Front caliper hard lines
J.A.P.III
J.A.P.III is offline
PostPosted: Sun May 09, 2021 3:23 pm    Post subject: Front caliper hard lines Reply with quote
replacing my front calipers on my 89' 2.1, took to long and I can't figure out how the hard line is positioned to hook up to the flex hose. If anyone could please help with maybe a pic. that would be awesome. I started out just changing pads, turned into all new front brake system, and all around Bilstiens
Stoked!
Ahwahnee
Ahwahnee is offline
PostPosted: Sun May 09, 2021 4:12 pm    Post subject: Re: Front caliper hard lines Reply with quote
Mine's an 84 but perhaps the same. Is this the line you're dealing with?
J.A.P.III
PostPosted: Sun May 09, 2021 4:31 pm    Post subject: Re: Front caliper hard lines Reply with quote
Thats the line but the caliper looks different
jlrftype7
jlrftype7 is offline
PostPosted: Sun May 09, 2021 5:38 pm    Post subject: Re: Front caliper hard lines Reply with quote
. It should, earlier Vanagons will have a slightly different brake setup vs your later Van. But it’s a nice reference to start with. With your calipers bolted to their spindles by a single bolt as a starting point, you should be able to hold up each hardline and see which way it fits best as a link between the caliper and the flex hose.
Usually, on any vehicle , those hard bent lines are very ‘handed’ and only fit one way to a side on an axle.
Otherwise, wait for someone with a picture of the late model calipers to post a picture
‘84 Tin Top - Hilga....Auto
