Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri May 07, 2021 5:56 pm Post subject: Help. Need oil shield bearing cap shim size |
Hi guys. I need the shim size for the oil splash shield that goes on the rear axle bearing cap seal for swing axle cars. This is for a short axle 65.
Thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Sun May 09, 2021 6:23 am Post subject: Re: Help. Need oil shield bearing cap shim size |
Bump _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun May 09, 2021 10:38 am Post subject: Re: Help. Need oil shield bearing cap shim size |
What size are you referring to, thickness, or diameter? I would think the thickness could vary, maybe .020-.040. The inner diameter is going to be the axle size, so maybe 1.18/30mm. The outer diameter is going to be just shy of the seal diameter, so maybe 1.96-2.36/50mm-60mm. |
Posted: Sun May 09, 2021 6:47 pm Post subject: Re: Help. Need oil shield bearing cap shim size |
hi there. thanks for the info. i am trying to fgure out the thickness and ID OD. maybe someone has a spare they can measure? I found some on ebay but theyre located overseas.
thank you
Aiden _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu May 13, 2021 7:21 pm Post subject: Re: Help. Need oil shield bearing cap shim size |
lol i ended up ordering the shims from europe and it cost me more in shipping than if i had bought two sets of the kit you linked. makes you wonder where WW gets their shims.
thank you tho _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Thu May 13, 2021 7:27 pm Post subject: Re: Help. Need oil shield bearing cap shim size |
Chickensoup wrote: |
thank you tho |
WW is one of the few aftermarket companies that goes the extra mile on things, and contracts a lot of things to be made for them. I would image if/when you do find the actual diameter/thickness, having a company stamp/waterjet shims from a known thickness sheet wouldn’t be to difficult. WW has the advantage of the more you make, the less cost per unit. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Fri May 14, 2021 4:41 pm Post subject: Re: Help. Need oil shield bearing cap shim size |
I think I got an axle seal kit from Airhead many years ago that also had the slinger disc in it. That was a long time ago though, but I remember taking a photo of it over a decade ago. Diameter only, not thickness, but it's certainly not flimsy. Looks like 51.5mm or so...
_________________ Andy T.
Posted: Fri May 14, 2021 7:21 pm Post subject: Re: Help. Need oil shield bearing cap shim size |
hi, thanks for the picture. i measured the axle and got 30mm. then i meassured the step on the axle cap and got 60mm.
the 60mm could be wrong as for i couldnt get the teeth of the caliper in there enough but i ordered a set of the slingers and i will measure then and post up upon arrival.
thanks again _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
