tunnvar Samba Member
Joined: October 24, 2011 Posts: 261 Location: Austin, Texas
Posted: Tue May 04, 2021 9:11 am Post subject: Dome Light Fuse |
I think I have blown a fuse trying to replace the dome light with an LED light. I can't seem to locate the fuse. Does anybody know where it is? Also, was an LED light a bad idea? Cheers! _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
[url=http://www.vw-mplate.com/mplate2-35638.png]Click to view image[/URL] |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 04, 2021 10:19 am Post subject: Re: Dome Light Fuse |
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 05, 2021 2:46 am Post subject: Re: Dome Light Fuse |
Helps to learn how to read the electrical schematic for your year. Getting a copy of the diaphragm enlarged at a print shop and then laminated isn't a bad idea. This drawing can be found in the Technical Section which shows up towards the top right of every Samba page. Note that the fuse box is reversed.
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Wed May 05, 2021 8:35 am Post subject: Re: Dome Light Fuse |
tunnvar wrote: |
Excellent, will do, thank you both! |
Your bi-line makes no sense to me. |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 383 Location: Huntsville, AL
Posted: Wed May 05, 2021 12:45 pm Post subject: Re: Dome Light Fuse |
I think he means your signature line. A 1970 1600cc would be a Type 1. |
Posted: Wed May 05, 2021 12:48 pm Post subject: Re: Dome Light Fuse |
Did the fuse fix your light? Im curious how that LED bulb works. LEDs have a polarity, and I would imagine its possible to put a bullet type bulb in backwards. |
Posted: Wed May 05, 2021 2:27 pm Post subject: Re: Dome Light Fuse |
Ha. I did that line several years ago trying to sound like I knew what I was talking about. Never even looked at it since.
Yes, the #11 fuse had blown. I have power to the dome light but the new LED ceiling light is being a bit temperamental. Works one minute and not the next. The door feature doesn't seem to work at all I can't seem to figure it out. It's a cheap thing I picked up off amazon so not too worried. _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
Posted: Wed May 05, 2021 3:30 pm Post subject: Re: Dome Light Fuse |
Mberglo wrote: |
That is what I was talking about. If you have a type 4 motor in a 70; Very cool, if you have a type 4 motor that is 1600cc different, if you have a type 4 motor that is not duel port I want one. I see you changed your signature line to type 1. I was hoping you had a type 4 1600cc motor. I think that would be cool. |
