caden422 Samba Member
Posted: Fri May 14, 2021 2:23 pm Post subject: Volkswagen 1974 bus engine, good or no? |
Hi, I'm very new to Volkswagen Buses but I've recently fallen in love with owning one. I bought the manual How To Keep Your Volkswagen Alive, but I was hoping you guys could help me out with knowing if somethings wrong with this engine as I'm still a little unsure due to being knew. I thought it could be an issue with the lifters or a cylinder but my friend says it sounds ok for an air cooled engine and just needs a tune up/ fixed timing. Any help would be great, here's a link to a YouTube video of it running. https://youtu.be/EWHioaUj6PY [/youtube] |
Posted: Fri May 14, 2021 2:31 pm Post subject: Re: Volkswagen 1974 bus engine, good or no? |
sorry i forgot to mention its a 1974 type 2 bus if that helps any |
Wreck Samba Member
Posted: Fri May 14, 2021 2:58 pm Post subject: Re: Volkswagen 1974 bus engine, good or no? |
noises on YouTube videos are very hard to diagnose because the mic pics up different sounds etc . In saying that it sounds like an exhaust leak .
Buses have 2 different engines , a flat type 4 engine or an upright type 1 engine ,the same used in a bug . That is a type 4 engine .
It is hard to see on the video but it looks like the engine bay sealing tin and seal is missing , (google pictures of bus type 4 engine bay and you will see a big foam seal that goes all the way around the engine . )if so this is bad and causes severe overheating because the hot exhaust is recirculated by the cooling fan back over the engine .
one of the results of over heating the cylinder heads on type 4's is the heads get soft and the exhaust studs pull out of the heads , giving and exhaust leak at the head. the only proper way to fix that is replace the heads . A pair of heads are worth approx $1000 . |
Posted: Fri May 14, 2021 3:09 pm Post subject: Re: Volkswagen 1974 bus engine, good or no? |
Thank you, this really helped me out |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6008 Location: CONGERS, N.Y.
Posted: Fri May 14, 2021 7:10 pm Post subject: Re: Volkswagen 1974 bus engine, good or no? |
Caden, The T-4 engine is a much stronger engine which is needed for a heavy non aerodynamic bus. That said unlike a bug a bus is like bigger garage, the larger it is the more junk you put in it. That comes down to weight.
The T-4 engine in a bug lasts a long time, mine as been in my bug for 30 years, same engine. less weigh less the engine has to work. In a light bug the T-4 is very forgiving.
A loaded bus can weight 3 times a bug with full travel gear.
Just keep that in mind, like Wreck said keep the engine compartment sealed
I am sure you will be receiving other helpful tips. Buses are a very sort after vehicles. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
oprn Samba Member
Joined: November 13, 2016 Posts: 12632 Location: Western Canada
Posted: Sat May 15, 2021 4:40 am Post subject: Re: Volkswagen 1974 bus engine, good or no? |
My Bus engine sounded like that too and with all the missing tin and engine compartment seals that one is most likely a cracked head. That is what was wrong with mine. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
