Crankey Samba Member
Posted: Fri May 07, 2021 8:20 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
I bought the mustang air box and plan on mounting as Chris Schimke did.
I don't know if I'll use the rubber snorkel in the setup. I think maybe not.
Hopefully I can make the panel template this weekend.
I'm still tempted to fit a trans am fender vent backwards on the side of my doka as an air scoop. |
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Fri May 07, 2021 9:08 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
When I installed my engine the first time , I used the K/N cone in the drivers rear corner of the engine bay and found it to hot and dirty. Solution was a aluminum 45%, a plumbing Gromit and a piece of sheet aluminum. _________________ what a long strange trip it's been |
fleetwood41 Samba Member
Posted: Thu Jul 22, 2021 9:24 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Bumping this thread a little....
Hey Vino!
Do you by chance have the measurements/dimensions of the block-off plate that you fabricated, pictured above?
Great work!
Thanks!
Mick _________________ 1987 2WD w/ 2.5 Subi & Poptop Conversion |
Posted: Sun Jul 25, 2021 10:21 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
I was going to do the mustang air box as Chris Schimke showed.
But the Vanaru kit includes an air box that also fits inside the cubby the same way, so I'm going with all his parts at least to start. I may swap to the mustang parts, I do really like how the band clamp opens it all up to clean the filter. I already bought those parts and made a template to close off the cubby and fit in the mustang housing. |
Posted: Sun Jul 25, 2021 1:44 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Fleetwood41 Sorry I don't have measurements for you, I just used some card stock and cut to fit. I then transferred that to the aluminum sheet and shaped to fit. It was actually pretty easy. I did do it with the engine out though,Good luck. _________________ what a long strange trip it's been |
