chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3413 Location: San Diego
modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
Posted: Mon May 10, 2021 4:46 pm Post subject: Re: hi rev springs data |
QRP wrote: |
BUT!!!
Beehive springs are bypassing when it comes to valve train, from my limited knowledge they are far superior to the old technology. |
I've been running beehive springs all along. I believe I got them in 2007
There are actually a lot of choices. Mine are from a old four cylinder chevy, then there is ford modular size ones such as comp 26215, cb did LS springs for awhile, Dan Rudduck has a kit, Aircooled.net sells some too. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1703 Location: NORTH HOLLYWOOD,CA
Posted: Mon May 10, 2021 7:28 pm Post subject: Re: hi rev springs data |
modok wrote: |
QRP wrote: |
BUT!!!
Yeah I know Dan and ACN have kits at the ready and guys like you are hip to the program already but just surprised it's not more common place on here.
( hmmmm didn't know CB was offering it at one point )
Then again I have been absent for a while . . LOL
On the springs you used did you modify some chromoly retainers to fit, or is that even possible???
I feel bad high jacking this guys thread. |
modok Samba Member
Posted: Mon May 10, 2021 9:20 pm Post subject: Re: hi rev springs data |
Modified retianers from a old v6 ford ranger |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7182 Location: Videbaek Denmark
Posted: Tue May 11, 2021 1:56 am Post subject: Re: hi rev springs data |
You keep comparing a VW valve train with a V8. IRL they are worlds apart.
There are several reasons to why beehives are not commonly used in the ACVW world.
1. 80% don´t really need them.
2. Price. - A kit price 3 times the price of good barrel springs doesnt encourage many to go that way. And it is actually a little odd, because they are not that expensive for other engignies. (We use them regularly in other engines where lift is less and you can´t convert to dual springs.)
3. Half the people that could benefit from them run into lift issues.
4. (This is a personal point of view) I am a firm believer in light valve trains. Also, the better you set the valve train up the lesser risk of float and to a certain extent harmonics there is. Also, as I wrote above, if you stop using cams that are designed 50 years ago and move on to something a little more modern you reduce the risk of both float and harmonics already there.
A properly designed cam, and especially assymetrical cams does not suffer from the issue with float during rpm increases. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Tue May 11, 2021 4:03 am Post subject: Re: hi rev springs data |
I may be asking an off topic question, but they are related.
What is considered light valve train and what are modern cams?
If I’m running Thorsten-Pieper 54g lifters, alum pushrods, Scat slipper foot rockers, SS valves with titanium retainers...is that light?
Are the Nowak / JPM cams considered modern? Web vs. Engle? |
Posted: Tue May 11, 2021 9:09 am Post subject: Re: hi rev springs data |
txoval wrote: |
If I’m running Thorsten-Pieper 54g lifters, alum pushrods, Scat slipper foot rockers, SS valves with titanium retainers...is that light? Yep!
Yep! That said, Web is not nearly as rough as Engle. Steve Long has some good grinds (and some not so interesting) CB has some good ones too, especially some of the newer "weekend warrior" cams.
