mbrobe Samba Member
Posted: Thu May 13, 2021 7:00 am Post subject: Back after 10 years, finally adding 2276cc engine. |
Hey all,
Now that my boys are not babies anymore and I upgraded my garage space, my '72 STD Bug is going to get attention again. I am very excited to be back browsing these forums after a good 10 years. I see a lot has not changed which is very refreshing. A lot of the same folks out there. My bug has been sitting in PPG primer, doors off, and all a mess of parts but the good part is the chassis is complete.
To get the ball rolling again and give myself some motivation I ordered up myself a 2276cc from Mofoco with all the options! The build is about 5-6 months out so that gives me some time to get the old '72 ready.
Wish me luck and I will post some pictures as my progress moves along.
Cheers all! _________________ '72 Standard Bug |
ac509 Samba Member
Joined: September 20, 2012 Posts: 160 Location: moved
Posted: Thu May 13, 2021 12:32 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
good luck!
i can't wait to see pictures. we love pictures. _________________ Dumber people are doing harder things everyday.
No one questions a 73' Volkswagen?
I have a '73 Volkswagen and it is nowhere near 73' long! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Thu May 13, 2021 5:28 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Welcome back to the VW world, and being motivated to be active again. Have you decided on the carburetion for the 2276, and overall characteristics: torquey or high power, etc? Wise preparations for your '72 would be front disc brakes and a tachometer. |
mbrobe Samba Member
Posted: Fri May 14, 2021 7:27 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
I am going to do Weber 48 IDAs on the 2276. I would like to have a high power street bug to zip around in. I don't car about gas mileage or if I have to tweak the engine every once and awhile. I basically said screw it and added every option on Roy's website with 1.4 rockers.
I had high hopes of building it myself but I just need it done right. I may rebuild my old stock motor to mess around on and have this one done professionally.
I have Gia disc brakes on it and I think they should be ok still. All they did was sit on the chassis in a garage for 13 years Some surface rust is all.
I will get some pics posted later this month or early June of current status. I am in the process of moving houses so everything is in disarray.
some old pics of chassis:
mbrobe Samba Member
Posted: Fri May 14, 2021 7:36 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
old chassis pics
mbrobe Samba Member
Posted: Fri May 14, 2021 7:42 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
and....for entertainment purposes, this is what it looks like now!
embarrassed but life happens.
Now I just want to get it drivable. I don't care what it looks like.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri May 14, 2021 8:33 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Looks like a neglected project. For sure.
But your plans to resurrect it are good too.
Has the trans been beefed up? If not. But plan on driving the car hard. The trans break pretty easy.
I have a 2180 and it didn't take much to break the side gears during a hard launch. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
mbrobe Samba Member
Posted: Fri May 14, 2021 8:42 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
There are many misc. parts that were bought and installed. I am in the process of trying to remember what those are and going through receipts.
The transmission installed currently is one I bought from aircooled.net in '07. The description on my receipt is: Pro Street Transmission 4.125, Super Beetle
I can't remember why it says Super Beatle. Also, I think 4.125 is what I want but I am refreshing my memory on all these stats and such.
The transmission has never seen a motor mounted to it.
I still have my original transmission as well. _________________ '72 Standard Bug |
Posted: Fri May 14, 2021 8:53 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
IRS trans will fit either a standard or SB. From the doors back there's really no difference between the two.
Pro street will do. Also the Kafer bar setup will help some in stiffening up the drive line.
Perhaps you can update your avatar to indicate where you are located. Sometimes when folks get stuck/stumped. A local enthusiast can lend a hand in sorting an issue. _________________ I have learned over the years.
Buy Once, Cry Once!
mbrobe Samba Member
Posted: Fri May 14, 2021 9:12 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Thanks for the support. I updated my location. I used to be in Minneapolis but now moved to Hudson,WI. This is one of the reasons I choose Mofoco. I will be able to pick up my engine and meet the team building it.
I wanted to start this thread just in case I needed some help putting humpty dumpty back together again. _________________ '72 Standard Bug |
fredybear Samba Member
Posted: Sat May 15, 2021 11:36 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
I win
This is how to stuff a buggie full
What year is it??? Can you spot the clue |
mbrobe Samba Member
Posted: Sat May 15, 2021 11:51 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Hahaha, that does make me feel a little better
1959? I see the semaphore. _________________ '72 Standard Bug |
Posted: Sat May 15, 2021 12:50 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Close...you got the clue
55
The next project, if I can get in out |
Chip Samba Member
Posted: Sat May 15, 2021 2:18 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
fredybear wrote: |
55
I was gonna guess 55 or earlier, but not cuz of the semaphore. The notch in the b pillar just next to the semaphore is the real clue there 😉 |
mbrobe Samba Member
Posted: Thu Aug 05, 2021 6:38 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Adding some current pics for anyone that wants to see them
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Aug 05, 2021 7:05 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
That's a hell of a garage upgrade! Looks good, keeping at it is the only way it will get done. |
mbrobe Samba Member
Posted: Thu Aug 05, 2021 8:34 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
txoval wrote: |
Thank you very much, I could not be happier! _________________ '72 Standard Bug |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Thu Aug 05, 2021 9:07 am Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
Nice garage space. I suppose there is some sort of living quarters attached? And somewhere to prepare food? Priorities. Was that Marina Blue when you started out? My '73 bug started out a shell too, Took 53 weeks to build from when i brought it home on a trailer to first drive. Think you can beat that?
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
mbrobe Samba Member
Posted: Thu Aug 05, 2021 12:47 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
BIGMIKEY wrote: |
Mike T |
Living quarters are in the house next to this extra 3 car garage. I was lucky enough to have a 2 car attached to the house. That is the Wife's garage. My garage has 500 sq ft unfinished 2nd floor. Future lounge area someday.
Bug was Marina Blue to start. I am still undecided on final color. I have a few ideas but pictures only. I need to track down some PPG codes.
My engine is set to be ready later this year so I hope to work quick to get this thing back on the road in Spring.
I plan to get all the chassis work soon, get the body bolted back on, then get this thing sprayed before it gets too cold. Electrical and interior will happen over winter and then hopefully drive time. _________________ '72 Standard Bug |
mark tucker Samba Member
Posted: Thu Aug 05, 2021 1:32 pm Post subject: Re: Back after 10 years, finally adding 2276cc engine. |
nice dog... garage is ok but wont stay that way.... getter done!!! |
