Engine Stand
mdevane
mdevane is offline
PostPosted: Thu May 06, 2021 4:44 pm    Post subject: Engine Stand Reply with quote
This might be a stupid question but being new to VW's I'm just looking for some experience. I have a new engine that I will be installing in my 58 and was thinking about building an engine stand so that I could set up the Weber 40idf's before installing the engine in the car. It seems that it would be a lot easier on the stand than in the engine bay. Are there any drawbacks or reasons I can't tune the carbs on the stand? Appreciate you input.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu May 06, 2021 5:00 pm    Post subject: Re: Engine Stand Reply with quote
You.l can run it on the ground.
We have dedicated topics on engine build and run stands, so check them out
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
tattooed_pariah
tattooed_pariah is offline
PostPosted: Thu May 06, 2021 5:37 pm    Post subject: Re: Engine Stand Reply with quote
mdevane wrote:
.... being new to VW's .....
dude.... you joined almost TWENTY years ago... how long before you don't consider yourself new anymore? Shocked Laughing
-pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.)
mdevane
mdevane is offline
PostPosted: Thu May 06, 2021 6:37 pm    Post subject: Re: Engine Stand Reply with quote
New to VW. Had a Porsche 356 when I joined Samba.
67rustavenger
67rustavenger is offline
PostPosted: Thu May 06, 2021 6:42 pm    Post subject: Re: Engine Stand Reply with quote
Run the engine close to the floor. I run mine on a furniture dolly. That way it won't tip over.
Dale M.
Dale M. is offline
PostPosted: Thu May 06, 2021 6:45 pm    Post subject: Re: Engine Stand Reply with quote
A little forum search would tell you there is whole big, long, monster, thread about building a assembly stand and also about a engine run stand....
But basically you can run it on the garage floor if you want... All you really need as a bellhousing or adapter to hold starter and some real simple wiring to power it up... or you can go as complex as you want with reference to what's in engine stand thread...
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Mr. 010
Glenn is offline
PostPosted: Thu May 06, 2021 6:48 pm    Post subject: Re: Engine Stand Reply with quote
Here's the topic: https://www.thesamba.com/vw/forum/viewtopic.php?t=380203
Glenn
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Performance/Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
