"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... 165, 166, 167 ... 172, 173, 174  Next
S4VAGE
S4VAGE is offline
PostPosted: Mon May 03, 2021 10:52 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
campism wrote:
1988M5 wrote:
CLK FS (not mine) FYI
https://sfbay.craigslist.org/eby/wto/d/sacramento-mercedes-benz-clk-w208-clk/7289074601.html
$800 is pretty steep for wheels that need to be refinished.
"Scratches, pitting, curb rash, face gouging, tire machine mounting marks, paint fade, tire bead residue, clear coat aging all present."
Agree. $800 should get you pretty nice ones. I just got really nice, but not perfect ones for $850 shipped. I think these are more like 400-500, but the market is nuts on everything so maybe I am out of touch.
Bloomquist
Bloomquist is offline
PostPosted: Thu May 13, 2021 4:25 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Does anyone know what these steelies are?
They look a bit bigger and I notice opposite the valve hole two of the oblong holes are actually round. Somewhat unique so was wondering if anyone has seen or can recognize that wheel?
Thanks for the help!
Crankey
Crankey is online now
PostPosted: Thu May 13, 2021 9:51 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Yeah me too and where can I get a pair banded to 9" wide ?
Crankey
PostPosted: Thu May 13, 2021 11:02 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thought maybe same as these without caps ? But maybe not..
ET on spares can be large enough to use adapter so it's real possible it's not a 5x112 wheel. There's a few that look close on ebay searching 18 inch steel wheel. Didn't see an exact match though.
campism
campism is offline
PostPosted: Fri May 14, 2021 4:52 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
New Beetle (and successor) Turbo wheels, maybe?
'87 Westy in Wolfram Grey Metallic
S4VAGE
S4VAGE is offline
PostPosted: Thu May 20, 2021 3:06 pm    Post subject: Reply with quote
[/quote]
I get a lot of DMs asking me for more details on these rims, so I thought I would just post the FAQs..
a) the horrible sparco logo is a sticker, it comes off with a little heat
b) tire rack has these go in and out of stock in multiple colors all the time
c) if you want to find them, search for wheel fitment for a 1998 Mercedes CLK320
d) The weight rating is stamped on the inside of the rim... wheel rating is 675kg.= I run them on my tintop, I would NOT run them on my westy.
e) Dokatodd was my insperation. I put mine on in 2014 so I guess I have had them for 7 years with no issues.
f) wheel spacers... you only need a 3mm to make the front clear, but if I was to do it again I would go just a little larger and then the caps that come with these rims will fit front and back. The caps come with a domed "S" logo that can be removed with a heat gun. I don't recall what back spacer size was... it was whatever Chris at T3 told me to buy.
g) just buy what Chris tells you to buy
h) I have since moved to BFG’s. I like them better.
Cheers
Crankey
PostPosted: Thu May 20, 2021 3:45 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I want a like button @S4VAGE those are cool.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat May 22, 2021 4:16 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Has anyone been able to buy 16" steel rims lately? They seem to have all dried up out there in the vanishing global supply chain.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Zeitgeist 13
PostPosted: Sun May 23, 2021 6:10 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Based on the deafening crickets, it's obvious you wanted me to work harder for the info. We found some in Germany, so FO.
Casey--
y u rune klassik?
S4VAGE
S4VAGE is offline
PostPosted: Mon May 24, 2021 8:23 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
I miss this place Laughing -- Hi Zeitgeist. You going to DOB?
Zeitgeist 13
PostPosted: Tue May 25, 2021 9:50 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
The organizers have wisely chosen to preemptively ban me from attending. My disruptive reputation precedes me wherever I go.
Casey--
y u rune klassik?
tjet Premium Member
tjet is offline
PostPosted: Fri Jun 18, 2021 2:44 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Not exactly what you're looking for, but close. And they build custom sizes..
https://www.corsasteelies.com/wheels
Ian
Ian is offline
PostPosted: Fri Jun 18, 2021 5:08 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Front GoWesty Springs
Rear Syncro Springs
Bilsteins all around (2wd rears)
Junkyard Mercedes wheels ET51 with 25mm spacers and F250 lug studs M14x1.5
Using Baywindow/Vanagon style lug nuts now on all 4
215/70/16 General Grabber tires
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA**
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sat Jun 19, 2021 8:54 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those wheels are very attractive but the 16" wheels are only rated at 1200 lbs.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Last edited by Jake de Villiers on Tue Jun 29, 2021 7:33 am; edited 1 time in total
Crankey
PostPosted: Mon Jun 28, 2021 5:54 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those look like 17" I think...can you identify them ? I can't find any exact match.
I am also wondering if a Mercedes clamp nut vs a vanagon peen nut on the front spindle will factor in to the grease cap fit. With grease cap fit factoring in to center bore and center cap fits with wheels...
Jake de Villiers
PostPosted: Tue Jun 29, 2021 7:35 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Sorry, I have edited my post to express my point more clearly.
The Corsa Wheels are rated at 1200 lbs whether 16" or 17". I don't know what's on that crazy low T3.
www.thebassspa.com
TomInAlaska
TomInAlaska is offline
PostPosted: Thu Jul 15, 2021 10:50 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
https://www.facebook.com/marketplace/item/87240800...619cc97295
These just showed up for sale locally to me. Google tells me that the centerbore should work, but the seller is measuring the centerbore to be sure (they'd be going on a 2wd van). I assume I would need spacers of some to be determined thickness and new bolts/nuts at least. What about weight rating? Would a 2wd weekender type van be too heavy for them?
'73 Super Beetle (resto-mod/rally look, 1776)
'84 GL adventure van project (1.9L, 4speed) https://www.thesamba.com/vw/forum/viewtopic.php?t=755844&highlight=
Jake de Villiers
PostPosted: Thu Jul 15, 2021 1:41 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
You're going to want to know the ET sooner than later. Those look like high ET FWD type wheels from here. Might need a lot of spacer to clear the upper control arm.
They're called 'Assetto Gara' and they're made by 'Sparco.'
The tires are way underrated at 91. You should have at least 97 on a tin top.
www.thebassspa.com
Crankey
PostPosted: Sun Jul 18, 2021 12:50 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Avantgarde for Audi, made by BBS. Fronts bored out to 66.6
17x8
3/16" spacer in front, 1/2" rear. Fronts need the spacer, rears don't really but the look better flushed out with the spacer.
Not something you can find easily, I just ran across them on the vortex. Really wish they were the 18" but at that time I thought 17's were ideal. Now I'd prefer slightly less tire sidewall. But good for winter tires, solid, simple shapes, easy to clean.
Tires 225/55/17.
WestiT3_1986
WestiT3_1986 is offline
PostPosted: Sun Jul 18, 2021 10:38 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
They seem to be 17" Mercedes GLA INfinity G30 rims:
All the data is in the pictures - ET38 6,5x17. Part Nr. A1564000000
66,6mm centre bore.
Problem will be the weight rating- they are only rated at max 590kg.
Page 166 of 174
