bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Sun May 09, 2021 1:18 pm Post subject: Modern Case half Sealants what are you currently using? |
For past 20-30 years I have always used Gasgacinch to seal my case halves up with great results. The past year or so I have done two stock 1600s. Used two different, new cans of Gasgacinch. I dunno if they changed the formula or what but it has been very VERY runny compared to what it was in the past decades. I used it anyway and both of these engines are now weeping from the case seam
I am done with Gasgacinch and looking to use try a new product. Had some Hylomar at the shop (which some folks recommend) and I did not like the consistency and fact it never dried at all. I have had one of the better engine builders I know recommend Hondabond/Yamabond and was leaning towards trying that says it dries but stays flexible.
Looking for some comments or opinions on what is out there currently.
Thanks _________________ Samba Member #95 |
Shane Tuttle Samba Member
Joined: February 02, 2011 Posts: 173 Location: Arlee, Montana
Posted: Sun May 09, 2021 1:20 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
I recommend Hylomar or Loktite 515. I use both of these in the aviation industry and both are top quality products. I would lean towards the 515 for the engine case halves. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Sun May 09, 2021 9:25 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
I’ve used Gasgasinch, Hylomar, Aviation Permatex, Loctite 515 (and other #), Ford water pump, silk, etc...etc... I’ve been at this since 1966, Porsche, VW, British MC, plus water pumpers (gave them up 30 years ago). Back in those days, EVERYTHING leaked oil. When we were kids, we had to be careful riding our bikes across a parking lot. It finally occurred to me in the ‘80’s that everything coming from Japan DID NOT LEAK AT ALL! _________________ Jack Staggs
Actual name |
Posted: Mon May 10, 2021 12:46 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Jacks wrote: |
I’ve used Gasgasinch, Hylomar, Aviation Permatex, Loctite 515 (and other #), Ford water pump, silk, etc...etc... I’ve been at this since 1966, Porsche, VW, British MC, plus water pumpers (gave them up 30 years ago). Back in those days, EVERYTHING leaked oil. When we were kids, we had to be careful riding our bikes across a parking lot. It finally occurred to me in the ‘80’s that everything coming from Japan DID NOT LEAK AT ALL! |
Hmm must be the Yamabond and the Hondabond huh? _________________ Samba Member #95 |
Jacks Samba Member
Posted: Mon May 10, 2021 5:51 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Yes, or equivalent ThreeBond 1184 _________________ Jack Staggs
Actual name |
obieoberstar Samba Member
Posted: Tue May 11, 2021 7:33 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
25 years ago I was introduced to Loctite 574 for sealing 356 and 911 engines by my mentor at Stoddard in Cleveland.
No leaks in the last 17 years on my type 4 and beetle engines. Good stuff. |
74 Thing Samba Member
Posted: Tue May 11, 2021 8:17 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
Yep, 574 is good stuff. I have that and Curil T. I have the Threebond too as well as the Hylomar. |
Jacks Samba Member
Posted: Tue May 11, 2021 11:30 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
++ all those, yes! None is the perfect solution for ALL applications. VW, 356, 911, call for specific solutions. This will come from experience. Experience comes from bad judgment. Now, experience is a hard teacher. She gives the test, then the lesson _________________ Jack Staggs
Actual name |
esde Samba Member
Joined: October 20, 2007 Posts: 5967 Location: central rust belt
Posted: Wed May 12, 2021 4:55 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Jacks wrote: |
Yes, or equivalent ThreeBond 1184 |
I have been using the threebond for 6 or 7 years, and I'm very happy with it. It is easy to spread very thin, and when doing so it stays tacky for long enough that you don't have to rush assembling the case halves. It's adhesion to mag and aluminum is excellent, and tear strength is pretty high. Was told that the Hondabond and Yamabond were made by the same company, but no idea if it's true.
FWIW, there are a dozen different formulas, the 1184 is what I decided on and have been using. Nice stuff _________________ modok wrote:
Posted: Thu May 13, 2021 12:21 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Yes, I am seeing different formulas. Went to order some Hondabond and saw there is Hondabond 4 and Hondabond HT....not sure what each was for so held off for now. Anyone? _________________ Samba Member #95 |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat May 15, 2021 9:03 am Post subject: Re: Modern Case half Sealants what are you currently using? |
bastardbus wrote: |
Yes, I am seeing different formulas. Went to order some Hondabond and saw there is Hondabond 4 and Hondabond HT....not sure what each was for so held off for now. Anyone? |
It's the Threebond #1184 that you want _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sat May 15, 2021 7:48 pm Post subject: Re: Modern Case half Sealants what are you currently using? |
evanfrucht wrote: |
bastardbus wrote: |
It's the Threebond #1184 that you want |
YES that stuff works so dang well. however getting it back off once its dried is a PITA. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun May 16, 2021 12:56 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Curil K-2 |
OKType3Tim Samba Member
Joined: April 30, 2011 Posts: 279 Location: Northeast Oklahoma
Posted: Mon May 31, 2021 7:20 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Went to purchase some additional Curil K2. Argh! Discontinued! Can not be found/purchased.
Curil T can still be found/purchased; but is not longer listed on the elring web site. And there are mixed reviews here on TheSamba about results using the "T" product.
Elring now lists only two sealing compound products: Curil T2 and Dirko HT.
The Curil T2 spec sheet says "Polyurethane" based, and "contains no solvents".
Any comments? Any one used the "T2" product?
https://www.elring.com/en/products/sealing-compounds/
Note: the Dirko product is listed as "Oxime silicone". _________________ '69 Squareback restoration
'69 Fastback restoration
'66 Type34 |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Mon May 31, 2021 11:00 am Post subject: Re: Modern Case half Sealants what are you currently using? |
Uh-oh, I'd better find some old stock...thanks for the heads up! |
