58b on the lighting switch Dash Lights
dgsaz
dgsaz is offline
PostPosted: Wed May 12, 2021 2:13 pm    Post subject: 58b on the lighting switch Dash Lights Reply with quote
I would like to extend power from 58b (dash lights) to three additional gauges.
The addition load is three light bulbs. Can I:
1. Extend the circuit from the last light on the system and just add these to
bulbs to the original system.
2. Put a splitter on terminal 58b and feed the new lights from there.
3. Install a relay, get the 12 volt signal from 58b and feed the additional lights
from the relay. Can I use 58b to signal the relay and power the
original light circuit?
Here's a sketch of how I envision the set up with the relay.
I'm hoping for #2 as it is the easiest install. But, I want to do it the right way.
thank,
dgsaz
johny__utah
johny__utah is offline
PostPosted: Wed May 12, 2021 3:00 pm    Post subject: Re: 58b on the lighting switch Dash Lights Reply with quote
#2, no different than a extra accessory such as a deluxe clock.
1956 L31
1961 L346 L347
1963 L380 L289
busdaddy
busdaddy is offline
PostPosted: Wed May 12, 2021 3:36 pm    Post subject: Re: 58b on the lighting switch Dash Lights Reply with quote
I agree, #2 will work fine, 3 more little bulbs isn't too much more. Adding a relay will make the added lights lose their dimmableness, might as well tap in to 58 if you go that route.
Слава Україні!
telford dorr
telford dorr is offline
PostPosted: Wed May 12, 2021 8:23 pm    Post subject: Re: 58b on the lighting switch Dash Lights Reply with quote
While three additional lights shouldn't be a problem, if you have a lot of extra gauge lights, you can build this buffer circuit. It allows the additional lights to track the original dash lights. Get the 12 volts from headlight switch terminal 58, and the control signal from 58b. The transistor can get quite hot, so mount it on a good heat sink:
Now if the brightness of the new gauge lights is noticeably greater than the original dash lights, then you can use this circuit to balance them:
This is a DYI project, but it's not too hard to build.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
BarryL Premium Member
BarryL is offline
PostPosted: Thu May 13, 2021 6:08 pm    Post subject: Re: 58b on the lighting switch Dash Lights Reply with quote
telford dorr wrote:
Does the 10 kohm resistor have wattage assigned?
telford dorr
PostPosted: Thu May 13, 2021 9:03 pm    Post subject: Re: 58b on the lighting switch Dash Lights Reply with quote
1/8 watt or better.
