moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Wed May 12, 2021 7:50 am Post subject: Re: O Ghia's Restoration Journey |
Hi Marc,
Do you have the rubber gasket for your trunk yet? If not I would highly recommend buying one from Rudiger Huber in Germany. Chris (Kiwighia68) suggested him a a source for one which fit correctly when I was lamenting Lilcar's trunk fit not looking right. I finally got around to installing it this weekend and the fit of it is incredible. Not cheap, but well worth it in my opinion...
https://www.vintagecarparts.de. _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
Marcdeb Samba Member
Posted: Wed May 12, 2021 6:01 pm Post subject: Re: O Ghia's Restoration Journey |
moogie32 wrote: |
Hi Marc,
https://www.vintagecarparts.de. |
Hi Diane,
I do have a new trunk gasket. It was put on the car by Richard Troy just before he shipped it out. It seems to fit well and it is soft so I plan to put it back on. If I need a better one though, I will certainly look into Rudiger. Richard glued it on with yellow gasket adhesive and made quite a mess. Took me several hours to remove it without damaging it.
Did you have to use adhesive when you put yours on? Thank you for the hint. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Thu May 13, 2021 3:35 am Post subject: Re: O Ghia's Restoration Journey |
Marcdeb wrote: |
Did you have to use adhesive when you put yours on? |
I did use adhesive - the black version of the yellow 3M product- bonds very well and quickly so fitting it in dry was essential. On Lilcar there are two screw holes up in the top corners which would hold it in place but I made the mistake of not making holes in the rubber before installing and after it was in couldn't figure out where they should be - the previous gasket didn't use screws so I left them off this time and won't worry about them unless it seems to be disbonding in that area. If yours sits properly then there is no need to change it - the gasket I had i place before this really bumped the hood up and always bothered me. _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Thu May 13, 2021 12:24 pm Post subject: Re: O Ghia's Restoration Journey |
moogie32 wrote: |
Marcdeb wrote: |
I did use adhesive - the black version of the yellow 3M product- bonds very well and quickly so fitting it in dry was essential. On Lilcar there are two screw holes up in the top corners which would hold it in place but I made the mistake of not making holes in the rubber before installing and after it was in couldn't figure out where they should be - the previous gasket didn't use screws so I left them off this time and won't worry about them unless it seems to be disbonding in that area. If yours sits properly then there is no need to change it - the gasket I had i place before this really bumped the hood up and always bothered me. |
I should perhaps mention that the gasket I received from Rudiger Huber fits so well that I only had to use a few 6" stretches of adhesive at the corners. No screws and no mess, and the hood sits down flush all round. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Thu May 13, 2021 5:05 pm Post subject: Re: O Ghia's Restoration Journey |
kiwighia68 wrote: |
moogie32 wrote: |
Marcdeb wrote: |
I should perhaps mention that the gasket I received from Rudiger Huber fits so well that I only had to use a few 6" stretches of adhesive at the corners. No screws and no mess, and the hood sits down flush all round. |
Thanks for the input. Great to have all this input ahead of time. The Gasket that came with the car seems to be
made of good material. It also seemed to have a good fit before I took it off the car. It's soft and spongy, not stiff at all
and it's new, not even dirty but it does have plenty of glue on it. Luckily the glue peels away with careful work. It had only
been on the car a few months. What's odd to me is that it is made of 4 separate pieces glued in a ring? Is this typical?
it has the cutouts for the channel drains at the front corners.
The 4 glue joints are visible in the picture.
I also have a new gasket for the engine lid but it is totally different. The engine lid gasket is made of a very stiff hard rubber?? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu May 13, 2021 5:09 pm Post subject: Re: O Ghia's Restoration Journey |
Hmm...
That looks like it might be an RT special.
Here’s how mine looks:
_________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Posted: Thu May 13, 2021 5:15 pm Post subject: Re: O Ghia's Restoration Journey |
Marcdeb wrote: |
kiwighia68 wrote: |
The gasket from Rudiger Huber comes as a moulded one-piece. The join is hardly noticeable. The most important feature is that it is moulded at the corners. It fits like a glove - and needs no bending or shaping. And as I said, a small section of adhesive at the corners. _________________ Festina lente - hasten slowly
Trylon Samba Member
Posted: Thu May 13, 2021 5:21 pm Post subject: Re: O Ghia's Restoration Journey |
Where did you buy your gasket? Did you use adhesive? If so just at corners or along the whole length? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Thu May 13, 2021 5:23 pm Post subject: Re: O Ghia's Restoration Journey |
kiwighia68 wrote: |
Marcdeb wrote: |
kiwighia68 wrote: |
The gasket from Rudiger Huber comes as a moulded one-piece. The join is hardly noticeable. The most important feature is that it is moulded at the corners. It fits like a glove - and needs no bending or shaping. And as I said, a small section of adhesive at the corners. |
I like the sounds of that. Maybe I'll be buying a new one, but I'll at least try a dry run with the one I have. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Trylon Samba Member
Posted: Thu May 13, 2021 5:43 pm Post subject: Re: O Ghia's Restoration Journey |
Marcdeb wrote: |
Where did you buy your gasket? Did you use adhesive? If so just at corners or along the whole length? |
Would you believe RT supplied it?
No adhesive. Seems to stay of its own accord. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Thu May 13, 2021 6:07 pm Post subject: Re: O Ghia's Restoration Journey |
Trylon wrote: |
Marcdeb wrote: |
No adhesive. Seems to stay of its own accord. |
Maybe he'll chime in and reveal where he bought it from! _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Trylon Samba Member
Posted: Thu May 13, 2021 6:09 pm Post subject: Re: O Ghia's Restoration Journey |
And maybe Santa bought Rolex’s as bonuses for all the elves that met quota. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Thu May 13, 2021 6:33 pm Post subject: Re: O Ghia's Restoration Journey |
whilst on this discussion... I have never found an engine lid seal that was soft enough to go around the bottom corners and let the lid close evenly.
I have always used a length of front hood seal which is much more spongy. It looks slightly different when fitted but the lid closes nicely and it is much more 'forgiving' |
Posted: Thu May 13, 2021 6:37 pm Post subject: Re: O Ghia's Restoration Journey |
Ian Godfrey wrote: |
You just described my engine lid seal. It's like tire rubber! Maybe my trunk seal will be repurposed for the engine lid, and a new Rudiger Huber could be ordered for the trunk? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri May 14, 2021 4:15 am Post subject: Re: O Ghia's Restoration Journey |
Yes, they are so hard.
The last repurposed seal I got was an NOS front seal with rip in it (off the Samba) that left plenty for me to make a engine lid seal out of |
Braukuche Samba Member
Posted: Fri May 14, 2021 9:29 am Post subject: Re: O Ghia's Restoration Journey |
I did the same, the new engine seals are garbage.
The seal I got from Airhead is a single piece and even using the hold down tabs on the corners pops up and pushes my hood up ruining the alignment. I have my old factory seal which oddly has been trimmed along the back edge. I’m going to clean it up and use it. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sat May 15, 2021 4:52 pm Post subject: Re: O Ghia's Restoration Journey |
While restoring a headlight assembly for the right side, I noticed that out of three headlight assemblies, and
several partial assemblies, all of them have only one spring each? There is two locations for installing springs so I just
want to make sure that two springs is correct. Can anyone verify?
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
