Oil warning light/buzzer problems Subaru Engine
Azad lost
Azad lost is offline
PostPosted: Thu May 06, 2021 5:16 pm    Post subject: Oil warning light/buzzer problems Subaru Engine Reply with quote
I don't know if people will be able to help me with this problem, but it will require many little bits of knowledge, so any information, even its not a solution, will be appreciated.
The vehicle: 87 syncro
The motor: 3.3 Subaru H6 out of an svx
The problem: This is a new problem. Whenever the engine revs above 3800, the buzzer begins sounding and the oil light flashes. This continues until the engine is shut of.
Extra details:
When the key is inserted and turned to the "on" position the oil pressure light flashes only once at the moment the key reaches "on" position. It DOES NOT continue to flash with the key on and engine off as I believe it should in a standard vanagon.
I believe I have located the oil pressure switch on the Subaru motor, behind the alternator. If I unplug the oil pressure switch, the light does not flash or turn on. HOWEVER, if the oil pressure switch is unplugged the buzzer will NOT sound and the light will NOT flash when the engine revs above 3800 rpm
Theres plenty of gaps in my knowledge of the system, so any information helps.
MarkWard
MarkWard is offline
PostPosted: Thu May 06, 2021 6:15 pm    Post subject: Re: Oil warning light/buzzer problems Reply with quote
The 87 would have had two oil pressure switches. That’s how the system was engineered and wired. So, the Subaru engine would have needed 2 switches as well. If you only have one switch and it was working, the converter likely did something to get it to work and that “trick” has failed.
You should first verify the oil pressure with a mechanical pressure gauge.
Azad lost
PostPosted: Thu May 06, 2021 9:39 pm    Post subject: Re: Oil warning light/buzzer problems Reply with quote
Is it possible that the subaru switch was wired to the buzzer in the manner of the high pressure switch instead of the light in manner of the low pressure switch?
MarkWard
MarkWard is offline
PostPosted: Fri May 07, 2021 4:35 am    Post subject: Re: Oil warning light/buzzer problems Reply with quote
I’ve actually never run just one switch that way. I suppose it could work. It would likely change the behavior of the warning light on startup. On a stock WBX, disconnecting and grounding the high pressure switch lead disables it for testing. If that works the switch could be bad or the engine has an actual oil pressure problem.
wesitarz
wesitarz is offline
PostPosted: Fri May 07, 2021 5:59 am    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Look up how to disable the hi pressure buzzer on the speedometer.
MarkWard
MarkWard is offline
PostPosted: Fri May 07, 2021 8:35 am    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Disabling at the cluster is sort of permanent. I believe since it was working, they'd like to have it working again.
Rather than explaining how the system is supposed to work, here is a recent thread regarding troubleshooting the system. https://www.thesamba.com/vw/forum/viewtopic.php?t=753690
Since it's converted to subaru power plant, without a supplemental wiring diagram, it's going to take some investigating. As I mentioned above, first step is to verify the engine has the correct oil pressure. Your warning could be functioning properly.
wesitarz
wesitarz is offline
PostPosted: Sat May 08, 2021 8:45 am    Post subject: Re: Oil warning light/buzzer problems Reply with quote
There is a low oil pressure wire (Bl/B) and a hi pressure wire (Y)at the 14 pin connector to the cluster. Maybe check which wire the Subaru oil pressure sensor is connected to in the black box drivers side firewall in the engine bay.
I've never heard of anyone using the hi pressure with a Subaru.
Azad lost
PostPosted: Sun May 09, 2021 3:16 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Oooh, where is this black box? Where can I find information about what’s in it online.
I checked the oil pressure, I can confirm that the oil pressure is fine. Also, while i had a manual gauge hooked up , and the wire to the oil pressure sensor disconnected, the buzzer kept going off regardless.
Now I suppose I can confirm that
1: the buzzer is not connected to true oil pressure
2: no functioning oil pressure warning system of any kind.
I replaced the pressure switch, everything seems to be the same.
Azad lost
PostPosted: Sun May 09, 2021 3:21 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Also, i’ve been told those colors at the 14 pin connector, but mine dont seem to match up.
Heres a picture of my 14-pin connector.
hardway
hardway is offline
PostPosted: Sun May 09, 2021 3:28 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
The Subaru motor did not come with the high pressure switch that is needed for the dynamic oil pressure system to work. Unless it was added it is not there. The stock VW high pressure switch is open below the threshold pressure and closed when above the pressure to provide ground to the control unit in the instrument cluster. If you locate that wire and ground it the buzzer should not sound. It should be a yellow wire in the engine compartment.
Azad lost
PostPosted: Sun May 09, 2021 5:57 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
I understand all that. At this point my interests are more focused around having a functioning oil pressure warning. Helpful info would be:
-Which of the wires on my 14 pin plug goes to the low pressure oil switch originally (it doesnt seem to be yellow)
-which is the high pressure switch wire?
-where could i find the other ends of these wires in the engine bay so i can hook one up to my oil pressure switch.
wesitarz
wesitarz is offline
PostPosted: Sun May 09, 2021 6:55 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Wire at #12 of the 14 pin connector should be hi pressure (green)-mine is yellow on my 88; wire #13 should be low pressure (blue/ black)
These wires can be found on T7A connector (round 7 pin connector ) in the black box upper drivers side of firewall in the engine bay. The hi press might be the one in the middle according to a schematic that I have.
Try disconnecting the hi press wire. The low press wire should connect to the Subaru oil press sensor
MarkWard
MarkWard is offline
PostPosted: Mon May 10, 2021 7:25 am    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
I see 3 non factory splices in your harness. Through the years there are a few arrangements of the wires in the connector.
First step would be to meter out which wire is which end to end. If you want to only run the low pressure oil switch, you will need to disable the high pressure switch provision as mentioned above.
Azad lost
PostPosted: Fri May 21, 2021 1:24 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Would like to say that everything is fixed now and working great. The low pressure switch works and the high pressure switch is deleted.
The true answer came courtesy of Jeff Robenolt of Autoventures.
It was was the "blue foil" or printed circuit board that was at fault.
When I called Jeff he immediately told me the blue foil was at fault without hesitation, but I resisted because the gauge cluster didn't appear to have any other faults.
Jeff was right.
I replaced the blue foil with a "cluster master" wiring kit from The Bus Depot (CMDT version). And the problem went away. I think the blue foil should be one of the first answers suggested to anyone with an oil buzzer issue.
MarkWard
MarkWard is offline
PostPosted: Fri May 21, 2021 2:00 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
After you verify the engine has oil and pressure. Wink
Azad lost
PostPosted: Fri May 21, 2021 3:29 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Haha, Fair enough. And thank you so much for your help. Everything felt better after running a mechanical gauge. I ended up snipping the high pressure sensor wire, and the buzzer kept going off anyway.
wesitarz
wesitarz is offline
PostPosted: Fri May 21, 2021 5:17 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
[quote="Azad lost"
I replaced the blue foil with a "cluster master" wiring kit from The Bus Depot (CMDT version). And the problem went away. I think the blue foil should be one of the first answers suggested to anyone with an oil buzzer issue.[/quote]
The CMDT version deletes the buzzer, which you can do by bending one pin on the printed circuit board behind the speedo.
rmengr1
rmengr1 is offline
PostPosted: Mon Jun 28, 2021 11:31 pm    Post subject: Re: Oil warning light/buzzer problems Subaru Engine Reply with quote
Blue black is low pressure and Yellow is high pressure. Yellow should be grounded. Check to make sure its a strong ground. Blue Black is connected directly to the pressure sensor on the engine. it should be terminal 1 on the round connector in the black box.
Good luck
JB
