MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Wed Jul 08, 2009 3:37 pm Post subject: Door handle removal... |
Sorry about this one, but I don't want to break anything, and can't find the info.
Want to remove the interior handles to remove my door panels without breaking the handle.
Best way?
Thanks! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Wed Jul 08, 2009 3:56 pm Post subject: |
Thanks Everett! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Jun 04, 2012 9:34 am Post subject: |
OK. I did a bit of searching, and have not found a clear answer so I figured I would just continue this thread.
I cannot, through any method, get the inner front door handles off of my 57 Kombi. When I push in on the escutcheon, it only travels about half (or less) of the distance needed to remove the pin. I have removed these before, so I know how it's supposed to work, but these won't budge.
I have tried several methods, I have sprayed some penetrant in there, I have lit candles and spoken in tongues. Nothing will budge them.
My next step, unless someone has a magic bullet for me, is to cut/crack/grind off the escutcheon. I have replacements, and they are not that hard to find or expensive. I also do not want to wreck the door panels. They are not perfect, but they are original.
What say you? Any help is much appreciated. _________________ nothing |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Mon Jun 04, 2012 6:53 pm Post subject: |
Could the pin be askew such that it's preventing the ring from sliding in? Does the panel push in enough to see what up? |
Posted: Mon Jun 04, 2012 7:54 pm Post subject: |
This is as far as they will go. In the second pic you can just see the edge of the pin. Both door handles act the same way. If I push any harder I am just bending the inner door structure. _________________ nothing |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Jun 04, 2012 8:23 pm Post subject: |
is it binding up the same all around the handle? _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Mon Jun 04, 2012 8:27 pm Post subject: |
Yes. I have tried pushing it on all sides and at angles, and it will not budge. I almost seems like there is something stopping it from behind the door panel, but I can see down in there and all that is visible is the spring. _________________ nothing |
Posted: Mon Jun 04, 2012 9:02 pm Post subject: |
Maybe it's just the pic but it almost looks like there's a collar inside the esc. in the second pic.
I wonder if the spring came through the panel is is wedges bewteen the esc and the panel itself. _________________ Your Vanagon sucks, Stop waving at me.
westfaliaftw Samba Member
Joined: April 02, 2011 Posts: 64 Location: Alberta, Canada
Posted: Thu May 13, 2021 4:26 pm Post subject: |
cdennisg wrote: |
Yes. I have tried pushing it on all sides and at angles, and it will not budge. I almost seems like there is something stopping it from behind the door panel, but I can see down in there and all that is visible is the spring. |
Was there a solution to this baffling problem? I am in the exact same boat with my 56. Panel won’t move in any further to expose the full roll pin. My door panels and handle are in great original shape so I do not want to damage them at all. Thanks in advance! _________________ 1974 standard beetle - Africa red
1959 deluxe beetle - l41 black/brick red interior
1956 single cab - dove blue
1961 standard micro bus - mango green/dove grey
1971 campmobile - pastel white |
Posted: Thu May 13, 2021 7:26 pm Post subject: |
westfaliaftw wrote: |
cdennisg wrote: |
Was there a solution to this baffling problem? I am in the exact same boat with my 56. Panel won’t move in any further to expose the full roll pin. My door panels and handle are in great original shape so I do not want to damage them at all. Thanks in advance! |
I do not own that bus any longer, but I had always just planned to cut through the escutcheon plate to expose the innards. I had plenty of spares on hand at the time. _________________ nothing |
Clara Samba Member
Posted: Sat May 15, 2021 8:37 am Post subject: Re: Door handle removal... |
FWIW, VW tapped the pin down when installing, and it tends to be easier to remove it by tapping up.
I have found that sliding a screwdriver between escutcheon and handle helps.
Some times, the escutcheons have a groove where the pins was installed., removed before. if so, rotate it to take advantage to the extra mm of clearance.
A couple times the escutcheon cracked and broke when it was very tight. At least now there are repros.
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
