MartinFidler918 Samba Member
Joined: April 15, 2021 Posts: 17 Location: United Kingdom
Posted: Mon May 10, 2021 3:34 am Post subject: 1968 Beetle Fuel Cut off Valve 6Volt |
hi Everyone, I'm after another bit help!
As per the title I have a 1968 1200cc beetle which is 6 Volt.
I think I have a faulty fuel cut off valve as sometime fuel does not get through and the car wont start.
I'm after replacing this with a brass plug or something, can anyone advise what I can replace this with as finding a replacement for 6 Volt is impossible.
Cheers
Martin |
bomberbob Samba Member
Posted: Mon May 10, 2021 4:54 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Cut off valve on the carb? Does it make a clicking sound when you turn on the key? I guess you could just put a plug in there, but you may have issues with engine run-on then. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Mon May 10, 2021 6:05 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Hi There Yes, the fuel cut off on the carb. It 'clicks' sometimes hence why I think it's on it's way out. Do you know what brass plug I could use?
Cheers
Martin |
Ovally Samba Member
Posted: Mon May 10, 2021 7:29 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
MartinFidler918 wrote: |
... I have a 1968 1200cc beetle which is 6 Volt.
...as finding a replacement for 6 Volt is impossible.
Cheers
Martin |
I suppose you need this one : VW part number 111 129 413A
6 Volt I think, but to be sure you can ask the seller.
https://www.thesamba.com/vw/classifieds/detail.php?id=2206461
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
diamondblue1969 Samba Member
Joined: February 19, 2010 Posts: 95 Location: ONTARIO
Posted: Wed May 12, 2021 2:11 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Thanks guys. It's a good forum here. I think i'll cut the plunger end off to start with.
Many thanks. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Wed May 12, 2021 4:22 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
My 68 1500 RHD doesn’t have a fuel cutoff as standard from the factory. Just leave it off.
I thought these fuel cutoffs were a US thing for emissions reductions so not relevant in most other jurisdictions. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Wed May 12, 2021 6:20 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
viiking wrote: |
I thought these fuel cutoffs were a US thing for emissions reductions so not relevant in most other jurisdictions. |
Not an emission device, or not directly and emission device.
In the late '60s VW added the idle cutoff solenoid as a solution to prevent engine run-on when the ignition switch was turned OFF. Often bypassing the idle cutoff solenoid results in the engine continuing to run for a few seconds after the ignition is turned OFF.
At the instant you turn the key to OFF, the engine's momentum allows the engine to continue to rotate as it slows down. While the engine is still rotating the charging system is producing current. This current can still make it back into the ignition circuit (15) via the GEN lamp. You often see this as the GEN lamp turning ON the instant you turn the key OFF. This current thru the GEN lamp has the ability to power the ignition coil to keep it firing the spark plug weakly. So even though the ignition switch is OFF the ignition coil continues to weakly spark and ignite the compressed charge in the cylinders.
To prevent this from continuing, VW added the idle cutoff solenoid to immediately cutoff fuel to the idle circuit. No fuel means the cylinders will not ignite even if there is spark. Compressed air alone does not ignite. _________________ AshMan40
Posted: Wed May 12, 2021 3:57 pm Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
I understand what “dieseling” is and what it is caused by. I’ve never had it happen in my original 68 which was NOT fitted with the cut off as standard equipment. All I’m saying is remove it and see what happens. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Thu May 13, 2021 12:56 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Cheers guys, don't fight |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Thu May 13, 2021 2:36 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
you can buy a new one from aliexpress for a few bucks (they are used on repro carbs), even if it ends up being c**p it's worth trying IMHO. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Thu May 13, 2021 3:12 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
When the car doesn't start as per usual, pull it off and see if the that remedies the situation. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Posted: Thu May 13, 2021 4:21 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
I'm not fighting! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Thu May 13, 2021 5:17 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Dan the workingstiff wrote: |
When the car doesn't start as per usual, pull it off and see if the that remedies the situation. |
Not as simple as this.
Disconnecting the power from the solenoid will stop fuel flow thru/past it which means no fuel for the idle circuit.
Removing the solenoid and leaving the hole open creates a vacuum leak.
The common work around is to clip the end of the plunger off so the solenoid always allows fuel to flow. But this is a permanent change and cannot be un-done.
The less used option is to remove the solenoid and find a plug with the same sized threads. Since this is less used I've never heard of anyone posting the size of the threaded plug needed. I suppose you could take the solenoid out and take it with you to the hardware store and try different sized nuts and see which one threads onto the solenoid. Then purchase a plug with the same size thread. You will want to make use of a washer or o-ring to seal the plug so no fuel leaks out. Maybe Teflon/plumber's tape could work to seal the threads. _________________ AshMan40
Ovally Samba Member
Posted: Thu May 13, 2021 5:44 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Why make it difficult when it can be easy.
The idle cut-off valve in the link I gave is indeed a 6 Volt type and available.
Part number 111 129 413A (g 55)
VW Bug 1200 D motor
Posted: Thu May 13, 2021 6:58 am Post subject: Re: 1968 Beetle Fuel Cut off Valve 6Volt |
Maybe you could install the threaded portion of the solenoid with the open
end sealed with a dab of silicone ! |
