Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Fri May 14, 2021 1:08 pm Post subject: Re: Fuel Pump & pin questions |
AirHead1966 wrote: |
____a. A bolt that is (i) a bit longer than the pin; (ii) very slightly thinner than the pin |
The pin is smooth and the bolt is threaded.
It's smooth for a reason, a rough surface will wear the opening in the lever. _________________ Glenn
Member #1009
#BlueSquare |
