Zeitgeist 13 Samba Member
Posted: Mon Apr 26, 2021 11:08 pm Post subject: Re: Oregon Trail Syncro build |
I'm currently installing an AHU in a Syncro with the factory diesel bits, and I have to say the 15 degree install is a much easier to service approach. Looking forward to your build updates. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dkoesyncro Samba Member
Posted: Sun May 09, 2021 8:22 am Post subject: Re: Oregon Trail Syncro build |
Another mess...
As I was digging in and evaluating the MS install, I thought I'd look into the engine a bit for a welfare check. This was a bummer deal but better now than later!
Problems-
Cracks, "many" on a proprietary design "NLA" turbo manifold, one crack so complex that it have to be milled after welding up. I could throw in the towel and get the dime a dozen t3 garrett flanged turbo but I'm over it, my toy engine and my toy van can't share the same place! My cylinder walls had some shallow scoring and signs of heat. I'll tear into it deeper later but as a door closes another opens.
I spent the last two weeks mulling over my choices. I thought long and hard about a VR. My engine porn imagination got carried away about just how I could make it fit. The power numbers were just so if I used the AES cams and squared runners on a low pro rams horn style intake....(record screeched) I realized I'm doing it again...a repeat of the last build but N/A and two more cylinders and that wonderful low growl of the VR. Just had to die, now!
Based off of a fiscal decision and a practacle decision. I'm installing VW/Audi version of Top Ramen, it comes in many flavors to not disappoint, fills the void, and is plentiful just about anywhere!
Welcome the 1.8T!
rogertj Samba Member
Joined: October 07, 2008 Posts: 505 Location: Tijuana, Baja California. Mexico
Posted: Sun May 09, 2021 8:02 pm Post subject: Re: Oregon Trail Syncro build |
Great to hear that youre going for the 1.8T I had it but not had the bases to follow the build it seems that you have to search for this conversion on other forums not much information here or I have not looked deeper.
Good luck on your new engine and looking forward in your progress! Writte something like the Vanagon Nut manual on the internet lol!!!!!!
Thanks again for your help in my build you have been a great help. That book has helped me a lot! _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Sun May 09, 2021 8:39 pm Post subject: Re: Oregon Trail Syncro build |
A solid choice. I can verify that the VR6 is a very tough engine, but the 1.8t has much better torque characteristics for these vans. _________________ Casey--
y u rune klassik? |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Sun May 09, 2021 9:47 pm Post subject: Re: Oregon Trail Syncro build |
Sorry about the last motor.
My last build was an amu motor, big turbo and aeb head. Still got a pile of amu parts if want.
Good luck. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Fri May 28, 2021 6:08 am Post subject: Re: Oregon Trail Syncro build |
A bit more progress has been done. It certainly doesn't seem like a lot by the pictures. Since the last post, I've torn the engine down for a welfare check. Had the head pressure tested and resurfaced. Plastigauged the rods/mains
and reasembled the thing. Recent timing belt and water pump chain tensioner and chain as far as I could tell! It was maintained well.
I had the ecu out with a local tuner for a remap and mobilizer delete. While he's at it, he's removing all the emissions crap. No more SAI, secondary o2 sensor and all those damn hoses and check valves....gone! I am keeping the evap purge valve, my own pieve I suppose, I like having a gasoline vapor free van.
Between things, I've managed to get the wiring somewhat sorted out. It's time consuming but I enjoy it. It afforded itself some bonding time. My son can now read and understand Bentley schematic diagrams and how relays work, he really enjoyed it.
I think I may have finally solved my drive line vibes....time consuming venture. But once I was sure of what I was doing, I nailed them down on the 4th reading. It took all that equipment to get it done. A strap, hydraulic table, engine support bar (rotational angle) and the chain hoist.
Posted: Fri May 28, 2021 8:05 am Post subject: Re: Oregon Trail Syncro build |
Nice progress Dillan! Hope to have more pics and details of the build I would love a 1.8T in mine in the future! _________________ Roger
valvecovergasket Samba Member
Posted: Fri May 28, 2021 9:08 am Post subject: Re: Oregon Trail Syncro build |
dkoesyncro wrote: |
Reviving this thread as I'm about to embark into another phase of this machine. Although it works, but not without some issues I'm going to swap out my management for Microsquirt, the modified 1.8t harness just has some issues.... nothing consistent...often chasing gut intuition... without results or eureka! |
feel free to reach out if you run into hurdles with the MS
looking good!! _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Sun Oct 10, 2021 9:43 pm Post subject: Re: Oregon Trail Syncro build |
It's been a while but I'm happy to say that this engine conversion has been running strong for a couple of weeks now. This engine really transforms the vanagon experience!
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Mon Oct 11, 2021 12:32 am Post subject: Re: Oregon Trail Syncro build |
That's a nice install. Well done. _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
Posted: Fri Oct 15, 2021 2:45 pm Post subject: Re: Oregon Trail Syncro build |
Nice job Dilan! When can I send you my Vanagon lol!!!
Congratulations! _________________ Roger
rmcd Samba Member
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Sat Oct 16, 2021 1:29 pm Post subject: Re: Oregon Trail Syncro build |
Nice!!!! |
