foamermetal Samba Member
Joined: February 17, 2011 Posts: 274 Location: Warner Robins, Georgia
Posted: Tue Jun 28, 2011 6:18 pm Post subject: 68 Ghia that I bought in February |
My 68 Ghia I Drug home in Feb. Hasn't run in 15 years. After checking the oil and feeding it off of bottle of gas she turned right over. I am still slow on the posting of pictures but there will be updates as I get proficient.
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Wed Jun 29, 2011 3:33 am Post subject: |
You had to Drug it home Now you have a Ghia High Congrats, they are fun little cars. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Posted: Wed Jun 29, 2011 11:54 am Post subject: This is the day after with just a wash. |
Posted: Wed Jun 29, 2011 12:12 pm Post subject: Couple shots of the interior. |
Posted: Wed Jun 29, 2011 12:13 pm Post subject: |
Posted: Wed Jun 29, 2011 12:24 pm Post subject: |
I rebuilt the carb and bled the brakes so I could take her around the block. She had the shakes really bad. The PO had replaced the transaxle mount with spliced rubber floor mat. That would explain the bad engine seal alignment. while the engine was out I worked on the apron.
zabo Samba Member
Posted: Wed Jun 29, 2011 12:26 pm Post subject: |
cleaned up nice _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
Posted: Wed Jun 29, 2011 6:28 pm Post subject: |
Here's the trashed out apron
Posted: Wed Jun 29, 2011 6:32 pm Post subject: |
Here I cut out some metal left over from my 63 Galaxie trunk skin( thats alot of free metal) then put the reliefs in it using some form blocks from old 2x4 scraps.
Posted: Wed Jun 29, 2011 6:34 pm Post subject: |
Comparison of the old and new piece.
Posted: Wed Jun 29, 2011 6:36 pm Post subject: |
Finished product with a fabricated seal retainer spliced in all sealed up and painted with some hammer tone rustoleum I had laying around.
Posted: Fri Jul 01, 2011 6:47 am Post subject: |
It took a little while, but thanks to some Samba members in the Classifieds I replaced some small missing tin pieces, cooling flaps with linkage and installed a thermostat. The worst part was drilling out the fully packed preheat tube on the intake. Its not in the picture but I ended up drilling a 1/4" hole in the outside of the curve and ran a 12" bit through. The things you got to do sometimes.
Posted: Fri Jul 01, 2011 7:06 am Post subject: |
Here is a shot of the engine back in the car. New transaxle mounts and bowden tube adjustment, stolen battery from my sons car and she's running nice. Thanks to some nice pictures in the forums on the thermostat linkage and my love for bicycles I was able to fabricate some linkage and a cable to the breather to get the warm air door working.
hudsonce Samba Member
Joined: January 29, 2010 Posts: 506 Location: Hagerstown, MD
Posted: Fri Jul 01, 2011 7:41 am Post subject: |
foamermetal wrote: |
Will you do mine? Seriously, I have a mangled rear apron and channel for engine seat, and clogged heat riser. do you have any details or pics on the channel to hold that engine seal? Do you think the commercially-available patch panels for that section would work as well as your custom fit? _________________ Use "to" for "give the wrench to me."
Use "too" for "I have too many VW projects"
Use "two" for "two people will not fit in the back seat of a Ghia."
For the sake of Peter, PREVIEW your post before you submit it. |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Fri Jul 01, 2011 7:52 am Post subject: |
I'll do yours Chad. The one from KGP&R fits fine. Check out bills 72 vert thread. He installed one I sold him. Not extremely hard. Easier then CIPs exhaust was. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Fri Jul 01, 2011 11:20 am Post subject: |
To fabricate the channel I took a piece of flat steel the width of the original channel and bent it around a piece of bar that goes through chain link fencing. You have to grind the bar down some to replicate the width of the seal. Center it clamp it in a vise and work the flat steel around the bar a little at a time. Mine had the curve in it so I formed it around an old 15" wheel to get the contour. Be easy or it'll want to kink on you. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed May 12, 2021 8:19 pm Post subject: |
Hi sir. I was wondering what those vice grip like clamps are called? my C clamps arent wide enough and these look like they would work well.
thanks _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
