GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Tue May 11, 2021 10:01 am Post subject: Kolbenschmidt mains |
Bought a new set of mains.
The case is a New autolinear one.
The oil supply hole in the bearing is only half aligned with the oil supply hole from the case. I can do a C cut in the bearing to get alignment. What I don't like is the full circle groove in the bearing is only 1mm deep. The other unusable bearing I was going to use has a proper 2 mm groove cut into it. I believe the oil supply to the journal will the 1 mm groove will be inadequate. A piece of junk or a bit of sealant will be able to block off that 1mm groove easily. I'll have to get the oil groove cut deeper me thinks. |
spencerfvee Samba Member
Posted: Tue May 11, 2021 10:09 am Post subject: Re: Kolbenschmidt mains |
GARRICK.CLARK wrote: |
......................................................................................................................yes i have done it many times spencerfvee |
Posted: Tue May 11, 2021 11:48 am Post subject: Re: Kolbenschmidt mains |
Roger that Spencer. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue May 11, 2021 8:48 pm Post subject: Re: Kolbenschmidt mains |
What is the bearing made of? |
Posted: Thu May 13, 2021 4:29 am Post subject: Re: Kolbenschmidt mains |
Aluminum. I've sent them back and ordered steel backs. I wasn't given a choice in what I recieved. |
