SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sat Aug 01, 2020 7:36 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Over the last couple days I've tackled some electrical connection issues in the dash, cleaned all the grounds on all four exterior light assemblies, replaced the positive and negative battery cables as well as the transaxle cable.
Replaced the rear shift coupler, the front coupler that resides in the front of the shift tube (68-71 bushing), greased all components and cleaned up the shift block off plate and housing. I checked the transaxle code (CA) because the throw on the shifter is so long, 3rd hits the parking brake release. I've known this to be an issue when 091's are installed into earlier buses as they have longer throws, but it's the original box for the year. Thoughts? Could the shifter have been replaced with a later year? I'm not aware of shifters being different throughout 68-79.
Wrapped up the front brakes with bending new metal lines, rubber hoses, wheel cylinders, shoes, and getting a new master cylinder installed. I went ahead and installed the drums, made adjustments for the shoes prior to adding brake fluid. I learned this years ago, if you do a brake job, and DO NOT adjust the shoes out to mate the drum first, when bleeding the system, without that resistance you'll basically pop the pistons out of the wheel cylinders and have a mess of things behind the drum. Which of course makes sense now, but a thought that didn't occur my first go around to what seems like forever ago.
Driver side
Passenger side
Note that I did reuse the inner metal supply line between wheel cylinders.
Purchased a battery to test the functions of the electrical, with much surprise I have most components working. Up initial testing, the only items not cooperating are the horn, the fuel gauge, the reverse lights and the dash lights.
I dug around a bit behind the dash, removed all the wiring, cleaned the connections, the wire ends themselves, and reinstalled everything. Always take the time to label the wires, it makes it so much easier for reinstall.
Discovered the front turn signal housing grounds were broken. Fixed those, and the quick turn signal flash went away. Also discovered that the coil within the headlight switch that operates the dimming of the lights was shot. The switch will function running and headlights, but theres no dimming of the current non-existent dash lights. Bulbs are good, receiving 12v. So my theory is the circuit within the headlight switch is causing a fuss.
Still awaiting my replacement floor metal and battery tray. Klassicfab shipped it out two Wednesday's ago. This past Wednesday, FEDEX delivered to someone in Stockton, CA. My package was suppose to go to Benton, AR! WTF?!
Received a bunch of the engine parts: generator, ignition coil, drive pinion, fuel pump, carburetor, ignition components, oil cooler, and the various items that all are on standby until I pick up my engine tin from the powder coater. I have items I need to clean up for that engine as well; intake, generator stand, fan, Hoover bit, thermostat and its bits, and probably a bunch of items I've currently gone blank on this morning.
Though it's ugly, I'm trying to get the bus operational, so I can at least drive it in and out of the shop, making it easier to move paying projects in and out. I want to take it to the Eureka Springs show, but the miss doesn't like that idea. She said it looks like a "creeper van"
Perhaps it does, but it isn't anywhere as creepy as that Panel Jason had with the Toy Company all over it, with it's dancing toys!
Have a great weekend everyone, stay safe
Sam _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Wed Aug 12, 2020 6:30 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Been crunching away the past week or so bringing life into this long block I picked up with Panel last month.
Here it is nice and naked, checking flywheel shims, flywheel seal, and endplay.
I know the engine sat for a long time, so I pulled the rocker assemblies off and checked torque on the cylinder head nuts. Yep, most were loose.
Installed the drive pinion gear with the distributor. Installed with the mandatory two washers (spacers) as well. Getting those installed in an assembled case was fun
Installed oil cooler, generator stand. Checked torque on case half nuts and bolts.
The weight of the engine started to scare me a bit on the table, so I transferred the engine onto a transmission jack with a piece of plywood. Makes a good work surface.
Reused an old exhaust setup and clutch kit from another engine. All in decent shape.
The powder coated items look really nice. Also picked up the wheels, awaiting tires.
These are late Split/early bay stock 14" bus wheels.
Once tires get in, I'll be able to move it out into a cubby in the shop and start working on paying customer's projects
Posted: Wed Dec 30, 2020 10:46 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Not a whole lot has happened with the panel the last few months.
I did manage to pull the rear window out, along with the front windshield. The nose is completely rotten under the glass, and with all the damage and mud on the lower sections, looks like I'll be doing another nose replacement on a bay bus!
The Panel will be rolling to the sandblaster in a couple weeks. Going to rip all the crud off, pull doors, and have the exterior blasted and epoxy primed. This will give me a clean and clear state of the buses solidness, and the metal work may begin. _________________ The Bus Barn Ltd. Co.
Posted: Mon May 10, 2021 2:37 pm Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Well damn, it's been so long uploading photos seemed that of a distant memory
I've been relatively busy with life and work the past 5 months, I'm beginning to learn why all the old fellas say wrenching on other folks cars, you lose interest in doing it on your own.
But aside from my personal absence on here, the Panel has been receiving some progress. I decide to have the entire exterior sandblasted and epoxy primed, while not messing with rusted front cab doors nor the trashed deck lid.
The bus being blasted in stages, showing the good and the bad. Overall, I didn't think it was too gnarly for a Washington State to New Jersey Early Bay.
Passenger side rear rocker and corner rot.
Gotta love when metal repair includes irrigating the sheet metal
A couple weeks ago, I decided to chop the roached nose off. A process I've decided to do twice now on my last two personal buses.
Fortunately the inner structure and A pillars are clean and solid aside from where the lower A pillar section welds to the inner end caps that support the inner valance. I'll have to cut the rust out and create patches to weld the caps to before building back up the framing for the nose skin.
The front floor isn't all that bad. Both driver and passenger rot is really isolated to a "resting feet" area, seemingly from wet boots out in WA. I'll be using Klassicfab patch panels for the floor.
As you guys may have been tagging along before my monthly break, the mystery longblock ended wasting some time and energy, so while I've continued to put off it teardown and dissection, I've begun building a new engine for the Panel.
1691cc
- New Brazilian VW case
- CB Performance C/W 69.5mm crankshaft
- AA Pistons Thickwall 88mm Pistons/Cylinders
- AA Pistons 500 Series Heads (Ported and Polished by Brother's Machine Shop w/ Matched Ported Carb Manifolds)
- SCAT 5.4 I beam Rods
- Engle W90 Camshaft
- Engle Single Hi-Rev Springs, Chromoly Caps and Keepers
- Scat 1.1:1 Rockers (so using traditional heli-cut timing and cam gears)
- 26mm Schadek Oil Pump
- 8.1:1 Compression Ratio
- Weber 40 IDF's
- Vintage Speed Sport Exhaust
- Stock Weight Flywheel
Currently waiting on the cylinder heads to finish up the long block. Decided today as I'd want a new (rebuilt) transaxle with the new engine as I don't know the shape of the unit in the bus, so I called Rick up at Wright Gearbox to put me down for one. This building on a budget sure does add up
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
metz Samba Member
Posted: Tue May 11, 2021 6:30 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
I'd say this bus was lucky picking its new owner. Keep it up! _________________ 68 panel
64 ghia coupe |
Posted: Wed Jun 09, 2021 10:10 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Finally moving along engine wise, I spent some time yesterday setting up rocker geometry and pushrod length. To achieve the proper angle at half lift, I coincidentally was still able to retain the stock push rod. That was nice.
Waiting on heater boxes from being sand blasted and coated, and trying to decide what to do exhaust wise.
Everyone and their mom is out of the Weber 40's, so I'm trying to figure out my approach right now. Though I'm waiting on my transaxle from Wright Gear, I'm ready to get this engine under load and break in this camshaft. Not my first choice, but do the HPMX 40's clear the stock fan shrouds? I'm almost tempted to just install a damn Solex PICT 34/3 at this point.
Still needing to delete the mount for the oil bath in the engine bay.
More to come. _________________ The Bus Barn Ltd. Co.
Posted: Sat Jun 19, 2021 12:09 pm Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Got around to installing some more key components to the Panel’s engine build. Getting really close to firing it up and burning in that camshaft!
I ended up ordering a fuel pump and distributor from Bill at Sparxwerks. Very pleased with the finish and care, as always.
A close up of the fuel pump. Note this is with the usage of an alternator.
Clears just fine.
I didn’t take any photos of the distributor, but it’s a beautiful 034 that Bill did up nicely. I’m hoping to be able to use it with the dual carbs, if vacuum is an issue, I’ll stash it away and buy a magnaspark or something comparable.
Took a lot longer than it should have, assembly due to the fan shroud made it more difficult and time consuming, but here is the engine with the carbs installed.
Waiting for some free time to fire this bad boy up. The Panel has tons of metal work left to do, but at least when the engines back in, I can drive it in and out of the shop and drive it into the first bay to make use of the lift to get some better access underneath for welding the front end. _________________ The Bus Barn Ltd. Co.
Posted: Wed Jun 30, 2021 12:25 pm Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Well today was the day, I set up my test stand bits and fired it over. Removed ignition components, hooked up lights to oil pressure gauge and cranked for a good 30 seconds. Pressure wasn't an issue, light goes out immediately upon cranking. I know I know, but what was the ACTUAL oil pressure? I don't know, that gauge hasn't come in yet, but will be installed in the bus.
Had an issue getting fuel, and after removing the beautiful pump Bill restored for me, I realized I had the wrong fuel pump rod, so the other new Brazilian pump went back on until I get the correct push rod.
No leaks, no grinds, grunts, knocks, etc...just some occasional exhaust popping due the exhaust on the engine for the test run processing. Running the dual Webers deletes the pre-heat riser tube needs but I impatiently didn't cap them off.
Happy day, ready for my transaxle to arrive from Wright Gearbox!
Posted: Wed Sep 01, 2021 6:53 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
UPDATE TIME!
The bus and I (and the family) just completed the 29th Annual Eureka Springs VW Show in Eureka Springs, Arkansas. Always love coming up to that area. Nothing like breaking in a new motor with a 50 minute 1/2 gear parade in the heat of August!
Here the front nose clip, epoxy primed, ready to be installed onto the bus.
But first I had to weld up the front valance skin. I am still needing to complete both passenger and driver dog leg sections. Also needing to address the lower A pillar on the driver side, so shame me, the front valance is currently "floating" on that side.
I really need to start buying weld-through primer.
And with the new Klassicfab nose installed. I weld the headlight buckets onto the nose while it is off, which gives much better access to the tabs for the buckets. Wire wheel the paint off, drill a couple holes in the buckets and plug weld them together. Easy peasy.
Installed some H4 headlights while I was at it, they truly are a great improvement over the stock sealed bulbed headlights.
On the trailer, ready to head to Eureka Springs this past Friday morning.
Here she is stanced up, outside of La Familia Mexican restaurant in Eureka. The service was terrible so we bounced, went to Amigos downtown. Great food.
Not seen in any of the photos, but that I'm currently still feeling:
- Installed Headliner
- Reupholstered the Front two seats
- Plumbed my VDO Oil Temp Gauge
- Installed Door Panels, Door glass, seals, sweeps, rebuilt the window regulators, installed the pedestal mats, walk through mat, front floor mat.
- Drained oil, ran valves, and away we went!
(I was an absolute zombie in the heat on Saturday during the show after Thursday night's 20hr day. Never Again.) _________________ The Bus Barn Ltd. Co.
Brian Samba Moderator
Posted: Wed Sep 01, 2021 8:08 pm Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
damn that's a good update _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Sep 02, 2021 6:23 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
Thank you Brian. So much work goes into these things that's never seen. I don't attend the shows for accolades or awards, I attend for the community. People have such nice cars, endless pocket books.
And the cleanest, softest hands.
Here's a couple shots of the interior. I thought I had pulled the headliner tighter in the section you seem "bunched up", I'm okay with the outcome, wish it was a little cleaner finish, but not bad for a first headliner go. Much easier it being just the front cab area.
The seat covers and door cards are TMI of course, their color VW Gray, which is more of a light tan/gray tone. I like it, though I do think it will show more dirt, grime, and wear than the typical beige/tan leatherette.
She's coming along. I've got about 200 miles on the 1700 I built, which will soon be dumping the oil and running the valves. I also need to address the exhaust leak that has been present but gotten a little better since I installed the Vintage Speed exhaust.
I'm also getting a little bit of a lean pop (rarely) which I think is from needing some adjustments on the fuel/air mixtures on the Weber 40's. Kicker is, I believe my stock rebuilt pump is pushing out too much pressure, because when I adjust the screws out, it's simply too rich. Jets are about spot on for what I need application wise, so I'm thinking my fuel pressure is too high. I've read mixed opinions, what do dual Webers like best as far as fuel pressure? _________________ The Bus Barn Ltd. Co.
jeb1978 Samba Member
Joined: December 03, 2004 Posts: 197 Location: Cornfields of Illinois
Posted: Thu Sep 02, 2021 7:05 pm Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
SamboSamba22 wrote: |
A close up of the fuel pump. Note this is with the usage of an alternator. |
I've been thinking about adding one of these to my 1600 single port with an alternator. I see it clears the alternator once installed, but can you remove and install the fuel pump with the alternator installed? _________________ 1969 Westfalia 1600 Single Port |
Posted: Fri Sep 03, 2021 12:03 am Post subject: Re: (Nadine) 1969 Neptune Blue Panel Delivery |
jeb1978 wrote: |
I've been thinking about adding one of these to my 1600 single port with an alternator. I see it clears the alternator once installed, but can you remove and install the fuel pump with the alternator installed? |
Yes. There’s more room there than what appears in the photos. _________________ The Bus Barn Ltd. Co.
