RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Sat May 08, 2021 9:34 am Post subject: Upper Timing Chain Guides |
Is it possible to change the upper timing chain guides/tensioner with the engine in the van?
(12Valve VR6 - ‘99) _________________ Rich |
soissisc Samba Member
Joined: April 04, 2007 Posts: 636 Location: Western Pennsylvania
Posted: Tue May 11, 2021 9:20 am Post subject: Re: Upper Timing Chain Guides |
I believe that you must pull the trans out, but you can leave the engine in the car. That gives you the room that you need. _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
Posted: Tue May 11, 2021 9:33 am Post subject: Re: Upper Timing Chain Guides |
I had thought I read somewhere that a plate could be removed to do the top only. _________________ Rich |
Zeitgeist 13 Samba Member
Posted: Tue May 11, 2021 9:43 am Post subject: Re: Upper Timing Chain Guides |
I'm fuzzy about whether that's possible, but I guess the question is why? If the upper rail is worn, then most of the rest of the chain system is probably as well. Best to do them all at the same time and be done with it. Not that I haven't done partial parts swaps myself. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue May 11, 2021 10:16 am Post subject: Re: Upper Timing Chain Guides |
I will try to get a picture. I recall something like that too, but in my head, I cannot wrap my head around how. I have a 12V VR6 on the stand in the garage, I will try to take a picture of that end. For some reason I recall one of the guide bolts is below the part line at the head gasket, but it has been a while since I thought about that. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Tue May 11, 2021 10:42 am Post subject: Re: Upper Timing Chain Guides |
I just watched a video on it, he is working on a jetta it looks like, but he gets the one upper out. You will have to take the intake manifold off anyway too. Changing out the chain my be out of the question though I believe.
https://www.youtube.com/watch?v=gRndLodYKRw _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Tue May 11, 2021 11:53 am Post subject: Re: Upper Timing Chain Guides |
Zeitgeist 13 wrote: |
I'm fuzzy about whether that's possible, but I guess the question is why? If the upper rail is worn, then most of the rest of the chain system is probably as well. Best to do them all at the same time and be done with it. Not that I haven't done partial parts swaps myself. |
Because I have the parts, and I am going on a trip soon. I figure half a job is better than no job, for this, if it’s much faster.
Too bad there is no-one for a reasonable rate I could trust with the job anywhere close. We are VERY rural. _________________ Rich |
Posted: Tue May 11, 2021 12:11 pm Post subject: Re: Upper Timing Chain Guides |
I took a look, but no pics. It looks like you can get the lower guide replaced no problem, but the tensioner side guide looks like a no go without removing the lower cover (pulling the trans). You can replace the tensioner itself but just not the plastic guide. _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
Posted: Tue May 11, 2021 12:50 pm Post subject: Re: Upper Timing Chain Guides |
soissisc wrote: |
I took a look, but no pics. It looks like you can get the lower guide replaced no problem, but the tensioner side guide looks like a no go without removing the lower cover (pulling the trans). You can replace the tensioner itself but just not the plastic guide. |
Thanks _________________ Rich |
