PaoloT2 Samba Member
Posted: Sun May 09, 2021 11:31 am Post subject: VW T2 bay window bus - flywheel replacement which one to choose? |
Hello Everyone,
I have a VW T2 campervan with a Type 4 engine 1800cc.
I need to replace my original flywheel as there is a groove in it and it started leaking through the main seal...
I have found a few on line but I am not sure which one to take as they all look different now because the original are not manufactured anymore. Could you help me find the replacement please ? Also do I need to change the starter motor with it ?
I have put some photos of the old and new one
Thank you !
Paolo
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun May 09, 2021 12:02 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
Can I see a pic of the damage? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun May 09, 2021 12:21 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
Hi,
This is where it is damaged.
Thank you.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 09, 2021 12:33 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
A Speedi sleeve would solve that problem, apparently it's #99289 for a type 4. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun May 09, 2021 12:52 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
That's great ! Can I be sure it is 99289 ? I have found one.
Also, will I be able to fit it myself with a rubber hammer ? or do I need a specific tool please ?
Thank you ! |
Posted: Sun May 09, 2021 12:59 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
I learn something every day
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun May 09, 2021 1:11 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
Great. Thank you I will try this.
Thanks a lot ! |
Posted: Sun May 09, 2021 4:41 pm Post subject: Re: VW T2 bay window bus - flywheel replacement which one to choose? |
PaoloT2 wrote: |
Thank you ! |
That's what I found in the Vanagon forum, but upon further investigation it's for a water boxer, I don't know if they have the same crank snout. The seal for it pictured here is the same on for your bus so maybe it fits?: https://www.thesamba.com/vw/forum/viewtopic.php?t=730816&highlight=99289
Installation doesn't require any special tools, the cup it comes packed in makes a great driver to get it on evenly.
Surely some VW or Porsche 914-4 owner has found one that fits, do some research. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
