ELFRIED Samba Member
Posted: Sun Apr 25, 2021 7:03 am Post subject: Brake pedal doesn't return enough |
Certainly no binding between the pedals.
Spring correct mounted,but perhaps faulty???How to check?
Other possible reason?
Any help welcome... |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Sun Apr 25, 2021 2:47 pm Post subject: Re: Brake pedal doesn't return enough |
As long as the you have the correct free play in the pedal and the brakes don’t drag once everything gets hot, don’t worry about it. None of my pedals line up to the other ones but I get full throttle, the car stops and the clutch works great.
I have a new aftermarket pedal assembly which I won’t advertise cause it ain’t worth what they’re selling it for. I’ve seen images of other peoples pedals that line up perfectly though but I don’t think it’s worth the effort.
If you don’t have enough travel for your brakes you may want to adjust the pedal stop bracket on the floor pan and see if that helps. _________________ Volkswagen!
(Compression 8.7:1) |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Apr 27, 2021 7:37 am Post subject: Re: Brake pedal doesn't return enough |
Quote: |
adjust the pedal stop bracket on the floor pan |
yours might be bent or crooked. It's only sheet metal _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Thu Apr 29, 2021 4:07 am Post subject: Re: Brake pedal doesn't return enough |
the spring on mine is really strong, are you sure it's installed correctly?
Posted: Fri Apr 30, 2021 9:03 am Post subject: Re: Brake pedal doesn't return enough |
Yes I am but I really think the spring is too old ,can't see another reason... |
Posted: Fri Apr 30, 2021 9:43 am Post subject: Re: Brake pedal doesn't return enough |
simon varley wrote: |
On the LHD cars the bent tang of the return spring goes over the bolt head that holds the assembly on the tunnel. Do they make a different spring for RHD? _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Sat May 08, 2021 6:12 am Post subject: Re: Brake pedal doesn't return enough |
New spring mounted.
Pedals all nice in line and brake pedal returns immediatly.
Problem solved,thanks all. |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sat May 08, 2021 9:47 am Post subject: Re: Brake pedal doesn't return enough |
runamoc wrote: |
On the LHD cars the bent tang of the return spring goes over the bolt head that holds the assembly on the tunnel. Do they make a different spring for RHD? |
Yes they do. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
