The_orange_beetle Samba Member
Joined: September 15, 2020 Posts: 61 Location: London
Posted: Thu May 13, 2021 12:12 pm Post subject: Exhaust clamp! How tight? |
Hi all. Really simple one. The clamp between the heater box and the exhaust, how tight should I do that up? I have given it a good go but still has a leak. Do they need to be mega tight?
Cheers |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Thu May 13, 2021 12:30 pm Post subject: Re: Exhaust clamp! How tight? |
Do you have a new sealing steelwool-like mesh gasket and the sealing ring?
It should be pretty tight but with a good new gasket, it should seal right up.
#12 and #13 in this picture.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu May 13, 2021 2:21 pm Post subject: Re: Exhaust clamp! How tight? |
I've found they need to be pretty tight, especially with aftermarket headers.
I do like the mesh donut gaskets though. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu May 13, 2021 3:06 pm Post subject: Re: Exhaust clamp! How tight? |
Hi. Yep I have brand new everything. But have a leak on both sides. Was a little worried about over tightening them. |
Cusser Samba Member
Posted: Thu May 13, 2021 7:39 pm Post subject: Re: Exhaust clamp! How tight? |
The_orange_beetle wrote: |
If you break one of the long 6mm x 1.0mm bolts, get a new one, maybe a stronger one. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
goober Samba Member
Posted: Thu May 13, 2021 9:37 pm Post subject: Re: Exhaust clamp! How tight? |
It depends on how well things fit and how thick the clamp and tapered ring are.
Many of today's clamps and rings are so thin the clamp ends and rings will deform or mash apart before applying enough squeeze. Along with sloppy fitting malformed doughnuts, oversize muffler holes and a possible undersized exchanger pipe, it's easy to see why today's parts leak.
I have a whole litany of crap I do to prep a new muffler and exchanger to make a tight well-functioning system....the clamps
I find as thick of a clamp and tapered ring as I can. I drill the holes out to 1/4". I use grade 5 or 8, 1/4-20 x 2" bolts and cut more threads about a 1/2" further up the shoulder. I try to find well-fitting well-formed doughnuts. But if all else fails, I still have an old bag of new well-fitting asbestos doughnuts that I purchased many moon's ago. (one time I was going try brazing the outer of a thin new clamp to see how well it strengthened...but never did)
With the above clamps I can tighten as much as needed. The muffler/exchanger joint normally doesn't require too much force. But to seal and hold the sloppier fitting stacks in place, usually takes quite a bit more. |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Fri May 14, 2021 12:33 am Post subject: Re: Exhaust clamp! How tight? |
I put some sealant along with the donut. The tips from the heater boxes tend to be corroded and uneven. The sealant deals with that better.
The bolts in some kits are only grade 5.x (metric) vs. the more common 8.8. I've bent and snapped a couple. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
brando90gl Samba Member
Posted: Fri May 14, 2021 4:08 am Post subject: Re: Exhaust clamp! How tight? |
bnam wrote: |
The bolts in some kits are only grade 5.x (metric) vs. the more common 8.8. I've bent and snapped a couple. |
I used copper RTV at those joints on the last one I installed. No leak. _________________ 67 Type 1
68 Campmobile
70 Single Cab |
