1966 dash knobs (photos included)
Page: Previous  1, 2, 3  Next
peecee69 Premium Member
peecee69 is offline
PostPosted: Tue May 04, 2021 7:48 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
There are some wonky things going on with your bus. Definitely a mix of '66 and '67 features.
1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight=
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
widehatch
widehatch is offline
PostPosted: Tue May 04, 2021 7:53 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
that looks like 67 to me. everything about your bus screams 1967 except for the vin and gas door. can you verify the stamped vin in the engine compartment is the same as the vin tag and m-code plate in the cab (m-code tag is behind pass seat). can you take a picture of the hole for the hatch button and the gas door when you get a chance.
Missouri Micros
markeaton Premium Member
markeaton is offline
PostPosted: Tue May 04, 2021 8:11 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
peecee69... I agree now that this is all coming up on this thread.. I wonder (as I suppose it is not rare), that during ownership of however many PO's, parts are hard to find; parts are hard to fix; new parts are ordered to replace, etc. etc. and thus the mix.
I do not have the tag on the seat. It is actually affixed on the pass side of the air intake next to ceiling (see pic below). I did look in engine compartment before but could not find it.
I have a pic below of the back side of the latch.
widehatch
PostPosted: Tue May 04, 2021 9:02 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
the m-code tag should be located on the wall behind the passenger backrest.
pic for example
the vin in the engine compartment is a stamping on the passenger side where the apron meets the engine shelf in front of the battery.
pic for example
Missouri Micros
widehatch
PostPosted: Tue May 04, 2021 9:13 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
thats a 67 hatch. the 66 push buttom will not work with that hatch.
Missouri Micros
PostPosted: Tue May 04, 2021 10:05 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
widehatch... yes, the M plate "was" there on the pass seat, as left by an imprint... the rivet holes are still there... and they replaced the apron with a new one.
Crap, I'll need to call WW to get another latch.
peecee69 is offline
PostPosted: Tue May 04, 2021 10:09 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
The VIN isn't on the apron, but right next to it. The purpose of it is to have a VIN stamped into a difficult to change body part.
PostPosted: Tue May 04, 2021 10:11 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Gotcha... I'll check with a better light and my reading glasses tonight Smile
widehatch
PostPosted: Fri May 07, 2021 5:41 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
did you ever locate the stamped vin number in the engine compartment?
Missouri Micros
PostPosted: Fri May 07, 2021 6:04 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
I did not... I looked an looked.... Might it be under the new apron?
Okie Adam
Okie Adam is offline
PostPosted: Fri May 07, 2021 6:24 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
widehatch wrote:
Shouldn't be under the apron. In this pic the rusted area is what the apron covers. The vin should be right above the edge of the apron.
Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
PostPosted: Fri May 07, 2021 6:37 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Is it under my finger?
Okie Adam
PostPosted: Fri May 07, 2021 6:54 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Other side, above the edge with the screw through it.
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
Okie Adam
PostPosted: Fri May 07, 2021 6:55 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
The diagonal edge of the apron, that is
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
PostPosted: Fri May 07, 2021 7:14 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Oh boy.... I found it. Not good. Third digit a "7".
peecee69 is offline
PostPosted: Fri May 07, 2021 8:09 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
That is your actual VIN. Time to send off for a birth certificate to figure out what it used to be.
Then ignore most of it, repair what needs repairing, drive it, and enjoy it.
ToolBox
ToolBox is offline
PostPosted: Fri May 07, 2021 8:45 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Might want to run the VIN through NICB's VINCheck to see if it is hot. Would suck to put a ton of cash into it if it is on the hot sheet.
https://www.nicb.org/vincheck
PostPosted: Fri May 07, 2021 8:49 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Checked out as not stolen.
I'm thinking more that it used parts of a 66 and 67.
Clara Premium Member
Clara is offline
PostPosted: Fri May 07, 2021 10:11 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
as in 'someone put a air vent tag from a 66 on a 67'.
PostPosted: Fri May 07, 2021 11:06 am    Post subject: Re: 1966 dash knobs (photos included) Reply with quote
Sure seems that way.... I need to contact the PO to let him know too.
Page 2 of 3
