mdross Samba Member
Posted: Sat May 08, 2021 5:03 am Post subject: 74 Super Beetle rear window without defrost wire. |
Does anyone offer new rear window glass without the defrost wire to fit 74 Super Beetle. Good used glass would work. |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sat May 08, 2021 8:18 am Post subject: Re: 74 Super Beetle rear window without defrost wire. |
Cip1 has the glass you are looking for. I am sure there are others too. _________________ Come on, It's not rocket science. KISS |
mdross Samba Member
Posted: Sat May 08, 2021 12:48 pm Post subject: Re: 74 Super Beetle rear window without defrost wire. |
Thank you, Never cared for Kiss ? |
creative native Samba Member
Posted: Sun May 09, 2021 4:07 pm Post subject: Re: 74 Super Beetle rear window without defrost wire. |
I'm on board for this as well. I am a purist and prefer most everything stock, but as long as my rear window defrost doesn't work because of its' age and defrost lines being broken, it seems pointless to leave the window there as is. As long as the rear defrost doesn't work, I'd prefer a clear rear window without the defrost. |
Dark Earth Samba Member
mdross Samba Member
Posted: Mon May 10, 2021 3:48 am Post subject: Re: 74 Super Beetle rear window without defrost wire. |
Exactly this car will never need rear window defrost it does not work anyway no continuity and we just had a new headliner installed. Also never intend to sell this car so the decision was easy. That same thought process is why the next addition will be is a 2332 engine high torque. |
Cornwallav8r Samba Member
Joined: April 26, 2021 Posts: 39 Location: Central PA
Posted: Thu May 13, 2021 6:41 am Post subject: Re: 74 Super Beetle rear window without defrost wire. |
mdross wrote: |
Are you replacing the glass just cause the glass heater stopped working? You know that's easily repaired right? There are a few instructionals out there how to do it, but basically use 12v, apply plus to one terminal end, and probe with the negative probe along each individual wire, as they aren't insulated. Can easily find where the breaks are. They make a conductive silver paint, you just tape off both sides of the trace, clean/degrease the trace and paint. Do it neatly and it shouldn't show much of a repair.
Or just brute force and replace the glass lol
Good luck
Bill K |
mdross Samba Member
Posted: Thu May 13, 2021 7:48 am Post subject: Re: 74 Super Beetle rear window without defrost wire. |
Replacing the glass because the heater does not work and had a new headliner installed. I'm of the belief that if it don't work do not want it on the car. As I said before will never need it anyway. |
