Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Thu May 13, 2021 8:44 am Post subject: Re: AAZ- Once More, Into The Breach...... |
So, I have the engine stripped to the long block. The consensus in the workshop is 'oil starvation'.
_________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
Posted: Thu May 13, 2021 8:50 am Post subject: Re: AAZ- Once More, Into The Breach...... |
When I used to build VW inline engines, I would always prime them before the first start up. I had a simple rig for my drill.
I also found that you need to pay attention to new pumps with the clearance between the gears and the sump section. The last new pump had .007" clearance between the gears and the sump cover.
If reusing the sump, you need to verify the relief valve is not stuck. If all things are correct, there is no practical reason for an inline 4 to not have adequate oil pressure and volume. They have the opposite problem. _________________ ☮️ |
Posted: Thu May 13, 2021 10:25 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I'm not reusing *anything*!
However, I've just opened the shipping crate for the new engine, and I'm not happy!
On the plus side, I now have an extra oil pan, oil pump, front and rear main seals.
There's *no* intermediate shaft!
The bushing is there, properly torqued down, just *no* shaft behind it!
WTMF?
Also, it's obvious to see, on the oil pan is just a paper gasket and not a windage tray.
Today is a German holiday, so I have to wait till tomorrow to call and complain. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Sat May 29, 2021 1:42 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Joy upon Joy!
It's Update Time!
Engine number three is a No-Go at this Station!
I was *almost* finished assembling it, when I discovered that one of the holes for the motor carrier was *off-center*!
This means that only two of the three bolts would fit!
Also, when they recut the threads, they did not cut them all the way down! Minus the motor carrier, the bolt would only thread 2\3s of the way down!
Using a depth gauge, the hole is half a centimeter deeper than the bolt is long.
Add to this, they charged me €200 to drill and tap the head to fit the JX valve cover, only to abandon the job halfway through!
So, as I pulled parts off the old motor, I noticed a few things not reported before. Oil in the exhaust.
Oil in the Turbo.
Broken glow plugs for cylinders 1 and 4.
And yes, the timing was still DNO.
Also, there is a noise in the old motor. See if you can hear it!
So, here is where I stand.
I have two engines, both unsuitable\ unusable to send back for refund.
Now begins the search for another workshop to get an engine from! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Sat May 29, 2021 6:58 am Post subject: Re: AAZ- Once More, Into The Breach...... |
That’s some bad luck for something that should be plug and play. Sorry. _________________ ☮️ |
?Waldo? Samba Member
Posted: Sat May 29, 2021 7:49 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I've probably said before but you might want to consider a 1Z, AHU, or AFN TDI engine and get an LT28 mechanical injection pump to run it. You'd want the engine complete with injectors, metal lines, pump bracket and timing covers. Everything else (intake, exhaust, mounts, etc...) would bolt up exactly the same as it does on the AAZ. The result would be increased performance, 15% better fuel economy, and increased reliability. |
Posted: Sat May 29, 2021 7:55 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I think I might have to take you up on that.... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Sat May 29, 2021 10:38 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Do you have part numbers to help the search? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sat May 29, 2021 10:54 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Wow, that is some crummy stuff! My hats off to you preserving through this and I doubly appreciate this thread with the details.
What your going through does not have me looking forward to the day my AAZ acts up.....
Looking forward to hearing you have a running engine in Frank _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Zeitgeist 13 Samba Member
Posted: Sat May 29, 2021 11:48 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I'm currently in the process of swapping out an AAZ in a Syncro for an AHU with a manual pump, so I can help with some of the gory deets. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun May 30, 2021 1:30 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Zeitgeist 13 wrote: |
I'm currently in the process of swapping out an AAZ in a Syncro for an AHU with a manual pump, so I can help with some of the gory deets. |
That would be awesome, thanks!
I have to start from scratch here, so every little bit helps!
I generally use eBay to resource part numbers and average prices, but I'm having a hard time finding the LT28 manual pump for a four cylinder engine.
(to say nothing for accompanying parts!) _________________ 1990 Feldjäger Syncro AAZ
Click to view image
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Sun May 30, 2021 4:04 am Post subject: Re: AAZ- Once More, Into The Breach...... |
The Land Rover 200/300 TDI pump should work in lieu of a LT28. |
Posted: Sun May 30, 2021 7:03 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Yes, the Land Rover 200/300 TDI pump might be more readily available. There are more gotchas to the install than the LT28 but it would work well. The main ones are:
-pump bracket needs to be machined to the larger pump snout diameter
-either the mounting bolts need to be slotted or the ALH sprocket/hub needs to be used |
Posted: Wed Jun 02, 2021 9:08 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Thanks guzs!
Iäm on Holidaz for a week right now, Iäll have a look when I get back home!
)also on mz wifeäs computer. Sorrz for the spelling mistakes.= _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Fri Jun 18, 2021 1:08 am Post subject: Re: AAZ- Once More, Into The Breach...... |
It has taken *two weeks* for the motors to get picked up!
I've got the van back at the house now, because I don't have another motor ready to go, and the Base Commander now has a tow-happy bug up their ass!
Just this week the contract talks were finalized. Next week, towing begins! The Base Commander has the idea to tow ALL dead and unmoved cars next week.
No fucks given to where they are, in what condition, or anything. If they are in a parking spot, they are getting towed!
So, I just HAD to get the van out of there!
It looks as if I am going to be finishing this in my driveway now....
somehow! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Fri Jun 18, 2021 6:17 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I've done several engine conversions on a dirt and river rock driveway. A garage with concrete slab and lift is nice but not necessary for an engine swap. |
Posted: Fri Jun 18, 2021 6:44 am Post subject: Re: AAZ- Once More, Into The Breach...... |
I know. I did my H6 conversion on Domo/ Dumbo in an unpowered barn with a dirt floor.
But a well lit shop and a lift are much nicer!
This will be finished in my sloped drive-way.
But this time, I had the Tow Driver help me put it on ramps, so I have that going for me now.
My neighbor has a crane I can use, I just need to find an engine stand and I can do it at home. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Sun Jul 11, 2021 8:03 am Post subject: Re: AAZ- Once More, Into The Breach...... |
So, here is an update.
The motor builder is denying my refund, because he says I've mixed and matched the parts (Specifically, I've put a 1,9 in a van that came with a 1,6. Also, he say I don't know what I'm doing, despite in the last conversation, agreeing that I DO know what I'm doing.).
So, now I have to go find a lawyer...
FML! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Fri Jul 16, 2021 2:12 am Post subject: Re: AAZ- Once More, Into The Breach...... |
Still nothing from Tornau Motors, but my work (Pitstop) has gone and ordered me one from *their* supplier.
I have to wait a week or so, but I have one on the way! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Wed Jun 01, 2022 3:00 am Post subject: Re: AAZ- Once More, Into The Breach...... |
SO much has happened since then!
Pitstop fucked me over (again!), was unemployed (again!), and I'm STILL trying to get this f$^&ing motor installed!!!!
GGGHHHHAAAAHHHHHH!!!!!!
So, I have a different front plate on my motor. I can now enjoy the modern tensioner timing wheel! Downside is, the front cover didn't fit (surprise!), so I hit eBay and got another. I am now left with a hole, and questions.....
Is this where the motor mount would be located in another configuration?
The way the mototr sits, it invites dirt and rocks into the timing belt 'safe-space'.
Dear Samba: What To Do? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
