GratefulPhish Samba Member
Joined: July 20, 2020 Posts: 175 Location: Philadelphia
Posted: Fri May 14, 2021 11:08 am Post subject: Fuel pump question... |
In researching suggestions for a fuel pump leak, I realized there are different types depending on if the car has a generator or alternator. Anyway, my car has a generator but I think has the fuel pump generally associated with an alternator. Aren't the fuel pump rods different lengths?
diamondblue1969 Samba Member
Joined: February 19, 2010 Posts: 95 Location: ONTARIO
Posted: Fri May 14, 2021 11:31 am Post subject: Re: Fuel pump question... |
Your fuel line routing looks risky over the heat riser .
Your fuel pump should have the shorter rod. |
Posted: Fri May 14, 2021 11:38 am Post subject: Re: Fuel pump question... |
so its not necessarily the pump style but the rod length that matters? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri May 14, 2021 11:52 am Post subject: Re: Fuel pump question... |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Fri May 14, 2021 12:09 pm Post subject: Re: Fuel pump question... |
If your car is working fine then you likely have the correct (100mm) rod since you have the alternator style fuel pump. If you had the generator style rod (108mm), your fuel pump would be gone by now.
As for the leak, can you see where it is coming from? Obvious places to check would be to take the fuel pump off and replace the gaskets under and over the stand. Make sure that the carb inlet is not leaking or fuel pump inlet/outlets are not leaking.
Check the pressure of the fuel pump as well. A new pump I bought was almost 7 pounds when it should have been around 3 pounds. I had to add a bunch of gaskets to raise the fuel pump to decrease the pressure to 3. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Fri May 14, 2021 12:25 pm Post subject: Re: Fuel pump question... |
GratefulPhish wrote: |
Anyway, my car has a generator but I think has the fuel pump generally associated with an alternator. Aren't the fuel pump rods different lengths? |
Yes the push rod lengths are different and the pump + push rod must be a matched set. Do not mix up pumps and push rods.
Originally, you could ID the type of pump externally by whether the pump stood upright (generator) or if it was angled (alternator). The angled pump was needed to provide clearance between the pump and the larger alternator body.
Unfortunately, the aftermarket has changed things...
The left pump below is angled but uses a generator length pushrod. Note the operating arm does not extend below the base.
So just looking at whether the pump is angled or not is no longer a definite way to ID the pump and the push rod is needs.
Also, there is an upright generator pump that uses the longer 108mm pushrod, but the pump body is "squat" enough that it will fit next to an alternator so an alternator pump + alternator pump push rod is not specifically needed when using an alternator. Read the description of the pump below.
https://www.chircoestore.com/product/chrome-fuel-pump-all-vw-bugs/
Without taking the pump off the engine and looking if the operating arm extends below the base... you can often look at the location of the pivot pin in the body of the pump. The pivot is lower (closer to the base) on the alternator push rod pumps. You can sort of see this in the top pic above.
The best way is to remove the pump. That way you can also confirm if you have the correct length push rod. Always better to check than assume. _________________ AshMan40
