snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Sat May 08, 2021 10:58 am Post subject: Re: Vanagon Bell Housing |
@danfromsyr
I have enjoyed reading your posts about your mum's van; I really like that engine. I have three of those gas 2.5s here. Especially the story about you towing her halfway across the country, or was it the other way around? I forget.
danfromsyr wrote: |
didn't know it would be as much on rotating mass as the explosive impulses of the fuel and cylinder conditions |
Well that is a source of vibrations too, but a different source. It is not that the imbalance forces that we are talking about here are large -- it is that they are forcing a resonant vibration that is present because of the specific combination of engine mass, transaxle mass, and bellhousing stiffness (or lack thereof). There is very little structural damping present in that combination as well, resulting in a high sharpness of resonance (Q). If you are at the right RPM, it does not take much force to set up a large vibration.
The difference with your mum's van is that it is an automatic. It has a much stiffer (thick steel) bellhousing. Essentially that mimics the "fix" that the VW SA engineers came up with, i.e. stiffen the bellhousing.
And the torque convertor will help to damp the impulsive forces that you note above.
RonC |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sat May 08, 2021 11:22 am Post subject: Re: Vanagon Bell Housing |
I started with an OE Diesel Flywheel in my TDI install (clutch would slip)
Then I changed it for a G60 Flywheel from a 1997 Passat
Then I went to a DMF
Both the OE Diesel Flywheel and G60 had rattles at idle
The DMF has been awesome with respect to a quiet idle, smooth shifting, and virtually no resonance out on the road at any speed. In fact, after the DMF install I don't think about resonance anymore.
I sorta doubt a DMF will fit inside a SA bell housing.
Below, DMF on the left, G60 in the center and OE diesel on the right
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat May 08, 2021 11:23 am Post subject: Re: Vanagon Bell Housing |
The problem is in the Audi application, there was a nose mount to limit the belt side of the engine from moving up and down on accel and decel. Unlike a true inline engine, the torque is up and down not side to side. So, the vanagon transmission case is seeing loads it wasn't designed for. The original brace triangulated the bell housing to the case.
I had this problem with my TDI install, but added a torque mount after I had a friend following me. The engine was moving up and down at least an inch. My torque mount was fabricated from VW rabbit parts.
_________________ ☮️ |
Yota-toy Samba Member
Posted: Sat May 08, 2021 12:32 pm Post subject: Re: Vanagon Bell Housing |
Now the real story comes out!!! I am very glad to read about the lack of the 'nose' bushing and the idea that the engine's position is far different from the original could likely be a large part of this problem.
I'm sure it won't be much fun to fab a mount for the front of the eng. in the vanagon engine bay but it will be done prior to any lengthy driving. Most likely even before I start it for the first time.
I wonder what that 'special' destructive rpm is for the I5. Mostly likely the best for torque so it's sitting there all the time! A cummins 6BT can rev up to 7k, but if it hangs at 4100 (specifically) than the engine does actually grenade. I've seen it live at a truck pull and the driver saw the revs hang for a second and tried to shift but too late:(, no amount of winnings will bring that eng. back. Story's like that and the sweet durable 47RE trans are the two biggest reasons my truck does not get abused!!!! It has a power box set at level two (not 5) for pulling hills, not 30k/lb sleds for a $150 purse.
This is all great info.
MarkWard wrote: |
?Waldo? Samba Member
Posted: Sat May 08, 2021 1:11 pm Post subject: Re: Vanagon Bell Housing |
AndyBees wrote: |
I sorta doubt a DMF will fit inside a SA bell housing. |
I doubt there is an input shaft that will fit the SA bell housing and the TDI clutch disc. |
danfromsyr Samba Member
Posted: Sat May 08, 2021 1:14 pm Post subject: Re: Vanagon Bell Housing |
indeed even my I4s could benefit from the nose 'torque' mount.
I get a 'hop' at a given RPM & load.. it's funny it's actually more pronounced with a cold motor.. ie. taking off from my driveway and trying to maintain the ~30mph speed limit of my road. it'll hop the engine some..
my suspect is that the cold run Ign timing creates or compounds the issue.
by the end (1.5mi) of my road it's fine and won't do it easily.. well maybe if I'm lugging it asking for more while going up a given % hill grade @ a given mph.
ie. like a scenic Mtn road (Mount Greylock, MA) or such I can 'trigger' the engine hop..
had it in my 1.8L I4 and my 1.8T I4 too. which have had different engine cradles and mounts..
iirc, there's at least one 4cyl install who put the 'torque' snubber on, but I can't recall whom.
fun fact that in the rear engine inline configuration the engine is actually trying to torque downward. vs Upward in the forward facing longitudinal installations. _________________
Abscate wrote: |
Posted: Sat May 08, 2021 2:51 pm Post subject: Re: Vanagon Bell Housing |
?Waldo? wrote: |
AndyBees wrote: |
A regular Vanagon Clutch Disc can be substituted with the DMF and that's what I did before installing a pilot shaft to accept the TDI disc _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Tue Jun 22, 2021 3:18 am Post subject: Re: Vanagon Bell Housing |
To anyone interested in this shaft from German Transaxle http://www.germantransaxle.com I was told by email that the shaft is no longer available (obsolete) and that the company has no leads on where to locate one.
Contacting Eurospec LA next.
MarkWard wrote: |
No part number for the input shaft, but I searched my email and found this correspondence.
Thank you for the picture Mark,
Yes, we do have this part you are looking for. We are asking $250.00 plus shipping.
Please call 1-800-892-4327 if you would like to place this order.
Thank you,
Kateka
German Transaxle of America. [email protected]
Here is a picture I took comparing the diesel input shaft to the SA one that was shot.
From my notes. Overall measurement is 12.75” |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Tue Jun 22, 2021 4:58 am Post subject: Re: Vanagon Bell Housing |
I think you have been led far astray.
AFAIK, the standard length transmission input shaft is typically used on 5 cyl conversions that use the South African bell housing.
I know both of my vans with 5 cyl conversions used the standard 298mm shaft.
I think the photo of the really long input shaft is for a Mexican 4 cyl bellhousing used on late bay window buses that used the inline 4 watercooled engine.
Mark |
Posted: Tue Jun 22, 2021 5:43 am Post subject: Re: Vanagon Bell Housing |
indeed the mexican bellhousing is definitely deeper than any of the others.
https://www.thesamba.com/vw/forum/viewtopic.php?t=717904 _________________
Abscate wrote: |
Posted: Tue Jun 22, 2021 6:51 am Post subject: Re: Vanagon Bell Housing |
"I know both of my vans with 5 cyl conversions used the standard 298mm shaft.
Can you confirm what clutch configuration you used? I am hoping to keep the flywheel audi if possible.
Thank you
Could anyone with this conversion share coolant plumbing photo's?
crazyvwvanman wrote: |
Mark |
Posted: Tue Jun 22, 2021 8:26 am Post subject: Re: Vanagon Bell Housing |
Mine used Audi flywheels and clutch pressure plates.
One was a 240mm and the other a 228mm.
I think the 240 friction disk was special and the 228 was a Vanagon friction disc.
It has been a while.....
Mark
Yota-toy wrote: |
......Can you confirm what clutch configuration you used? I am hoping to keep the flywheel audi if possible. .......
I know both of my vans with 5 cyl conversions used the standard 298mm shaft........ |
Posted: Tue Jun 22, 2021 10:36 am Post subject: Re: Vanagon Bell Housing |
fwiw I have the 2.5l EV 5cyl flywheel and clutch parts. but iirc and according to rock auto they're 228mm. which does mean you can use improved stage 1 or stage 2 clutch discs fairly easily. it's a heavy beast so probably alot of rotating mass like the diesel likes.
https://www.rockauto.com/en/catalog/volkswagen,199...disc,10605
not sure if it's relevant but just adding to the 5cyl BH conversation details _________________
Abscate wrote: |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
Posted: Thu Oct 14, 2021 6:16 am Post subject: Re: Vanagon Bell Housing |
AndyBees wrote: |
Do you have the part number for the DMF clutch?
I have found a Sachs DMF from Brickwerks, that looks just like the one used on the Golf 3. SACHS 4013872460007
Will the Golf DMF fit the Vanagon?
https://www.autodoc.co.no/sachs/1219771?utm_source...zX4ZaMnVbk
_________________ Follow me on facebook: https://www.facebook.com/norwayvanagon
My youtube channel: https://www.youtube.com/c/Italjohn
Instagram: https://www.instagram.com/italjohn/ |
Posted: Fri Oct 15, 2021 8:47 am Post subject: Re: Vanagon Bell Housing |
Italjohn wrote: |
Assuming Clutch Disc, I have no clue what the part number is for a DMF clutch. But, this is what I found by searching ... 038141032D. Keep in mind, the splines inside the Golf/Jetta Clutch Disc are not the same as those on a Vanagon Pilot Shaft. However, a Vanagon Clutch Disc will work just fine in place of the Clutch Disc that comes with the DMF package. I ran that set-up in my Vanagon until I installed an aftermarket Pilot Shaft with the correct splines.
This is the Part Number for a DMF kit K7003802F at Autohausaz dot com. I purchased my LUK DMF from Amazon but cannot seem to find it now and it doesn't show in my order history for some reason.
Taking the last question as stated, a DMF package (Flywheel, Pressure Plate and Clutch Disc) will not bolt up to the crankshaft on a Vanagon Engine!
Also, if using an adapter to bolt-up a TDI engine or similar VAG in-line 4 to a Vanagon non-Diesel Bell housing, the DMF "might" work with some clearance grinding ... I am not sure about this at all. Depth of the Bell Housing as well as length of the Pilot Shaft are important aspects that must be determined.
Surely someone knows the answer to your last question based on first-hand experiences. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Fri Oct 15, 2021 10:24 am Post subject: Re: Vanagon Bell Housing |
Luk 17-050 is the kit I have gotten.
It fits the Inline-4 engines. The splined hole at the center of the disc is larger diameter than the stock Vanagon input shafts. The custom TDI Vanagon input shaft is available from various vendors.
The DMF will fit in the diesel Vanagon bell housing but requires some slight clearancing (basically around the boss of the clutch release shaft). The DMF will NOT fit with the Vanagon gas bell housing and will NOT fit with any engine to trans adapter plates currently available.
If the stock diesel Vanagon starter is used it will pinch the side of the DMF flywheel. A small amount of clearancing on the starter nose will fix it. It fits fine with the TDI starter+adapter. |
Posted: Fri Oct 15, 2021 4:50 pm Post subject: Re: Vanagon Bell Housing |
The pics below reflect where I removed material from the Diesel Bell Housing for the DMF. Seems I did have to remove a smidge of material for the G60 flywheel.
The pic below reflects where the snout of the Diesel Starter needs material removed to avoid rubbing on the DMF outer surface as Waldo mentioned. This applies to the G60 solid mass flywheel as well.
Lastly, below is a pic of the Vanagon OE 228mm Sach clutch disc I was using with the DMF/Pressure Plate. As you can see, the OE disc is not robust enough for a TDI engine. This disc had less than 20k miles on it. Notice the cracks in the Disc.
Posted: Fri Oct 15, 2021 5:19 pm Post subject: Re: Vanagon Bell Housing |
The castings may be different, but the two bell housings I have modified so far for the DMF only needed the material removed here:
Posted: Fri Oct 15, 2021 6:18 pm Post subject: Re: Vanagon Bell Housing |
Waldo, if you notice, the Bell Housing in my pic is bolted to the transmission. Two of the bolts are visible in one of the photo and one bolt in the other pic.
If I remember correctly, I installed the transmission and snugged the bolts, then rotated the engine with a tool. Anywhere the pressure plate rubbed leaving marks, I knocked off some material. Yes, it was a lot of work doing it that way. Seems I installed and removed the transmission several times to get it right.
But, I do admit it is very possible I hit a spot or two that wasn't necessary. However, as I recall, there were three tabs, maybe more, on the pressure plate I was using with the G60 Single Mass Flywheel. I had to knock those down with a hammer. So, it's possible they were hitting/scrubbing in places that pressure plate on the DMF never touched.
As for the aftermarket Pilot Shaft and Starter Adapter for the TDI starter, I've not been able to find them of late. The Diesel Starter will work just fine. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Fri Oct 15, 2021 8:12 pm Post subject: Re: Vanagon Bell Housing |
I removed the bell housing from the trans as I had to install the TDI Vanagon input shaft anyway. Installing only the bell housing onto the engine for checking seems a lot easier than leaving the bell housing on the trans and bolting the engine and trans together.
Input shaft in stock at Brickwerks.
Starter adapter in stock at mybusparts. |
