Tekenbeet Samba Member
Joined: May 29, 2012 Posts: 5 Location: Geldrop, Netherlands
Posted: Sat May 08, 2021 6:40 am Post subject: WBX Syncro pulley seal instalation? |
Hello Syncro owners,
How did you install your syncro pully seal?
I guess I can try to use use my spare pulleyside ring and use that to tap it in, but I'd rather not (It's new and original)...
maybe someone here has the trick? |
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Sat May 08, 2021 6:57 am Post subject: Re: WBX Syncro pulley seal instalation? |
I think that I used a large socket, but anything that is flat and about the right diameter can be used to carefully tap in into place.
There are of course special seal installation things you can buy but its not really necessary for this one. The purpose of that seal is just to keep things like water and mud from getting into the engine.
RonC |
Posted: Sat May 08, 2021 11:55 pm Post subject: Re: WBX Syncro pulley seal instalation? |
That would be a large verry thin walled socket.. It would need to fit in between the lips? |
Posted: Sun May 09, 2021 12:16 am Post subject: Re: WBX Syncro pulley seal instalation? |
So far I found this:
1 small glass the rim is too thick
2 a lid from a plastic can. Perfect fit but verry week
[/img] |
Posted: Sun May 09, 2021 5:06 am Post subject: Re: WBX Syncro pulley seal instalation? |
Are we talking about the same thing?
Seals are meant to be driven from the other side. There is a steel ring just inside the OD that can take the load.
RonC |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sun May 09, 2021 8:45 am Post subject: Re: WBX Syncro pulley seal instalation? |
Same seal position but the one you have pictured is of the 2wd version
snowsyncro wrote: |
Posted: Sun May 09, 2021 10:00 am Post subject: Re: WBX Syncro pulley seal instalation? |
Yup, sorry I could have been more clear. I was just trying to show the position. I do have a Syncro pulley but it is installed on an engine right now.
RonC |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Sun May 09, 2021 10:13 am Post subject: Re: WBX Syncro pulley seal instalation? |
When I don’t have an appropriate size sleeve, I will use the removed seal and my brass hammer. The trick is to work it in evenly without distorting the new seal or popping the spring girdle off. _________________ ☮️ |
Posted: Sun May 09, 2021 10:39 am Post subject: Re: WBX Syncro pulley seal instalation? |
MarkWard wrote: |
When I don’t have an appropriate size sleeve, I will use the removed seal and my brass hammer. The trick is to work it in evenly without distorting the new seal or popping the spring girdle off. |
Unfortunately that doesn't work with this seal, the raised parts offer no structural inttegrity as they are just formed rubber lips. The recessed section is where the metal backing is. |
Posted: Sun May 09, 2021 11:00 am Post subject: Re: WBX Syncro pulley seal instalation? |
So, a seal without a way to install it. What’s it set when the case is assembled? _________________ ☮️ |
Posted: Sun May 09, 2021 11:53 pm Post subject: Re: WBX Syncro pulley seal instalation? |
I got it in with no damage using the plastic lid seated in the outer groove!
Thanks all!
4Gears4Tires Samba Member
Posted: Mon May 10, 2021 6:23 am Post subject: Re: WBX Syncro pulley seal instalation? |
syncrodoka wrote: |
Same seal position but the one you have pictured is of the 2wd version |
I am 97% sure you are joking but 3% of me says, "hmm why I wouldn't be surprised." _________________ '87 Syncro
Posted: Mon May 10, 2021 8:40 am Post subject: Re: WBX Syncro pulley seal instalation? |
4Gears4Tires wrote: |
I am 97% sure you are joking" |
Nope. Different seal and pulley for blocking water/mud intrusion. The 2wd version has a flat face, the syncro version has raised ridges that fit into an extra piece on the pulley. |
Posted: Mon May 10, 2021 10:28 am Post subject: Re: WBX Syncro pulley seal instalation? |
Of course. How silly of me to assume you were joking about that.
