Type IV Manual
theguyryry
theguyryry is offline
PostPosted: Mon Apr 12, 2021 7:15 am    Post subject: Type IV Manual Reply with quote
Does anyone have recommendations on books, manuals, or other reading specifically for a type 4 engine?
busdaddy
busdaddy is offline
PostPosted: Mon Apr 12, 2021 8:03 am    Post subject: Re: Type IV Manual Reply with quote
Abscate Premium Member
Abscate is offline
PostPosted: Mon Apr 12, 2021 8:05 am    Post subject: Re: Type IV Manual Reply with quote
Tom Wilson ISBN 978-0-89586-225-9
Ray Greenwood posts bookmark
Microscope to read his secret instructions in the ellipses
You have access to all that is known about the Type 4 motor, and more.
.ssS!
theguyryry
PostPosted: Mon Apr 12, 2021 8:40 am    Post subject: Re: Type IV Manual Reply with quote
Sweet! I saw both of those on Amazon... I'll get those ordered. Any recommendations for a basic toolkit?
crownline
crownline is offline
PostPosted: Mon Apr 12, 2021 9:04 am    Post subject: Re: Type IV Manual Reply with quote
At least 4 10mm sockets and wrenches. Just a good metric tool set. Feeler gauges bandaid for knuckles. Beer. Dictionary so you can look up the definition of new cuss words you will using. Cool Did I mention Beer?
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
mikedjames
mikedjames is offline
PostPosted: Mon Apr 12, 2021 1:01 pm    Post subject: Re: Type IV Manual Reply with quote
For some reason I have 4 hammers in the tool kit I take with me in my bus from half pound to 2lb heads, one nylon headed.
Metric socket set 1/2" drive, set of metric combination spanners.
1/2" drive hex driver set for door hinges, sliding door bottom roller..
Cross head and flat blade screwdrivers. Adjustable spanners, 6" and 12" handle.
Vice grips.
Side cutters, pliers. Feeler gauge set.
12 volt test light at least, digital multimeter.
A jack for tyre changes.
(In fact I carry all tools needed to remove and replace the engine except for some way of lowering the engine . About 50% of the space under the rear seat is tools )
Ancient vehicles and vessels
1974 VW T2 : Devon Eurovette camper with 1641 DP T1 engine, Progressive carb, full flow oil cooler
Engine 1: 40k miles (rocker shaft clip fell off), Engine 2: 30k miles (rebuild, dropped valve). Engine 3: a JK Preservation Parts "new" engine: 16k miles to date.
raygreenwood
raygreenwood is offline
PostPosted: Mon Apr 12, 2021 1:08 pm    Post subject: Re: Type IV Manual Reply with quote
Laughing ....I have some good recommendations for affordable microscopes if you need one!
Ray
timvw7476
timvw7476 is offline
PostPosted: Mon Apr 12, 2021 2:53 pm    Post subject: Re: Type IV Manual Reply with quote
Powercraft sparkplug socket, it's magnetic.
Also a magnetic tool, to fish all the old sparkplugs out of the engine tin work .
Magnetic retrievers are important. When it comes to Type IV.
You'll understand after the first three minute encounter.
Wildthings
Wildthings is offline
PostPosted: Mon Apr 12, 2021 3:38 pm    Post subject: Re: Type IV Manual Reply with quote
Here is a list of tools and supplies I had with me on a three month trip to Mexico a decade plus back. I had to do an engine pull during the trip when an oil galley plug blew and the only tool I had to borrow was a torque wrench for the flywheel bolts. All the tools and some of the supplies fit into a smallish (1 cu. ft.) tool box.
Tube high temperature silicone
JB Weld
Tube anti-seize
Tube Loctite
Roll plastic electrical tape
Remnant of a roll of rubber electrical tape
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2" Tape measure
Jumper cables
Brake fluid
Motor oil
1/2 drive sockets 15mm-22mm
1/2 breaker bar and extensions
3/8 socket set regular and deep
3/8 spark plug socket
3/8 ratchet and breaker bar, plus extensions
Metric allen wrench set
17mm tool for tranny fill and drain
Feeler guage and spark plug wire gauge set
12 point adapter for CV joint bolts, long
Hex adapter for CV joint bolts, long
Screwdrivers:
3/8 flat, long
#3 phillips
Replaceable tip #1, #2, 3/16, 5/16
Replaceable tip, jewelers
Radiator hose tool
Small rattail file
Half round file
Crescent wrenches, 4", 6", 12"
10 x 11mm tubing wrench for brake lines
8mm - 22 mm combination wrench set
6mm - 19 mm box end set
3/8 - 5/8 English combination set
VOM meter
Wiring multi-tool with misc asst of wire terminals
Diagonal cutters
Snap ring pliers, two styles
Channel-locks 10"
2# ball peen hammer
Vise Grips, large and small
Battery drill, with bits 1/16 - 1/4"
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two
my59
my59 is offline
PostPosted: Mon Apr 12, 2021 3:41 pm    Post subject: Re: Type IV Manual Reply with quote
When I redid the bus engine, I went through the Wilson book and underlined the type 4 specifics to make sure I could double check what I was doing accurately.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '95 Benz E300D, 77 Benz 300D, '02 Jetta TDI with a 3" lift.
busdaddy
busdaddy is offline
PostPosted: Mon Apr 12, 2021 3:47 pm    Post subject: Re: Type IV Manual Reply with quote
I can't find it right now, but there's a thread on the errors in the Bentley as well as one on Wilson's. Many don't matter much, but some, like that overtorque on the rocker stands in Wilson's will change your weekend. His distributor drive instructions are a big challenging as well.
my59
my59 is offline
PostPosted: Mon Apr 12, 2021 4:05 pm    Post subject: Re: Type IV Manual Reply with quote
Thats what notes in the margins are all about! Things like adding in the torque values where you need them so you aren't flipping pages around smearing greasy crap on the manual or typing on the phone looking for info while wedged underneath the bus with the manual propped open next to you lying on an unheated barn floor in the dead of winter with that inner voice saying WTF were you thinking?
theguyryry
PostPosted: Tue Apr 13, 2021 2:12 pm    Post subject: Re: Type IV Manual Reply with quote
I went ahead and ordered the following:
- How to Rebuild Your Volkswagen air-Cooled Engine (All models, 1961 and up)
- How to Keep Your Volkswagen Alive: A Manual of Step-by-Step Procedures for the Compleat Idiot
The bus I'm going to look at next comes with the Bentley manual, so I'm going to hold off on that one for now. I was looking for online reading to keep me busy while I wait for those to ship, and stumbled across ratwell's website again ( https://www.ratwell.com/technical/FAQ/FAQContent.html ). This should keep me busy for awhile.
busdaddy
busdaddy is offline
PostPosted: Tue Apr 13, 2021 2:47 pm    Post subject: Re: Type IV Manual Reply with quote
That'll do fine, consider the idiot book as a last resort if nothing makes sense in any of the other books, it's fun and entertaining, and good for a noob to get their head around basic procedures, but it's written at a time when junkyards were full of good German parts and it wasn't a big deal if you broke something.
Zeta
Zeta is offline
PostPosted: Tue Apr 13, 2021 3:24 pm    Post subject: Re: Type IV Manual Reply with quote
Great idea!
Thank you.
1974 Westy
1800 cc Type4 Engine
Single Weber Carb
Zeta
Zeta is offline
PostPosted: Tue Apr 13, 2021 3:36 pm    Post subject: Re: Type IV Manual Reply with quote
I am certainly a noob, and yes, this book allows me to grab the concepts and overall layout of the game plan. As a noob, this book has helped me greatly, and yes, it is a good read too. I do have the Bently as well which is used after reviewing overall plan from Muir's book.
Based on this thread, I purchased Wilson's book even if I am not doing an overhaul when I drop my engine. I am not knowledgeable enough to embark on this task. But, I realized these reading materials will require several reads.
The same happened when I started reading the Itinerant's thread on converting back to Solex (The Goose:... https://itinerant-air-cooled.com/viewtopic.php?t=13619 )
At first, wow I was lost and multiple times I thought "this is out of my league" but by page 4, I was able to follow a few things, and by the end I certainly knew more than at the beginning.
These forums are invaluable! Thank you Samba (and contributors)!
1974 Westy
Single Weber Carb
mfemenel
mfemenel is offline
PostPosted: Mon May 03, 2021 1:43 am    Post subject: Re: Type IV Manual Reply with quote
I just realized a weakness in my tool kit this weekend. On my 79 westy, it's a 6 mm allen head to get the alternator loose. Throw one of those in your bus along with a long sturdy screw driver, or pry bar. I had a piece of scrap angle iron that worked. If your belt goes you're not changing it on the side of the road if you can't get the altnernator bolt backed off.
'79 Westy FI/AC/Auto
'78 Tin Top FI/Manual
'71/68 Ghia Coupe Project - FOR SALE!
Takamotti
Takamotti is offline
PostPosted: Mon May 03, 2021 4:09 am    Post subject: Re: Type IV Manual Reply with quote
or you can get it online straight from VW... Most type 4 related manuals are in German but at a quick glance it seems at least 2.0 L-Jetronic manual is available in English
https://erwin.volkswagen.de/erwin/showHome.do
alman72
alman72 is offline
PostPosted: Mon May 03, 2021 5:06 am    Post subject: Re: Type IV Manual Reply with quote
funny not/funny, but an actual owners manual for the year of vehicle you are interested in. Besides the engine, lots of little tidbits of knowledge. You see it on the samba quite frequently. "the answer is in your manual!"
i dont even think you have to buy one. they may be in the tech section .
Wasted youth
Wasted youth is offline
PostPosted: Fri May 07, 2021 7:25 am    Post subject: Re: Type IV Manual Reply with quote
I have found on several occasions the 1980-1982 years covered in the Vanagon Bentley manual to have updated and important information regarding the air-cooled Type 4 engine.
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
