paul356A Samba Member
Joined: July 31, 2015 Posts: 85 Location: Brighton U.K.
Posted: Mon May 10, 2021 5:36 am Post subject: Brake pressure regulator with front disc conversion |
Hi all,
I am fitting bay front discs to my split with a servo dual circuit master cylinder ( all fitted around a Red 9 Design wishbone front end) . Do I need a brake pressure regulator on the rear drums? If so does anyone have any recommendations for a suitable one?
Cheers
Paul _________________ 1956 RHD PGSG bus
1959 RHD 356A |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon May 10, 2021 8:16 am Post subject: Re: Brake pressure regulator with front disc conversion |
I don't know if it's required or the sellers would offer it with their kits. I've had 2 upgrade kits and no issues. I'm wondering what others will pitch in. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 559 Location: I don't recognize it anymore
Posted: Thu May 13, 2021 2:46 am Post subject: Re: Brake pressure regulator with front disc conversion |
I do not have a regulator, but I tried it--nothing changed. I also do not have a servo, so this may not help you. I have 4 wheel disc's on a split. I used the regulator on the rear circuit with a standard dual MC. Made no difference.
I think just having disc's is enough, (especially 4 of them). I think if you're bled well and and adjusted in the rear, you should be fine w/o it.
I think you can do fine w/o the servo MC too. I'm pushing some HP and it stops much faster even before I installed the rear disc's |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Thu May 13, 2021 11:52 am Post subject: Re: Brake pressure regulator with front disc conversion |
I have a late-bus, German ATE DCMC, I don't use a servo with it. I have Wilwood discs up front and T3 drums in the rear, I did not have to modify anything, no residual pressure valve was installed or removed from mine, and it still has plenty of pressure without a booster, with perfect front to rear balance. _________________ "OG = Original German" -- TheSamba.com dictionary |
