Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Mon May 03, 2021 1:48 pm Post subject: Re: '59 Karmann Ghia fever |
PeteSC wrote: |
I abandoned using my booster switches to power my brake lights altogether and went with this:
https://www.thesamba.com/vw/classifieds/detail.php?id=2140061
I know it's not the 100% stock you're after, but for a car that's driven often I love that I have instant brake lights as soon as I touch the pedal and none of the pressure-activated lag that comes with the booster switch. |
Thanks Pete! But you are right, stock over safety every time. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Posted: Mon May 03, 2021 4:14 pm Post subject: Re: '59 Karmann Ghia fever |
Pulled the main wire harness through today. What a treat.
The shifter boot is on the loose side (and I don’t think cutting it down would help). The wire is tight, just the fit on the tube is suspect. Thinking about some permatex as a remedy.
So this is progress?
Puzzle pieces that arrived while I was away:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
kingkarmann Samba Member
Posted: Tue May 04, 2021 8:03 am Post subject: Re: '59 Karmann Ghia fever |
I've been watching with interest the electrical work your doing.
Although I rewired my Ghia several years ago I still have some non functional items that I've always wanted to address. After seeing you use the DC power supply I decided to go ahead and get one for myself and finally address those issues. Thanks for the ongoing inspiration _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Trylon Samba Member
Posted: Tue May 04, 2021 8:16 am Post subject: Re: '59 Karmann Ghia fever |
Thanks King! That trunk load of loose ends is daunting— I needed some encouragement just about now.
Good luck with your gremlins. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue May 04, 2021 9:19 am Post subject: Re: '59 Karmann Ghia fever |
You should be happy your harness is so minimal compared to late models....I had so many ends to connect it was daunting. I pre labeled every wire end and still faced problems, confusion, while looking at the wire instruction sheet and the wiring schematic. It was like learning another language, like Shakespearian English, took a while to decipher, then when it finally popped into my head, became a 'bit' more understandable! While it looks daunting, continue to address it as you have done all along, from a technical perspective, but with somewhat of a child like curiosity!! At least that worked for me!
Don't give up!!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Trylon Samba Member
Posted: Tue May 04, 2021 9:34 am Post subject: Re: '59 Karmann Ghia fever |
Guess you all detected a bit of anxiety in my last post.
Thanks for the outpouring of support! And to McDonaldneal for the link that I will undoubtedly be referring to many times!
“But I’m not giving in an inch to fear, ‘cause I promised myself this year— I feel like I owe it to someone.” - David Crosby _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
c21darrel Samba Member
Trylon Samba Member
Posted: Tue May 04, 2021 12:04 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
Trylon wrote: |
“But I’m not giving in an inch to fear, ‘cause I promised myself this year— I feel like I owe it to someone.” - David Crosby |
Today is 51 years post Kent State you could have gone with
"Should have been done long ago" CSNY
Perhaps a bit too flippant for such an occasion? No? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Tue May 04, 2021 2:23 pm Post subject: Re: '59 Karmann Ghia fever |
"Should have been done long ago" CSNY |
Or, since Trylon is working on the electrical system (positive electromotive force), "May the Fourth be with you".
Trylon Samba Member
Posted: Tue May 04, 2021 4:23 pm Post subject: Re: '59 Karmann Ghia fever |
Anyway...
When it rains it pours... but in this case in a good way.
After seeing the jeopardy that our sun visors were in, Kev (The Aussie Trimmer) sent two pivot castings suitable for chroming for our car! As if he hasn’t done enough to make our dreams come true— thanks Kev!
And Loren found sun visor hardware that had gone missing:
As this set was already chromed and complete, I have purchased it.
Thanks for all your support Loren!
Got sidetracked today. Noticed that the passenger side vent conduit got moved to the wrong side of the struts. You can just see the red and taped thing in this pic:
Had to remove the vent control to reposition it and saw what a mess it was in so did some clean up on it:
Will show result tomorrow.
‘Course this reminded me about the ducts so I gave one a go:
No go.
Just managed to tear one of the rubber pieces. Will try again another day.
I think this might be considered 1 step back. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb Samba Member
Posted: Tue May 04, 2021 6:13 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
This reminded me about the ducts so I gave one a go:
No go.
I think this might be considered 1 step back. |
Plenty of posts about what a pain these are. I eventually need to put mine in also so I'm hoping you can come up with a good trick to make it easy?
If you put baby powder on the seals, they might be easier to work with? _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Trylon Samba Member
Posted: Tue May 04, 2021 6:29 pm Post subject: Re: '59 Karmann Ghia fever |
I’m thinking baby seals might be easier to deal with. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Tue May 04, 2021 6:41 pm Post subject: Re: '59 Karmann Ghia fever |
Try boiling them and they may become more stretchy...that's a technical term. Slip them on and when they cool, they fit well....We are talking about those little rubber rings yes?
2012 Passat-Sold
Trylon Samba Member
Posted: Tue May 04, 2021 6:43 pm Post subject: Re: '59 Karmann Ghia fever |
At first I thought you were going to make a joke about boiled baby seal.
Will try your actual advice— thanks! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Tue May 04, 2021 6:45 pm Post subject: Re: '59 Karmann Ghia fever |
They're yummy if you haven't tried! If ever in Denmark, and you know the right people........Now if you had some seal oil, that could work too!
2012 Passat-Sold
Trylon Samba Member
Posted: Wed May 05, 2021 4:24 pm Post subject: Re: '59 Karmann Ghia fever |
Tired of trying to determine what size bolt to use, so got this:
Gonna wear it to my next mosh pit experience.
Would you believe that none of them fit the wiper strut nuts?!
M4 too small; M5 too big. Goldilocks wants to know where just right is!
‘Course it’s probably the thread (both of the testers are 1.0).
So had a thought and tried to gently screw in a M5 0.8 tap:
It did seem to work so I am going to try that size.
We will see...
Moving along in the vent arena. I remembered we have new paddles to install so I pulled everything apart:
And reassembled after cleaning:
Waiting for paint to dry on the casing and will reinstall.
When I pulled the vent paddles out, I accidentally unscrewed the ignition switch:
Would you look at that? Screw terminals! Must have decided it would have been a pain to replace the key so they simply attached spades.
And why couldn’t they do that all round?
Anyway, nice that we have the correct switch:
And since the last vestige of working wire is now removed, I pulled the incorrectly installed harness out of the way:
I think it actually does look like progress is being made now:
Wish I had thought to ask Dwayne to remove that unsightly grounding tree.
I don’t think I have the right tool to deal with it? Hack saw good enough? Or do I have to get something more dangerous? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Rome Samba Member
Posted: Wed May 05, 2021 8:44 pm Post subject: Re: '59 Karmann Ghia fever |
psst- isn't that the key code stamped into the side? |
Posted: Thu May 06, 2021 4:01 am Post subject: Re: '59 Karmann Ghia fever |
You want to keep your car all original, why would you hack that grounding tree off? Is it not original? Those grounding points are practically the foundation of your wiring, since as you know, everything must be grounded properly to function. Where are you going to place or replace it? I wouldn't take away such an important part of your system.
2012 Passat-Sold
