If you have extra time, maybe pour 2-3 gallons of diesel in the fuel tank, rock the bus back and forth and then, drain the gas tank to remove any rusty bits. Then pour new 2-5 gals of gas in the tank, rinse and repeat with gas. The goal here is to see if the tank is rusty and clear any nasty rust outta the tank. You'll find out real quick if the tank is blocked.
77 Westy - Cape Cod Sage
14 Dieselgate Jetta Wagon
LLAP
Wildthings
Wildthings is offline
PostPosted: Sat Apr 24, 2021 9:50 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
If the tank has been sitting with a load of ethanol laced fuel in it, its going to take more than swishing the tank out with fresh fuel to make it serviceable. The tank likely has a layer of goo inside that will slowly dissolve and move through the fuel system clogging jets and causing sticky valves for tens of thousands of miles to come if it is not remove somehow before the rig is put back into service.
If he wants to run it as is, the OP should buy a half dozen cases of Tectron "Ethanol" fuel system cleaner and enough cheap synthetic oil to add a pint at every fill up for the next 50K miles to keep the valves from sticking and having negative interactions with the pistons, and of course make sure he keeps his AAA towing insurance paid up.
Jason0115
Jason0115 is offline
PostPosted: Wed Apr 28, 2021 6:21 pm    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
Rider_Surfboards wrote:
Whereabouts in NJ are you located?
Hunterdon county, how about you?
Jason0115
PostPosted: Wed Apr 28, 2021 6:22 pm    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
60vwnewengland wrote:
Pictures of OP engine
No engine bay seal, probably disintegrated over the 10 years. Center mount carb with some FI components still in engine bay. But based on these two photos, I wouldn’t turn the key to try and run it.
t
Is their any FI components that are missing which you can notice?
alman72
alman72 is offline
PostPosted: Wed Apr 28, 2021 6:27 pm    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
t
I notice that it has a single progressive.....good news is he wont have to worry about vac leaks and cracks in S boot. edit-but you knew that...
Rider_Surfboards
Rider_Surfboards is offline
PostPosted: Thu Apr 29, 2021 5:11 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
I am in Monmouth County. I saw from your other thread that you may be passing up this bus and continuing your search for another—probably not a bad idea.
If/when you come across a good project, I may be able to come up and help you see what’s what. Shoot me a PM when that time comes.
I’ve had lots of help from the community on my own VW journey, and its been one of my favorite parts of owning one of these vehicles. I will be glad to repay the favor if I can.
— Kevin
1979 Bus Weekender -- Gertrude McBus
Jason0115
PostPosted: Sat May 01, 2021 8:14 am    Post subject: Re: Getting a Type 4 engine to start after 10 years Reply with quote
I appreciate that Kevin, I'll give you a pm if I find something nearby. I'm trying to get the word out and network around. Hope I come across a good deal soon. It has been a warm welcome from the community.
I'm thinking of getting the bus in the photos for parts. Fiddle with engine learn on it since I wont be driving it. Plus, it has all the interior camping gear minus some of the fabric and the shot front seats. All for hopefully under 750.
Page: Previous  1, 2
Page 2 of 2
