Speaker
ELFRIED
ELFRIED is offline
PostPosted: Fri May 14, 2021 4:42 am    Post subject: Speaker Reply with quote
Hi ,
This speaker was in my 63 ghia and as you can see the cone and outer band were detoriated.
I can't find the wright size cone to repair and I'm wondering what to do now.
I'm certainly no audio expert, so which speaker would fit to work with my bendix saphire 2?
Knowing it's a 6 V car but I don't know if 6 ,or 12V makes a differance for speakers.
ELFRIED
ELFRIED is offline
PostPosted: Fri May 14, 2021 4:44 am    Post subject: Re: Speaker Reply with quote
AirHead1966
AirHead1966 is offline
PostPosted: Fri May 14, 2021 5:28 am    Post subject: Re: Speaker Reply with quote
Search Amazon for 5 inch, 4 ohm speakers. Your picture shows 13cm (5 inch) and 4 ohms clearly. Speakers are not rated by voltage.
Here is an example. There are many others.
https://www.amazon.com/Speaker-Mounting-Depth-Various-Vehicles/dp/B00CRKJWGE/
ELFRIED
ELFRIED is offline
PostPosted: Fri May 14, 2021 6:50 am    Post subject: Re: Speaker Reply with quote
Thanks very much.Again something I learned.
Braukuche
Braukuche is offline
PostPosted: Fri May 14, 2021 9:25 am    Post subject: Re: Speaker Reply with quote
I get mine from Woodys. They fit right.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
tisius
tisius is offline
PostPosted: Fri May 14, 2021 1:40 pm    Post subject: Re: Speaker Reply with quote
ELFRIED wrote:
I see a Mitsubishi logo Very Happy
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
ELFRIED
ELFRIED is offline
PostPosted: Sat May 15, 2021 1:03 am    Post subject: Re: Speaker Reply with quote
T zal idd wel genen originelen zijn
tisius
tisius is offline
PostPosted: Sat May 15, 2021 3:03 am    Post subject: Re: Speaker Reply with quote
Correct, want origineel zou dat vanuit Volkswagen van het merk Blaupunkt zijn geweest.
So I personally would not attempt to repair the broken one you have now. Instead look for a decent modern speaker with the exact same mounting holes size, connect the speakerwires to your old contacts for you radio, and then you have something that delivers music (and pleasure)
for years👍
ELFRIED
ELFRIED is offline
PostPosted: Sat May 15, 2021 1:20 pm    Post subject: Re: Speaker Reply with quote
Ok ,I will do so.
Thanks all.
stoph
stoph is offline
PostPosted: Sun May 16, 2021 5:09 pm    Post subject: Re: Speaker Reply with quote
This was a perfect fit for my '61.
https://www.retromanufacturing.com/products/standa...rmann-ghia
'61 Ghia Convertible
View user's profile Send private message Send e-mail Twitter Classifieds Feedback
