terryly Samba Member
Posted: Sun May 09, 2021 9:50 pm Post subject: How much does a IDF carburetor weigh ? |
Hi there. I am curious what an IDF carburetor with cast aluminum base, filter and top weigh if some on has one handy to weigh please. I have sold all my carbs and parts since going EFI and dual independent runner throttle bodies.
What I am working with right now is switching from dual throttle body set up to a single throttle body and dual turbo plenums. I was starting to get concerned that the plenums I am making are a little heavy. Contemplating if it would be wise to third stud my heads. I then measured what I have
Some of the weights I have come up with are
-2050 g previous dual ITBs each
-1866 g new turbo plenum each
- 910 g previous Cb offset manifold
- 956 g new big beef injector strait manifolds
- 2960 g Itbs and offsets manifold set up
- 2822 g new plenum + big beef set up
So I am now pleased to find out I am now 138 grams lighter with probably less leverage on the intake studs. Although the big beef manifold is taller than the offsets my plenum is lower than a carb/ filter set up
Still curious what the old carb set up I ran pre-fuel injection would weigh ? How about Kadron dual singles or any other dual/single carbs
Stock end casting ? Just out of curiosity haha
Under what conditions would one want to third stud the heads ?
I have a Baja that would subject them to harsher down force than a street car
Obligatory pics
_________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Calgary Alberta Canada
Terry Lytle |
mark tucker Samba Member
Posted: Mon May 10, 2021 10:48 am Post subject: Re: How much does a IDF carburetor weigh ? |
dang those are thick!! put them on the mill and fin them!!!! |
ken63 Samba Member
Joined: April 12, 2003 Posts: 102 Location: Redwood City, CA
Posted: Wed May 19, 2021 2:16 pm Post subject: Re: How much does a IDF carburetor weigh ? |
my 44 IDF with CB aluminum base and top and 3" filter weighs 2372g _________________ '63 Bug
'61 Bug |
Posted: Thu May 20, 2021 4:21 pm Post subject: Re: How much does a IDF carburetor weigh ? |
thanks bud seems I am a little heavier _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Terry Lytle |
