Door speaker placement
Page: Previous  1, 2
porkchop-rob
porkchop-rob is offline
PostPosted: Thu May 13, 2021 10:21 am    Post subject: Re: Door speaker placement Reply with quote
Globespotter wrote:
vwwestyman wrote:
Ha ha, we're getting way off the original question!
Not really. The original question asked if there was any problem with speaker placement, and the responses identified both problems and potential alternatives. It's a constant source of amusement when people ask questions. I think they really just want the answer - "Looks awesome. Do it!"
There has been some alternative options offered and some good input about protecting the from moisture in the door. I expected some flack for cutting holes in the door...and y'all didn't disappoint (LOL).
I was really hoping for someone to respond about sound quality and/or aiming of the speakers.
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
Globespotter
Globespotter is offline
PostPosted: Thu May 13, 2021 10:48 am    Post subject: Re: Door speaker placement Reply with quote
Did you read my post? Eh?
Globespotter wrote:
Mounting them on the door results in really poor sound. They face each other and sound terrible. I eventually mounted under-dash speakers - on brackets and tilted both slightly inward and up. The sound is SO much better, and no worries about speakers in the doors.
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
porkchop-rob
PostPosted: Thu May 13, 2021 11:21 am    Post subject: Re: Door speaker placement Reply with quote
Yes, I should have followed up with a question. Sorry. How and where were your door speakers mounted?
I think a lot of people may have poor performance due to mounting too low and without enough reinforcement (due movement of door panel).
This is why I am trying to move them up onto a stronger/higher portion of the door....and I'm considering building pods or mounts to slightly angle to speakers for better imaging.
1965 Beetle
Globespotter
PostPosted: Thu May 13, 2021 11:55 am    Post subject: Re: Door speaker placement Reply with quote
Good questions. Mine were lower in the door - as most people - using that existing hole, so yeah that certainly would have a negative effect on the sound. they were fairly solid, but mounted to the panel, so movement could have been an issue too.
It would be interesting to hear how good your sound is if you do end up placing them there, and if any others have placed them higher. Thanks for the context. It helps.
richparker
richparker is offline
PostPosted: Thu May 13, 2021 4:11 pm    Post subject: Re: Door speaker placement Reply with quote
It’s a bus, not an infinity. It’s gonna be loud on the inside and you’re gonna have external noise interference drowning out the music. Time, energy and money could be better spent installing new door seals, new window seals, installing deadening, reducing induction and exhaust noise. Basically anything you can do to reduce road noise and your music will sound better, no matter what the speakers are mounted too.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build
Globespotter
PostPosted: Thu May 13, 2021 4:50 pm    Post subject: Re: Door speaker placement Reply with quote
...or make sure your kick butt stereo can overcome all those external noises lol. Remember the old adage - if you hear a weird noise, turn up the radio!
porkchop-rob
PostPosted: Thu May 13, 2021 7:49 pm    Post subject: Re: Door speaker placement Reply with quote
This is all true and also going to be addressed....not to an SQ level build, but some deadening and noise control is for sure necessary.
1965 Beetle
aeromech
aeromech is offline
PostPosted: Thu May 13, 2021 9:10 pm    Post subject: Re: Door speaker placement Reply with quote
A couple ear pods are the answer. Times are changing. The old days when you park your bus and crank up the stereo are over. Now a Bluetooth speaker and an iPhone are all it takes. No more big amps and stereos powering several speakers. I use a Bose sound link resolve out by my swimming pool and it fills the whole yard with music. No wires. No expensive hardware. Speaker technology has come a long way. I don’t have a home stereo system like the old days. My echo show fills the whole living room with sound plus does a lot more.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Bursch
Bursch is offline
PostPosted: Sat May 15, 2021 2:45 pm    Post subject: Re: Door speaker placement Reply with quote
Beefed up the lower part to fit 8" woofers.
Angled the mid and high to improve soundstage
1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Camper Special Club Member
vwwestyman
vwwestyman is offline
PostPosted: Sat May 15, 2021 9:55 pm    Post subject: Re: Door speaker placement Reply with quote
So now I'm curious- Did you also do power windows, since the cranks are blocked?
And what is the silver thing above the corner of the door panel? A puddle light?
Dave Cook
1973 Wild Westerner
My Thing
Page: Previous  1, 2
Page 2 of 2
