Jockomo Samba Member
Joined: October 11, 2006 Posts: 163 Location: Lafayette, LA
Posted: Tue Feb 17, 2015 3:11 pm Post subject: |
busdaddy wrote: |
I don't se any stickers proudly displayed, are those straight out of the box?, or have they visited one of the qualified type 4 head rebuilders for a tweak before you install them?
How about compression?, doing any calculations yet? |
They are right out of the box. I know I should send them in and may still do that someday. But I don't want to spend to much on this gex engine, at least not at this point. I just need to get it running because it's sort of my daily driver.
I haven't done any calculations or measurements yet. There are more pictures and questions to come.
So no loctite on these guys huh?
Thank you cliveawn. Your Truma heater is the only picture I've ever seen of one. For a long time we called that hole in the floor the "toilet". I just have a piece of wood (that came with the bus when I got it) covering the hole. _________________ '75 Westy with '78 2.0L engine. |
kevin77westy Samba Member
Joined: November 12, 2004 Posts: 795 Location: Ocean Springs, MS
Posted: Tue Feb 17, 2015 6:35 pm Post subject: |
Jockomo wrote: |
So no loctite on these guys huh? |
Nope. Tighten them in good and they will fine. No heavy torque required. Plus they will be easier to remove when you have them rebuilt one day.
I thought AMC hardware was getting better in the last few of years but I haven't been paying attention lately. Don't need to - got a pair of Adrian 2L heads stashed away for my next build . |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Feb 17, 2015 6:51 pm Post subject: |
Ahhhh...., I missed the GEX part, regardless I've reached an age or time in my life when pulling motors really sucks when it could have easily been prevented by dropping extra bucks for better parts and careful building, my time is better spent doing the job as good as can be just once and that leaves me more time for higher priority stuff that doesn't involve crawling around under a dead bus.
Green Locktite if you wish but none is needed, if the double nuts start slipping it's approaching too tight. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat May 08, 2021 4:46 pm Post subject: Re: The Dharma Bus |
My brake servo was leaking fluid so I decided to change it and the master cylinder out.
I ordered replacement hoses from bus depot, but I'm not sure I've got the right things.
The hose from the refill reservoir to the twin chamber reservoir seems a bit long. Should I just cut this to size and flare the end? Whats the best way to do that if so?
And this is from what I understand an air hose? (highlighted in red)
I assumed it was a short hose that attached to a metal tube that goes under the beam to the wheel well, which you can see highlighted in the pic below. I think it's a metal tube? Where does this even go?
I think they were out of the part I need there, I'm guessing that's what this is? https://www.busdepot.com/j18127
I ordered 2 hoses because it wasn't clear which one I needed. I also ordered the mysteriously vague "Hose for brake booster servo" https://www.busdepot.com/211611939
But I don't even know what this is for now. Do I need this or is it for FI?
I'm also curious if there's anything I can do while the booster and Master Cylinder are out, like check the pushrod length.
Should I install the new Master Cylinder onto the booster before mounting it in the bus? Bentley seems to indicate to remove and replace the MC while the Servo is mounted, but I'm not sure if maybe it's just how the book is organized.
Unfortunately I didn't find a ratwell proceedure (anyone know of another refrence?) I found this http://www.misterfixit.com/brakbld1.htm
Any other suggestions and advice are welcome!
Thanks! _________________ '75 Westy with '78 2.0L engine. |
Posted: Thu Aug 12, 2021 2:54 pm Post subject: Re: The Dharma Bus |
I'm still stumped on this issue. Specifically the hose that goes to the lower reservoir. I've ordered every hose I can find and none of them work. Anyone have any ideas?
This is the lower reservoir that I have:
https://www.busdepot.com/211611313k
But that hose doesnt fit. I've asked Bus Depot about it several times but they never get back to me.
I ordered another hose from Germany.
https://www.justkampers.com.au/211611805-brake-reservoir-pipe-t2-bay-1973-1979-brazilian-bay.html
Thats not it either.
If you look at the reservoir, you can see the hose has to make a 90 degree turn, not 180.
I'm about to order this: https://www.busdepot.com/211611313j
But to be honest, I don't even know if that will work.
Can anyone please fill me in on what the hell is supposed to be going on down there? I don't know if the fact that the bus was originally intended for the european market matters. Like would the master cylinder be located in a different place? How can this possibly fit? https://www.busdepot.com/211611805 What even is that picture? This setup is as elusive as bigfoot. _________________ '75 Westy with '78 2.0L engine. |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Fri Aug 13, 2021 11:37 am Post subject: Re: The Dharma Bus |
Jockomo wrote: |
Thanks! |
Not sure on your other question but that highlight red hose through the wheelwell on my '79 is plastic, not metal. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1182 Location: Vancouver, BC
Posted: Fri Aug 13, 2021 12:55 pm Post subject: Re: The Dharma Bus |
ImAddicted wrote: |
Jockomo wrote: |
Thanks! |
Not sure on your other question but that highlight red hose through the wheelwell on my '79 is plastic, not metal. |
Mine is plastic on my 76 Westy and it is just a breather hose that goes into a cavity at the top of the wheel well where it meets the panel. I guess that's the highest place it can reach to stay out of the water/wet and not suck moisture back into the brake unit diaphragm. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
