Water indicator light is always on green
Californio
Californio is offline
PostPosted: Wed May 12, 2021 3:31 pm    Post subject: Water indicator light is always on green Reply with quote
As the title says. Even empty, the kitchen water tank light is on green. This is an 87 Syncro, which has the old style tank sensors, not the one in the the cap.
The Bentley doesn't cover this wiring--in fact, 97-32b mistakenly shows early models of campers having the later in-cap sensor.
Any one have a diagram of the early sensor setup? I can't figure it out.
Timwhy
Timwhy is offline
PostPosted: Wed May 12, 2021 4:36 pm    Post subject: Re: Water indicator light is always on green Reply with quote
clean the terminals on the side of the tank inside the righthand cabinet
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Californio
PostPosted: Wed May 12, 2021 5:48 pm    Post subject: Re: Water indicator light is always on green Reply with quote
I cleaned the inside part of the terminals with 400 grit but no change. I can clean up the outside spade connectors but I'd be surprised if that made a difference.
What I can't tell is why, if the tank is empty, the green light is always on. Something weird. It makes no difference if the spade connectors at the tank are on or off, green light stays on.
I think the sensors in the tank just complete a path to ground, right?
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Wed May 12, 2021 6:20 pm    Post subject: Re: Water indicator light is always on green Reply with quote
Long shot, but it’s not the bottomed green LED for the fridge is it?
Also, is the pump off? I think my my water level turns green when I turn the pump on.
Californio
PostPosted: Wed May 12, 2021 6:43 pm    Post subject: Re: Water indicator light is always on green Reply with quote
No, it's the top one, not the fridge propane-on light. Pump functions normally and the level light stays green with it on or off.
Interesting why yours would turn green when you use the pump, never heard of that one.
dobryan
dobryan is offline
PostPosted: Thu May 13, 2021 6:19 am    Post subject: Re: Water indicator light is always on green Reply with quote
Sounds like there is a short in the wiring to the display causing the light to stay on. Try tracing the wiring harness from the display to the tank.
Dave O
The Western Syncro build
fxr
fxr is online now
PostPosted: Thu May 13, 2021 8:12 am    Post subject: Re: Water indicator light is always on green Reply with quote
I would be checking the ground at the 'little black box' that hides the connections from the tank 'sensors' to the loom at the front of the tank.
Jim Crowther
Vespa GTS 300
Californio
PostPosted: Thu May 13, 2021 8:44 am    Post subject: Re: Water indicator light is always on green Reply with quote
Yes, the only thing I can think of is that the green wire to the panel is somehow grounding out between the tank sensor and the light. I'll post if and when I find what it is.
dobryan
dobryan is offline
PostPosted: Thu May 13, 2021 8:57 am    Post subject: Re: Water indicator light is always on green Reply with quote
You could just run a new wire to bypass the existing wire as a test. And if everything works I'd just abandon the existing wire and use the new one.
Dave O
