Removing paint from wiring
noah2burchell
noah2burchell is offline
PostPosted: Fri May 07, 2021 11:03 am    Post subject: Removing paint from wiring Reply with quote
The PO of my 1972 Super had it repainted, and the wiring in the trunk was painted too. No wiring was painted from the factory, right? What do you recommend to remove this paint without damaging the wire insulation, plastic junctions, and wiring cover? Have you had personal experience using this method?
Thank you all for the help.
Wanted: Anything from Risacher Motors VW dealership in Morristown, Tennessee or Westgate VW in St. Louis Missouri.
Original flat window 1302 Super Beetle
PostPosted: Fri May 07, 2021 1:10 pm    Post subject: Re: Removing paint from wiring Reply with quote
No wiring was painted but that is a common sloppy resto thing where everything gets oversprayed.
Here's another thread I found:
https://www.thesamba.com/vw/forum/viewtopic.php?t=600135
It mostly says Acetone or Paint Thinner
raydog
raydog is offline
PostPosted: Fri May 07, 2021 2:07 pm    Post subject: Re: Removing paint from wiring Reply with quote
you could try acetone or lacquer thinner
Come on, It's not rocket science. KISS
