Primer for difficult to reach spots
andybla
andybla is offline
PostPosted: Sat Apr 10, 2021 5:19 am    Post subject: Primer for difficult to reach spots Reply with quote
Hi, how would one handle when you are sanding before primer/paint but you have some spots where you can’t reach because there is a support bracket over the hard to reach spot.
Do primers exist of some sort that don’t need prepping/sanding that you can just apply after some degreasing? some kind of aggressive “adhesive” between layer?
I saw at my parents house, they are re doing their bathroom and the handy man sprayed some sort of reddish layer onto the smooth tiles to create a base to glue the new tiles onto
bomberbob
bomberbob is offline
PostPosted: Mon Apr 12, 2021 4:45 am    Post subject: Re: Primer for difficult to reach spots Reply with quote
Post a photo of the spots you are trying to reach. Self etching primer might grab onto whatever you are trying to cover, but it at least has to be clean and grease free.
1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Apr 14, 2021 7:35 am    Post subject: Re: Primer for difficult to reach spots Reply with quote
If you can't reach it then you have to spray/air brush gray or red oxide primer & your paint in there.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
andybla
andybla is offline
PostPosted: Thu Apr 15, 2021 12:33 am    Post subject: Re: Primer for difficult to reach spots Reply with quote
Here are some pictures, it is the space between the bracket and the wheel well bit Smile
Danpa
Danpa is offline
PostPosted: Sat May 08, 2021 2:11 am    Post subject: Re: Primer for difficult to reach spots Reply with quote
Would you be able to get in there with a "hose in bucket" sandblaster?
Dan
67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle (current, in pieces)
andybla
andybla is offline
PostPosted: Mon May 17, 2021 11:06 am    Post subject: Re: Primer for difficult to reach spots Reply with quote
in the end i used a por equivalent that we have here, that "eats" itself to the primer and sticks and is also an extra primer on itself after a week of drying
