lanaeandrews Samba Member
Posted: Sat May 15, 2021 10:32 am Post subject: 72 VW bus Rust issue |
I have a 72 VW bus and the rain gutter is rusting pretty bad. Can I use rust converter to fix it? Also, should I use rhino liner after to keep it from continuing to rust? I live at the beach with no garage, so it's a constant battle. |
Braukuche Samba Member
Posted: Sat May 15, 2021 11:31 am Post subject: Re: 72 VW bus Rust issue |
lanaeandrews wrote: |
No, it only neutralizes the surface of the rust. Underneath will still be active rust. The only real solution is to remove it, prime and paint the area. Removing it means getting down to shiny metal. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
2type2 Samba Member
Joined: June 02, 2002 Posts: 975 Location: SW Colorado
Posted: Tue May 18, 2021 3:59 am Post subject: Re: 72 VW bus Rust issue |
If the rust is inside the gutter, use a wire wheel to get cleaned free of seam sealer, then repair metal , Ospho treat, re - seal with seam caulk, then paint it. _________________ "A life of peace and happiness depends on your own gratefulness" |
