markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Sun May 02, 2021 2:10 pm Post subject: 1966 dash knobs (photos included) |
Saw a couple of good threads that almost answered what I needed. I wanted to make sure I order the correct items.
I'm assuming wiper and headlights, but need to be certain.
What is the hole for just to the left of the hazard?
What are the two holes I point too: one on the steering column and the one to the left on the dash?
As always, thanks for your help !!!
-Mark
EverettB Administrator
Joined: April 11, 2000 Posts: 69825 Location: Phoenix Metro
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun May 02, 2021 2:31 pm Post subject: Re: 1966 dash knobs (photos included) |
That ^^^^^ looks like a '67 flasher switch, not a '66. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sun May 02, 2021 2:40 pm Post subject: Re: 1966 dash knobs (photos included) |
Thank you again Everett.
crukab ... that is what came with it when I bought. My electrical friend is coming over this week to help me do some final wring. If we can make that work, great. Otherwise I'll need to search classifieds to get one. |
crukab Samba Chef
Posted: Sun May 02, 2021 2:46 pm Post subject: Re: 1966 dash knobs (photos included) |
That is from my '66 ^^^^^^^^
Things do get changed out over 50+ years, but look at the slots in your dash compared to mine, '67 has a wider radio hole, maybe yours is a '67 ?? _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
Posted: Sun May 02, 2021 3:11 pm Post subject: Re: 1966 dash knobs (photos included) |
Tom... I took it out to look. Yes, the hole is smaller. And on top of the dash on the back side, it has a small "dimple" that allows the knob box to sort of set around the dimple to sort of seat it.
Not sure if a 66 or 67, but fits snug. I'll know this week when we hook up... assuming it still works ha-ha.
Thanks
-Mark
c21darrel Samba Member
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Mon May 03, 2021 12:43 pm Post subject: Re: 1966 dash knobs (photos included) |
markeaton wrote: |
your bus is a 1967 model. check your vin number. the 3rd digit should be 7. as to your electrical friend coming over. please please print out a color wiring diagram for your bus that is located in the Technical section on this page. the color wiring diagrams are an awesome tool to have when working on the wiring on your bus. ive seen many people butcher the wiring because they did not follow the diagram. _________________ Missouri Micros |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon May 03, 2021 1:11 pm Post subject: Re: 1966 dash knobs (photos included) |
66-67 have a slightly more complicated wiring system than -65 so I agree that a printed out color wiring diagram from this site will be an asset along with the correct parts like a 9 pin relay, hi/lo relay, and a 66-67 turn signal switch.
Your dash does appear to be a 67 dash and the knob is correct for a '67. Also, the 67 emergency flasher knob has a larger shaft than the 66 if I remember correctly. In other words, a 66 knob will "fit" in a 67 switch (although sloppy) but a 67 knob will not fit in a 66 switch. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue May 04, 2021 4:39 am Post subject: Re: 1966 dash knobs (photos included) |
Widehatch... the third number on my vin is a "6" ... And yes, good idea on a color diagram... thank you
Okie - maybe they switched out the dash? I don;t know, but the vin plate and my title are both 1966. |
Posted: Tue May 04, 2021 5:12 am Post subject: Re: 1966 dash knobs (photos included) |
I'm not doubting or disputing your VIN number but I looked through your gallery and it looks like your bus has reverse lights which are a later 67 feature but could have been added or optioned of course. Also, your rear hatch looks like a 67 in the one photo I can see it in. Just curious, does your gas door have a church key hole or is it spring loaded with a finger pull? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue May 04, 2021 5:25 am Post subject: Re: 1966 dash knobs (photos included) |
The gas cover has a church key. Is that a 66 or 67 feature? |
Posted: Tue May 04, 2021 5:56 am Post subject: Re: 1966 dash knobs (photos included) |
markeaton wrote: |
strange. since your doors are different its possible that your bus could of been wrecked in the past and had a front clip replaced at one time. your radio hole is the 67 style. id start looking under the dash and under the bus for any evidence of metal being replaced. i would also check all 3 vin numbers and make sure they all match. _________________ Missouri Micros |
Posted: Tue May 04, 2021 6:07 am Post subject: Re: 1966 dash knobs (photos included) |
widehatch... good suggestion... plus I might ask the PO if he is aware of anything. |
Posted: Tue May 04, 2021 6:18 am Post subject: Re: 1966 dash knobs (photos included) |
markeaton wrote: |
66 is the last year of the church key gas door.
Can you confirm, is there a relief in the metal under the hatch and above decklid for you to pull the hatch open? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue May 04, 2021 6:22 am Post subject: Re: 1966 dash knobs (photos included) |
Okie... I am not sure what that is. Do you have a pic? |
Posted: Tue May 04, 2021 6:58 am Post subject: Re: 1966 dash knobs (photos included) |
FYI a 67 gas door will look like this
Posted: Tue May 04, 2021 7:01 am Post subject: Re: 1966 dash knobs (photos included) |
markeaton wrote: |
this is what Okie is talking about
Posted: Tue May 04, 2021 7:41 am Post subject: Re: 1966 dash knobs (photos included) |
My gas cover is not that one. It has a hole with the church key mechanism in it.
Below is a pic I had on my phone photos. Not sure if you can see it good.
I actually have new button on order from WW.
Posted: Tue May 04, 2021 7:46 am Post subject: Re: 1966 dash knobs (photos included) |
Thanks for the pic, widehatch.
Interesting, markeaton your bus looks to have the 67 rear hatch and decklid hinge carrier section. The image widehatch posted above is the 64-66 style with the relief and round push button release. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
