bad smell and removing old window tint 73 911
d17
d17 is offline
PostPosted: Wed Oct 02, 2019 8:07 pm    Post subject: bad smell and removing old window tint 73 911 Reply with quote
Need some ideas on getting rid of the bad smell and removing old window tint
from a 73 911 that's been sitting in a garage for 7 years
Thanks
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Thu Oct 03, 2019 7:26 am    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
Thanks
yup typical, after you remove the tint, "start" by using starting fluid to clean off the residue, then use dish washing detergent and water and a sponge. then spray fabreeze and let the car air out
Erik G
Erik G is offline
PostPosted: Fri Oct 04, 2019 2:00 pm    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
for the tint - heat gun. the cheap ones from harbor freight work great
S4VAGE
S4VAGE is offline
PostPosted: Mon May 03, 2021 11:00 am    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
I use a Wallpaper Steamer for tint. Lots of towels to make sure I don't drip too much under the area where I am working. If you don't have one call a friend who has a mid-century home. I guarantee they own one. Very Happy
Ohio Tom
Ohio Tom is offline
PostPosted: Wed May 12, 2021 12:25 pm    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
I prefer to use mineral sprits or Kerosene. Much safer to use on paint and plastics. Won't attack things like other solvents can.
Starbucket
Starbucket is offline
PostPosted: Wed May 12, 2021 3:37 pm    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
Bad smell, look under seats for dead mice. Window tint, Brass wool (boat supply or Amazon) it won't scratch glass and use with white vinegar. Rear window defrost grid will be a problem.
tcmia
tcmia is offline
PostPosted: Thu May 13, 2021 10:00 am    Post subject: Re: bad smell and removing old window tint 73 911 Reply with quote
I have had good results with the heat gun and a razor blade. Glue came off easy with thinner and windex.
