dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue May 04, 2021 10:13 am Post subject: Re: Official lazy person's stupid question thread |
My bipap, Resmed, is 24vdc native. At home a power brick supplies the 24vdc. In the van a different brick converts to the 24vdc required. Because of the higher pressure setting mine draws nearly 48 watts when using a 12vdc source and only slightly less when connected to a 24vdc source. With my model a brick is always required regardless.
Just a FYI data point _________________ Schau in das Buch |
4Gears4Tires Samba Member
Posted: Tue May 04, 2021 12:26 pm Post subject: Re: Official lazy person's stupid question thread |
You can get power out of bricks? I have a few thousand in my yard, how much power can I get? _________________ '87 Syncro
Posted: Tue May 04, 2021 5:51 pm Post subject: Re: Official lazy person's stupid question thread |
They must be vintage. 18th century for 12vdc and 17th century for 110vac.. Metric voltages are different.
Powerbricks the big brother to wallwarts. _________________ Schau in das Buch |
DuncanS Samba Member
Posted: Wed May 05, 2021 4:52 am Post subject: Re: Official lazy person's stupid question thread |
Since we're getting a bit crazy here--well ALL T3 owners are crazy at some level, I have to ask. If a brick can power a cpap, can my friend recharge his Tesla by plugging into a cement block, and if so, does anyone know where he get the adaptor? |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Wed May 05, 2021 4:57 am Post subject: Re: Official lazy person's stupid question thread |
"There is no adapter. Teslas receive the power through direct contact. Induction, if you like. To get a good connection, we recommend the application of said block from an elevation of at least a meter."
"Wait, elevation?"
"...of a meter or more, yes." _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed May 05, 2021 8:33 am Post subject: Re: Official lazy person's stupid question thread |
Team WorldTour wrote: |
"Wait, elevation?"
"...of a meter or more, yes." |
LOL! You're on fire this morning!! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Wed May 05, 2021 8:47 am Post subject: Re: Official lazy person's stupid question thread |
An elevation for what? Dropping it on my brain to cure my T3 disease? A meter sound iffy, I'd go for at least 40". |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed May 05, 2021 12:15 pm Post subject: Re: Official lazy person's stupid question thread |
DuncanS wrote: |
And that is how we will get the first T3 to Mars! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed May 05, 2021 12:52 pm Post subject: Re: Official lazy person's stupid question thread |
Turns out Syncros really can go everywhere and were already spotted on the surface of Mars.
Posted: Wed May 05, 2021 1:19 pm Post subject: Re: Official lazy person's stupid question thread |
Suspension Springs Paint?
I'm finally getting a new set, well new to me, and wonder if there is a special kind of paint that suspension springs require, as they are, well, springing.. ?? _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed May 05, 2021 3:16 pm Post subject: Re: Official lazy person's stupid question thread |
I was curious and did a bit of internet searching. I found this. http://www.secondchancegarage.com/feature-articles/coil-springs-1.cfm I am also curious to know anyone's first hand experience. _________________ '87 Syncro
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed May 05, 2021 5:57 pm Post subject: Re: Official lazy person's stupid question thread |
CPAP content:
For maybe a dozen year pre-van, the family used to rent a remote off-grid cabin for a week getaway every
summer. I'd run my Philips CPAP rig using the dedicated 12v cord ($30 option) and a used car battery...
At only ~2amp draw, I never got close to draining that sucker. Little to worry about here...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Wed May 05, 2021 6:06 pm Post subject: Re: Official lazy person's stupid question thread |
The power draw will be nearly independent of the voltage, 24 orv12 V. The current will vary of course. _________________ .ssS! |
howler9 Samba Member
Joined: April 12, 2012 Posts: 30 Location: United States
Posted: Wed May 05, 2021 8:16 pm Post subject: Re: Official lazy person's stupid question thread |
Speaking of the shore power, how does one wire the shore chargers to the hookup?
Sorry for nother truly lazy question, how do I find the wire of the fridge 12v setup so I can wire to the aux battery's fuse block? Which fuse should I use?
_________________ 1984 1.9L Westy |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Wed May 05, 2021 8:22 pm Post subject: Re: Official lazy person's stupid question thread |
howler9 wrote: |
Speaking of the shore power, how does one wire the shore chargers to the hookup? |
Look under your sink, there's an outlet with your fridge plugged in. Plug the battery charger in there. Easy. Plus it's conveniently close to the driver's seat, where your aux battery probably is. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Thu May 06, 2021 1:24 pm Post subject: Re: Official lazy person's stupid question thread |
Thanks VicVan! How did I not see that? Brilliant.
For the fridge, I found the 12v is one of these red wires but I don't know which?? The other is for the display unit. I want to rewire this 12v wire to my aux battery fuse panel.
Posted: Thu May 06, 2021 3:29 pm Post subject: Re: Official lazy person's stupid question thread |
Something very strange going on here. Do the plugs shown in the photo plug together? If so, the red wire is going to connect to brown. THAT CAN NEVER HAPPPEN. Red is always 12v plus and brown always is ground--thus a direct short. Put your volt meter on these and see what's going on. Pull the fridge fuse and find out if the red wire goes to zero voltage. Both of the red wires are connected together at the plug so it doesn't matter which one is used to tap off. |
VicVan Samba Member
Posted: Thu May 06, 2021 3:31 pm Post subject: Re: Official lazy person's stupid question thread |
The red wire you're looking for goes to the small fusebox at the bottom of the driver's side B-pillar (in other words, on the wall between the driver's seat and the sink). There's two wires there, can't remember which is which. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu May 06, 2021 5:28 pm Post subject: Re: Official lazy person's stupid question thread |
DuncanS wrote: |
Something very strange going on here. Do the plugs shown in the photo plug together? If so, the red wire is going to connect to brown. THAT CAN NEVER HAPPPEN. Red is always 12v plus and brown always is ground--thus a direct short. |
Not true - that brown is the +ve feed to the thermostat that then feeds the cooling fan. The blue is the negative, the black is the +ve feed to the 12V heater via the switch (DC/AC/LP).
_________________ Jim Crowther
Vespa GTS 300 |
fxr Samba Member
Posted: Thu May 06, 2021 5:50 pm Post subject: Re: Official lazy person's stupid question thread |
howler9 wrote: |
The red wire that goes to the brown should be a permanent +12V - same as the sink pump/display panel feed. The red wire that goes to the black should be connected to the fridge relay, so only +12V when the engine is running. Each of those red wires go to their own fuse just behind the driver's seat. It's the feed to the sink (and display panel) that you want to add to the aux battery. Leave the thicker main fridge feed alone. _________________ Jim Crowther
Vespa GTS 300 |
